Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 02-06-2014, 08:31 AM
trav427 trav427 is offline
Currently: Not set.
Basic Member
trav427 is an unknown quantity at this point
Garage
Default rx1 with new front mount acts like on the rev limiter at 7-8k
Iam pulling my hair out trying to get this thing to run right . This was a new build from scratch no matter what i do it will not rev past 7-8k at that point it sputters and pops out the exhaust like it is on the rev limiter .afr @ 12.2
What is on it .
Prologger with boost control
excel exhaust
garret gt-2864
Stacked head gaskets
new plugs gapped at 0.018"
billet Ts and Caps
Ts tied to u shape pilot tube
back side of carbs tied to dedicated 1/2" fittings with equal length lines
as Iam sitting here typing this iam thinking i still have 03 coils could these be arcing out when pressure rises ?
I guess i will go after coils if anyone else has any ideas they would be appreciated.
Rate this post: Yes | No
  #2
Old 02-06-2014, 09:46 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
Are you confident that you have the boost sensor plumbing for the carbs done correctly? 7k is right where it comes onto the boost so it sounds to me like the carb may not be getting pressurized correctly. Is your fuel pressure set at 4-5lbs static at idle?
M5
  #3
Old 02-06-2014, 10:24 AM
Currently: Not set.
Basic Member
Garage
Default
fuel pressure at idle is set at 4.5 lbs on the malpassi reg .
I agree with what your saying it seems that the second the turbo spools and the boost spikes everything goes to hell.
Iam pretty confident that all of the plumbing is right but this is what I have..
The malpassi is plumbed to the bottom of the I/C
The back side of the carbs are plumbed with 1/2" lines that are equal length into two fittings in the top of the I/C centered between carbs 1/2 and 3/4
The billet Ts are plumbed from the pilot tube to a T with equal lenght lines to the billet Ts
The pilot tube is not restricted right now . I think I read somewhere about restricting this signal with a 400 main jet . I have a couple of manual boost controllers around I guess i could try to restrict it a little
  #4
Old 02-06-2014, 11:06 AM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
Let's see a picture of how your billet tees are plumbed in. I'm betting that is your problem.
Ken.............
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #5
Old 02-06-2014, 11:14 AM
Currently: Not set.
Basic Member
Garage
Default
I will take a pic and post it when I get home . It is basically set the way Rxrider on TY4 said to set it up
  #6
Old 02-06-2014, 03:30 PM
Currently: Not set.
Basic Member
Garage
Default
this is what iam running
Click image for larger version
  #7
Old 02-06-2014, 08:28 PM
Currently: Not set.
Basic Member
Garage
Default
what do the o rings under the caps do ? What symptoms would someone that was missing ohh i don't know three of them have ? Decided to recheck the basics and found that . We installed the caps the night we had a Irish funeral for my buddies sled , guess we should have done that prior to whiskey lol . please tell me this might be the problem ................i am ordering a set tomorrow .
  #8
Old 02-06-2014, 09:03 PM
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
o rings keep the carbs sealed when under boost,when carbs pressurise.you were more than likely were losing boost pressure out the caps causing the prob you had.
  #9
Old 03-30-2018, 12:08 AM
totu totu is offline
Currently: Not set.
Basic Member
totu is an unknown quantity at this point
Default
Did you sove the problem? I have a similar problem and I have not find a reason for this.
I have o rings in place (old ones)
Ps. I know that this is an old thread :-)
  #10
Old 03-30-2018, 12:23 AM
Currently: Not set.
Basic Member
  #11
Old 03-31-2018, 08:08 AM
Currently: Not set.
Click Here to Register
  #12
Old 04-04-2018, 12:47 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — rx1 front mount turbo help! Thread Starter — trav427 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 12-05-2013 11:40 PM
Thread — 09 800rmk wont rev, acts like a rev limiter at around 7000 rpm Thread Starter — Wheel House Motorsports Forum — Polaris: IQ Replies — 14 Last Post — 12-27-2010 03:39 PM
Thread — RX1 Alpine Front Mount Turbo Thread Starter — shankster Forum — Turbos/Superchargers (Swapmeet) Replies — 1 Last Post — 08-30-2010 08:50 PM
Thread — WTB or trade MCX RX1 rear mount for front mount Thread Starter — MRFUSION Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 01-10-2010 01:25 PM
Thread — looking for a cheap front mount header for rx1 Thread Starter — BigFish BC Forum — Turbos/Superchargers (Swapmeet) Replies — 2 Last Post — 06-08-2009 01:44 PM
no new posts
