Upgrade to Premium
Video Cameras All things Video
Reply
  #1
Old 12-26-2013, 01:40 PM
JSun JSun is offline
Currently: Not set.
JSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond reputeJSun has a reputation beyond repute
Default Hero 3 Advice
Sorry if this has all been discussed in another thread...
My wife just bought me a GoPro Hero 3+ Black for Christmas. A couple questions:
1. How long can I expect the battery to last (record time)? Is it worth it to buy the extra battery pack?
2. What "mode" do you shoot on? There are about 8 different options (it seems like) from 1080p wide to 1080p to oh I don't know... Any suggestions? It will be mounted on my helmet.
Any other advice for using the camera?
Thanks in advance.
Joe
Rate this post: Yes | No
  #2
Old 12-31-2013, 08:56 AM
freak485's Avatar
freak485 freak485 is online now
Currently: waiting on winter
freak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond reputefreak485 has a reputation beyond repute
Default
I am in the same boat got a hero 3 black and wanted to know the same quetions. I did some recording in 1440 or whatever it is the setting above 1080p and its really nice image but dont know if its needed only about 30 min of vid and my 16g mem is full.
__________________
2015 Pro RMK....162 x3, Zbroz 39",silber turbo
2016 crewcab duramax
  #3
Old 12-31-2013, 09:16 AM
TheHardWay's Avatar
TheHardWay TheHardWay is offline
Currently: Kill Mode
TheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond reputeTheHardWay has a reputation beyond repute
Default
I carry a spare battery, especially when out riding, because the cold air affects battery life. And if you use the WiFi remote/smartphone app, even more battery drain.
As for settings, I've been playing around with the different 1080 settings, and haven't quite decided what I like best. I finally got a computer fast enough to process and edit 1080, so now I just need to shoot the video to see what is the best for me.
  #4
Old 12-31-2013, 01:49 PM
freak485's Avatar
Default
i see on gorpos website it says you need a class 10 if you plan on recording in 4k and 2.7k do you still need a class 10 for 1080p or can you get away with a regular?
__________________
  #5
Old 12-31-2013, 03:20 PM
TheHardWay's Avatar
You can use a regular HD type card as far as I know for 1080
  #6
Old 01-01-2014, 12:17 AM
Dartos's Avatar
Dartos Dartos is online now
Currently: Waiting
Dartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond repute
Default
Gizmodo article on GoPro Hero 3
This was taken from the article. It a good read.
The biggest ding against the Hero 3 Black was lousy battery life. GoPro has addressed this by swapping out the 1050mAh (3.885Wh) battery in the Hero 3, for an 1180mAh (4.37Wh) battery in the 3+, and doing some software optimization. We did an independent test, running both cameras at 1080p/24fps. The original Hero 3 Black went one hour and 37 minutes of continuous shooting, and the Hero 3+ Black went two hours and nine, which is a very respectable 25-percent improvement over its predecessor. (GoPro claims a 30-percent improvement. Maybe it depends on the mode you're in.) That's definitely better, but it's still about a half-hour shorter than the first edition of the Sony Action Cam.
__________________
Just so you know, there is no such thing as RPM's - it's just RPM.
  #7
Old 01-03-2014, 02:06 AM
Minten's Avatar
Minten Minten is offline
Currently: Not set.
Minten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond reputeMinten has a reputation beyond repute
Default
I suggest using a UHS-1 card no matter what. I currently have two Sandisk Extreme SDXC cards (http://amzn.to/1dYJXrf). Sandisk DOES have a throttled bitrate and jumps around a bit.
I have yet to do any other testing on memory cards.
Hopefully I can find one that has fast write speeds and the sun comes out so I can get some good bright light testing footage.
  #8
Old 01-03-2014, 08:40 AM
TheHardWay's Avatar
Default
Here are a couple of dedicated Go Pro forums. Lots of info here on the cameras, cards, and anything else related to the Go Pro. I remember reading a thread about a series of tests a guy did on different memory cards, and what worked out best for him.
http://goprouser.freeforums.org
http://www.goproforums.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Hero of the week Thread Starter — allied1 Forum — Fouled Plug Replies — 1 Last Post — 07-19-2013 10:49 PM
Thread — Gopro Hero or Hero 2? Thread Starter — snowman80 Forum — Electronics Replies — 22 Last Post — 10-08-2012 09:06 PM
Thread — new gopro hero 2 Thread Starter — 96j Forum — Photography & Video Replies — 3 Last Post — 01-09-2012 07:33 AM
Thread — Now Geithner's a hero!! Thread Starter — jsledder Forum — Fouled Plug Replies — 2 Last Post — 03-23-2009 02:33 PM
no new posts
