Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 12-07-2013, 06:33 PM
stomper stomper is offline
Currently: Not set.
Basic Member
stomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond reputestomper has a reputation beyond repute
Default bog issue while starting off
My sons 91 indy 400 has a bog when starting off from a stand still. Once it gets going it is fine. On take off it won't even spin the track like it used to. I don't drive the sled so I didn't know about it until I took it for a spin the other day. My kid says it has been doing this for awhile now. I just had the clutches apart and for cleaning and noticed it had 10M5 (I think) weights. The manual says stock weights are 10MB. So I changed them hoping that it would make a difference. Both the primary and secondary have the proper stock springs. The belt looks fine and sits up about 1/16 - 1/8" high above the secondary sheaves. I was going to take the cabs off and clean them but thought I would get some opinions first. Does this sound like a carb issue.
Rate this post: Yes | No
  #2
Old 12-07-2013, 07:29 PM
treetopflyer's Avatar
treetopflyer treetopflyer is online now
Currently: lovin boost
treetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond repute
Default
The first place id go would be clutches. The clutches probably have never been serviced. Sounds like you have belt deflection set properly. Check your primary,rollers and weight pins and weights, probably need to be replaced. Primary spring needs to be replaced. The spring sacks out with use and is probably shot. Next check your secondary clutch. Pull it apart and replace wore out or broken spring, also replace the buttons the helix rides on. more than likely they are wore out.
Sometimes if the primary hasn't been serviced your better off replacing the entire cluth, they just plain and simply wear out !!!!!!!!!
Good luck
Tim
  #3
Old 12-07-2013, 07:39 PM
Default
As for a carb issue, that is also possible. Check throttle cables, you need to make sure that the carb slides are pulling up in sync with each other. adjust them at the carbs where the throttle cables go in.
Also check compression on your motor, you may have a cylinder going down or just wore out. should be in the 115-120 pound range.
  #4
Old 12-07-2013, 08:55 PM
Currently: Not set.
Basic Member
Default
I will check these things. When I had the clutches apart for cleaning everything looked fine. As for the springs, I have never replaced them since I got the sled at 2100 miles and the sled has over 8000 miles on it now. I guess that would be a good place to start.
  #5
Old 12-07-2013, 11:32 PM
Default
With that many miles the clutch is probably shot. check the pins that hold the weights for wear, they get grooved and so do the weights in the bushing where the pins slide through. Also the cover bushing wears and binds the clutch. Its the the big bronze bushing in the center of the cover. Look at these areas and see if they need to be addressed.
Don't overlook the secondary clutch it needs to come apart to check the spring and to inspect the buttons. Im sure the buttons are completely gone and and the helix is wearing on the aluminum on the clutch.
  #6
Old 12-12-2013, 08:32 AM
Currently: Not set.
Basic Member
Default
I just bought some new springs for the primary and the secondary. I had the clutches apart for cleaning a couple weeks ago and things actualy looked not bad. The buttons in the secondary looked surprizingly good. I changed weights in the primary to the proper 10MB, it had 10M5. This helped with the performance a bit but not with the bog. I will check compressin and change the springs for starters and continue from there. Thanks for the help.
  #7
Old 12-12-2013, 09:33 AM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
What are you comparing the bog to? These older piston port engines typically have a bog off the bottom versus a reed port engine.
Good luck eliminating as much of the bog as possible.
  #8
Old 12-12-2013, 12:51 PM
Currently: Not set.
Basic Member
Default
I'm comparing to what the sled used to do. It had no problem spinning the track on take off before.
  #9
Old 12-12-2013, 07:29 PM
Currently: Not set.
Basic Member
Default
Compression is 117 on the pto side and 112 on the mag side. Also did some checking on the oem belt. The OEM belt is suposed to be 3211042 and the belt thats on it now is 3211070. According to my research the 3211070 isn't used on anything older than a 97.
  #10
Old 12-13-2013, 01:19 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
  #11
Old 12-14-2013, 06:18 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 12-14-2013, 06:55 PM
Currently: Not set.
  #13
Old 12-15-2013, 03:25 AM
Red River Pig Red River Pig is offline
Currently: Not set.
Basic Member
Red River Pig is an unknown quantity at this point
  #14
Old 12-20-2013, 08:35 AM
Currently: Not set.
Basic Member
  #15
Old 12-24-2013, 12:26 AM
steepndeeper steepndeeper is offline
Currently: Not set.
Basic Member
steepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond reputesteepndeeper has a reputation beyond repute
  #16
Old 12-24-2013, 12:36 AM
Currently: Not set.
Basic Member
  #17
Old 12-24-2013, 12:48 AM
mike_s mike_s is offline
Currently: Progress is fourthcoming!
mike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond reputemike_s has a reputation beyond repute
  #18
Old 12-26-2013, 09:52 PM
firecat99 firecat99 is offline
Currently: Not set.
Basic Member
firecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond repute
Garage
  #19
Old 12-26-2013, 11:01 PM
  #20
Old 12-29-2013, 09:59 AM
Currently: Not set.
Basic Member
  #21
Old 12-29-2013, 10:02 AM
Currently: Not set.
Basic Member
  #22
Old 01-05-2014, 09:14 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Engine Issue/ Starting Thread Starter — duckslayer Forum — Polaris: IQ Replies — 6 Last Post — 01-05-2012 04:50 PM
Thread — 05 900rmk bog of starting line Thread Starter — 900rmk87 Forum — Polaris: 900 Replies — 6 Last Post — 03-16-2011 12:15 PM
Thread — 09 D8 starting/idle bog Thread Starter — dragonwagon Forum — Polaris Replies — 12 Last Post — 03-15-2011 02:53 PM
Thread — need help on starting issue, starts and dies out!! Thread Starter — fredw Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 02-04-2010 01:06 AM
Thread — Starting Issue Thread Starter — boondocker97 Forum — Arctic Cat: M Series Replies — 12 Last Post — 01-31-2010 03:46 PM
no new posts
