Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 12-26-2013, 02:28 AM
SNWMBL SNWMBL is online now
Currently: Not set.
SNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond repute
Default Lightest drive systems capable of 200+ HP
If you were building a sled from the ground up that was going to make 200-250 HP, which drive system would you use? How light can you get a complete drive system? Is sub 25 lbs for everything reasonable? Is sub 20 lbs possible with lightweight shafts and 7075/Ti. bolts, and a drilled Ti. brake rotor?
I was thinking a Diamond Lite drive with high torque gears, billet cover, lightweight trackshaft & brake rotor, and the caliper from a '12+ M8 if it will fit the Diamond Drive trackshaft (stock M series caliper is heavy). Biggest downside to this is being stuck with a crappy secondary clutch. I had a ZR900 DD in a Rev and liked it aside from the clutch.
What's a complete CMX belt drive weigh with the shafts?
What's an RMI drive weigh? Are these still available?
How about the factory Polaris belt drive? Would the belts live if it was in a stiff tube chassis? Are they failing in the Pro's because of chassis flex?
Or do you forget all the fancy crap and just stick with a bulletproof chain case from an Apex?
Either a gear drive, or belt drive or chaincase with 8" or more C to C would be ideal to run a 3" track and 8-tooth or 9-tooth 3" pitch drivers. 9-tooth would be ideal. I don't want the jackshaft in the tunnel, defeats the whole purpose of having track clearance (IMO).
To sum it up: I built a very light turbo nytro last year, and I'm getting ready to build another from the ground up (mainly just using a Nytro motor, the rest will be fabricated). I want a finished weight under 400 lbs. I have most of the details worked out but I can't for the life of me decide what to do for the drive train. I've been going back and forth for a few months now so I decided to post up.
Rate this post: Yes | No
  #2
Old 12-26-2013, 01:07 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
CMX. i dont remeber the full package weight but its damn light, well layed out and everything you need to get going, and your not stuck with a junk clutch, can be cut for any secondary you want.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
  #3
Old 12-26-2013, 11:44 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Supreme tool machine makes a diamond drive looking chaincase.
Saw it in a different tube chassis build.
Oh its slightly cheaper than the cmx
You should try the 5/8 by .035 wall tube i had good luck bending it with a jd squared model 53 bender with their tightest radius die they sell.
2.125 clr i think.
__________________
Try again
  #4
Old 12-27-2013, 01:48 PM
Reeb's Avatar
Reeb Reeb is online now
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
Default
This is what you need.
Click image for larger version
__________________
NMFH....an enigma wrapped in a riddle.....
Lisa Simpson: Nothing is as fun as snowmobiling looks
Bender: But I can't live without technology.....and snowmobiles.
'94 ZR 700 twin turbo mach z triple with a holly double
pumper and belt drive.......on NAWWWZ!!!
Together We Ride T+D 12-24-07
The Following User Says Thank You to Reeb For This Useful Post:
SNWMBL (12-28-2013)
  #5
Old 12-28-2013, 01:33 PM
Sabaton Sabaton is offline
Currently: Not set.
Sabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant futureSabaton has a brilliant future
Default
Quote:
Could you post som more pics of that sled?
  #6
Old 12-28-2013, 04:12 PM
Reeb's Avatar
Garage
Default
I dont wanna step on Calebs thread but here are a few...
ID:	222281   Click image for larger version
ID:	222282   Click image for larger version
ID:	222284   Click image for larger version
ID:	222285   Click image for larger version
__________________
The Following 5 Users Say Thank You to Reeb For This Useful Post:
2XM3 (12-24-2018), Norway (01-21-2018), SNWMBL (12-28-2013), theultrarider (01-04-2014), Visi (10-29-2018)
  #7
Old 12-28-2013, 08:13 PM
Currently: Not set.
Default
Step on it all you want, it's all good info.
  #8
Old 12-29-2013, 03:24 AM
sportsterdanne sportsterdanne is offline
Currently: Not set.
sportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond reputesportsterdanne has a reputation beyond repute
Default
The downside of the FAST BLADE drive system is that it rotates the track the other way in relation to the secondary clutch.
It works on the BLADE because the Engine is mounted backwards and the clutch rotates the "wrong" way so the track goes the right way.
And change gearing would really be a PITA.
But there is similar drive systems with a short chain instead of gear to gear.
  #9
Old 12-29-2013, 05:46 AM
Currently: Not set.
Default
2.125 clr i think.
The STM case is limited to a 14" wide track.
  #10
Old 12-29-2013, 10:57 AM
Reeb's Avatar
Garage
  #11
Old 12-29-2013, 02:22 PM
Currently: Not set.
Click Here to Register
  #12
Old 12-29-2013, 07:23 PM
Reeb's Avatar
Garage
Idcatman3 (01-15-2018)
  #13
Old 12-30-2013, 09:04 AM
Currently: Not set.
  #14
Old 12-30-2013, 09:28 PM
  #15
Old 12-31-2013, 09:53 AM
Thistledoo's Avatar
Thistledoo Thistledoo is online now
Currently: Bring on the POW!! and dont be shy!!!
Thistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond repute
  #16
Old 12-31-2013, 10:49 AM
Currently: Not set.
  #17
Old 12-31-2013, 07:59 PM
Currently: Not set.
  #18
Old 01-04-2014, 12:47 AM
Reeb's Avatar
Garage
  #19
Old 01-04-2014, 06:05 AM
Currently: Not set.
  #20
Old 01-04-2014, 12:41 PM
Reeb's Avatar
Garage
  #21
Old 01-27-2014, 10:21 PM
Currently: Not set.
  #22
Old 01-27-2014, 11:34 PM
LoudHandle LoudHandle is online now
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
  #23
Old 01-28-2014, 01:43 AM
Currently: Not set.
  #24
Old 01-13-2018, 04:52 PM
Currently: Not set.
  #25
Old 01-13-2018, 07:19 PM
The Following User Says Thank You to LoudHandle For This Useful Post:
unclemark (09-03-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Belt Drive systems Thread Starter — 03 virt edge Forum — Polaris Replies — 2 Last Post — 04-01-2008 09:48 AM
Thread — best track for M1000 w/ 200+ HP Thread Starter — KidWalleye Forum — Mountain/Deep Powder Replies — 3 Last Post — 03-24-2008 03:16 PM
Thread — 200 hp for sale Thread Starter — hurtinalbertin Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 03-19-2008 02:22 PM
Thread — AC Mod 200+ HP Thread Starter — S3 Ent Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 03-12-2008 07:47 AM
no new posts
