Upgrade to Premium
Electronics Beacons, GPS, communication systems, etc.....
Reply
  #1
Old 02-07-2014, 07:37 PM
MrDieselTwitch MrDieselTwitch is offline
Currently: Not set.
Basic Member
MrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond reputeMrDieselTwitch has a reputation beyond repute
Default GoPro Battery Short Life - My Solution
So I don't know who else has this problem but it bugged the hell out of me. I would be riding along. do some thing awesome, crash, do some awesome side hill or get stuck is some awesomely deep snow... I look down at my go pro and the battery had died long ago....
These batteries are sadly underpowered. at most they last 1.5 hours. in the cold its even less and 20$ a pop you have to spend 100$ or more to be able to recored an entire ride. On top of that who want to be changing out batteries every hour....
So here is what I came up with.
I found a Dummy battery. drilled a hole in the back of the go pro cover and fed the wire threw a grommet. This keeps it snow tight (not water tight) I then made a barrel plug connection from a 15Ah (Equal to roughly 15x standard gopro batteries) battery. Im guessing battery life will be between 13-15 hours. Enough for two days worth of riding. Ill run out of storage long before I run out of battery power!
Rate this post: Yes | No
The Following 6 Users Say Thank You to MrDieselTwitch For This Useful Post:
801 (03-05-2014), bic (09-29-2014), Bowfisher (03-09-2014), christopher (03-05-2014), mountainhorse (09-30-2014), yz400ex (03-05-2014)
  #2
Old 03-05-2014, 11:36 AM
2Huskies's Avatar
2Huskies 2Huskies is online now
Currently: not being CBP any longer
2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute
Garage
Default
Man I just went ahead and got the extended battery pack and case... But that is definitely one sweet solution.
You posted about a month ago, how is it holding up?
  #3
Old 03-05-2014, 11:40 AM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default
And HOW has it been working?
__________________
  #4
Old 03-05-2014, 03:40 PM
Jay's Avatar
Jay Jay is offline
Currently: Watching it snow
Jay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond reputeJay has a reputation beyond repute
Default
Nice!! I have trouble with the battery pac as well.
__________________
You decided to take the walk to the darkside of mod custom built motors...this is a walk you take alone Indy Dan
Best way to tune a race engine is to lean on it till ya put the rods out about 50 feet before the finish line then back it down 1 tooth on the pulley so it lets go 50 feet after the finish 2XM3
  #5
Old 03-09-2014, 08:38 AM
Bowfisher Bowfisher is offline
Currently: Not set.
Bowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond reputeBowfisher has a reputation beyond repute
Garage
Default
Nice job. I've been thinking about doing something similar to this. How's it been working for your?
  #6
Old 06-06-2014, 08:29 AM
rodroc rodroc is offline
Currently: Not set.
Basic Member
rodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond reputerodroc has a reputation beyond repute
Default
This really looks like a great solution. Hope you can update us all on how it worked for you. I think I will try to give this a try, although I am not very good at building or putting together things. Thanks for sharing this with us.
Regards
Rod
DPF Delete
  #7
Old 08-04-2014, 10:22 AM
2Huskies's Avatar
Garage
Default
Still hoping to hear an update...
  #8
Old 09-28-2014, 07:17 PM
DieselTwitch DieselTwitch is offline
Currently: Trying to get lost
DieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond repute
Default
Quote:
Sorry its been a crazy busy summer. The system work extremely well! I had 15 hours of of solid recording, no more missed shots, no more having to stop to change batteries! the only thing that I ever had to change was the memory card and making sure the camera was still pointed right.
The Following 2 Users Say Thank You to DieselTwitch For This Useful Post:
Bowfisher (09-29-2014), christopher (09-29-2014)
  #9
Old 09-29-2014, 11:25 AM
2Huskies's Avatar
Garage
Default
I would very much like to do this
  #10
Old 09-29-2014, 06:13 PM
Garage
Default
Ya, power loss in the cold has been HUGE
__________________
  #11
Old 10-05-2014, 09:24 AM
Click Here to Register
  #12
Old 10-05-2014, 09:28 AM
  #13
Old 10-05-2014, 10:21 AM
Bergie Bergie is offline
Currently: Once you've flown, you'llwalk the earth with your eyes towards the sky
Bergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond reputeBergie has a reputation beyond repute
Garage
  #14
Old 10-05-2014, 03:28 PM
  #15
Old 10-26-2014, 01:16 PM
Davajn Davajn is online now
Currently: Braaaaap - Polaris Ambassador Sweden
Davajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond reputeDavajn has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — gopro 3 battery life Thread Starter — sloz71 Forum — Video Cameras Replies — 9 Last Post — 04-19-2013 05:17 PM
Thread — CONTOUR GPS BATTERY LIFE Thread Starter — rmkboy38 Forum — Photography & Video Replies — 3 Last Post — 09-03-2012 07:58 AM
Thread — Short draining battery on RT Thread Starter — goofy Forum — Ski-Doo Replies — 5 Last Post — 10-21-2008 08:03 PM
no new posts
