Upgrade to Premium
Yamaha: Product Reviews and Installs Reviews and Installs of products made specifically for our Yamaha sleds!
Reply
  #1
Old 12-04-2013, 10:01 PM
judger101 judger101 is offline
Currently: Not set.
judger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond repute
Default Cyclops Optimus LED headlight install
I have been wanting to do a headlight delete with some led or piaa lights behind the vented delete for awhile now and have found a few options, but I did not find exactly what I wanted. I have been looking on the forums and saw that Cyclops leds have good reviews so I purchased a set of 2 round optimus leds from them.
When I opened the box with the leds, I was surprised how stout they were. They have very good weight to them, which I feel is good when it comes to electrical items. The lights came with a wiring harness, sorry I did not take a picture of the harness off of the sled.
Here are the lights. They are a nice plug and play setup with the provided wiring harness.
Like I said the lights come with a harness. Im sure there are many ways to set it up depending how you want to switch them on and off ect. I decided to wire them to my hi beams so that I can shut them off by just dimming the headlights on the stock switch. There are basically 7 ends of the wiring harness you need to worry about as well as the relay. In the picture below you can see where I mounted the relay.
On the right I attached the 3 negative ground wires to the same location. There is 1 wire that you need to run over to the positive battery post and that one has a built in fuse on it. The other positive wire on the harness had a toggle switch on it that I cut off. In the picture below you can see that I zip tied the oem headlight plugins by the coolant bottle and plugged the wire from the relay into one of the "yellow" wires which is the hi beam on the oem harness.
In the next picture you will see the remaining 2 wires connectors which are to plug into the led lights. You will also see the mount that I made for these lights. It is just a piece of aluminum angle iron that I powder coated.
In the next picture you will see that I mounted the lights but also added an little aluminum extension to get the lights further back.
They work!
I have not received the mountain fit vented delete yet so I will post pictures of that and the finished product when I get it.
Hopefully I can get out tomorrow night and try the lights out as we do have a little snow. From my original impression I would highly recommend the Cyclops products, they are not cheap, but I have learned the hard way more than once to buy quality the first time.
Rate this post: Yes | No
The Following User Says Thank You to judger101 For This Useful Post:
m8magicandmystery (12-21-2013)
  #2
Old 12-05-2013, 03:44 PM
culvert culvert is offline
Currently: Not set.
Basic Member
culvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond reputeculvert has a reputation beyond repute
Default
Those are some pretty big lights. What Dia are they? How much did the run you?
I have a set of the PIAA on mine but when using the hand warmers & lights I keep blowing fuses. The PIAA's draw to much power. I'd like to go with a set of LED's
  #3
Old 12-05-2013, 08:02 PM
Currently: Not set.
Default
these are 3.5 inch lights. The set cost me $260.00. They also set some 2 inch round ones as well.
culvert (12-10-2013)
  #4
Old 12-20-2013, 09:19 PM
Currently: Not set.
Default
I would like to do a little update.
I have installed the mountain fit vented headlight delete. I am still happy with the brightness of the lights even though the delete. They work great and I will be posting some night pictures ect. The one negative I have found is that sometimes powder will get in the lights as there is a "ring" around the light and the lens is somewhat indented. snow can pack in and start to build up on the light, well since I have a vented headlight delete it is a pain to take the hood off the clean this off. So far this would be the only negative I have found. this is honestly not the fault of the light, but it has been very cold in my area and things tend to freeze in hurry around the hot engine. I fully endorse the Cyclops led lights and am happy with this mod. I am surprised with the brightness of the led lights. while they are quite expensive, they seem to be very well made and come with the necessary wiring harness to complete the install. I doubt you would find this quality in cheaper made units
on a side note, after I purchased this product I saw that Cyclops offers a 10% discount to snowest customers, I contacted Cyclops and asked for the snowest discount. they said there was nothing they could do for me to reimburse me for the snowest discount as I had already made my purchase. I am not sure why this is, but it was my fault not to do my research before purchase. to anyone looking to buy their products make SURE that you do your research and understand that they will give you a discount if you let them know before you order!
  #5
Old 12-21-2013, 12:20 AM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
I bought the light bar from Cyclops...great guy to deal with..!!!..amazing quality...
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Rigid led light bar install , Help? Thread Starter — husaberg76 Forum — Polaris Replies — 0 Last Post — 11-21-2013 10:51 AM
Thread — NEW PRODUCT: CYCLOPS OPTIMUS LONG-RANGE L.E.D. LIGHTING...OUT-PERFORMS H.I.D. Thread Starter — off road rider Forum — Polaris: Pro-Ride Replies — 27 Last Post — 01-01-2013 07:40 PM
Thread — NEW PRODUCT: CYCLOPS OPTIMUS LONG-RANGE L.E.D. LIGHTING...OUT-PERFORMS H.I.D. Thread Starter — off road rider Forum — General Snowmobiling Replies — 8 Last Post — 12-04-2012 10:09 AM
Thread — CYCLOPS OPTIMUS LONG RANGE L.E.D. LIGHTING SYSTEM...OUT-PERFORMS H.I.D. Thread Starter — off road rider Forum — Cyclops Adventure Sports Replies — 14 Last Post — 12-03-2012 06:23 PM
Thread — Replace headlight with aftermarked LED pods/bar Thread Starter — catothom Forum — Mountain/Deep Powder Replies — 36 Last Post — 11-12-2012 10:23 PM
no new posts
