Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 11-20-2013, 09:16 AM
lost lost is offline
Currently: Not set.
Basic Member
lost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond reputelost has a reputation beyond repute
Default Air compressor for air bags and fill location for air bags
Looking at getting a small inexpensive portable air compressor for my air bags and was wondering what anyone is using and what to stay away from? Don't want to have to mount one permanently as I have not decided exactly where I'm going to run my air lines. Plan is to install the air bags this weekend depending on what the Big Sky Garage decides to do!
Also, where are most of you running your air lines to? See in the directions that they show the lines running back to the rear bumper using the license plate mounts for the fill location. Again, I haven't decided exactly where I want to run my lines for a fill location so any insight would be appreciated.
Thanks in advance.
Rate this post: Yes | No
  #2
Old 11-20-2013, 09:49 AM
SLDHVN's Avatar
SLDHVN SLDHVN is offline
Currently: working
SLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond reputeSLDHVN has a reputation beyond repute
Default
Most trucks have the fill points back on the license plate like you said. I saw where a guy routed them to right inside his fuel door on the side of the gas cap, pretty slick. It really doesn't matter, just wherever you can find that is out of the way and convenient for you to use.
As far as compressors go, just about anything will do. The bags take very little volume to fill up. I think Slime Brand(the fix a flat tire stuff) has a real compact compressor.
__________________
Grip It N' Rip It!
The Following User Says Thank You to SLDHVN For This Useful Post:
lost (11-21-2013)
  #3
Old 11-20-2013, 11:31 AM
line8's Avatar
line8 line8 is online now
Currently: Not set.
line8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond reputeline8 has a reputation beyond repute
Default
I have mine coming out the back, one on each side of the license plate.
The Following User Says Thank You to line8 For This Useful Post:
lost (11-21-2013)
  #4
Old 11-20-2013, 11:35 AM
AZ800 AZ800 is online now
Currently: Not set.
Basic Member
AZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond repute
Default
On my 3rd Gen Dodge there are 2 holes in the back of the bed right above the bumper that work great. They are totally out of the way, no chance of getting busted up, no dirt and mud gets on them.
The Following User Says Thank You to AZ800 For This Useful Post:
lost (11-21-2013)
  #5
Old 11-20-2013, 01:09 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
01 superduty.
I have my lines come in from the top inside fuel door.
There is a lot of space in between inner and outer bed walls.
I sat up in front of the tire and used a regular cordless drill to drill from the top of filler box.
Also I have the firestone air compressor mounted inside of frame rail behind the transfer case and the dual gage with separate switches for right and left bag.
The Following User Says Thank You to summ8rmk For This Useful Post:
lost (11-21-2013)
  #6
Old 11-20-2013, 03:04 PM
winter4ever winter4ever is offline
Currently: Not set.
Basic Member
winter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond reputewinter4ever has a reputation beyond repute
Default
I put an airlift brand compressor on with wireless controller. I did this a little while after I put the bags on so I already had the lines running out the back. It comes with little T fittings so you can just tap it right into you existing lines. The best part about the wireless controller is you dont have to run any lines into your cab. Been on there for probably 4 years with no issues, way better than getting out to fill bags every time!
The Following User Says Thank You to winter4ever For This Useful Post:
lost (11-21-2013)
  #7
Old 11-20-2013, 08:17 PM
AndrettiDog's Avatar
AndrettiDog AndrettiDog is online now
Currently: I know, let's have a spelling contest
AndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond repute
Default
I have a brand new compressor with the same gauge as Summ8RMK for sale. PM me if you are interested. I never used it and ended up going with a wireless setup. It was costly though and I can get you the setup you need with all the lines and wiring included.
The Following User Says Thank You to AndrettiDog For This Useful Post:
lost (11-21-2013)
  #8
Old 11-22-2013, 12:59 AM
skidoo2012 skidoo2012 is offline
Currently: Praying for snow..and blue bird days!!!
skidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond reputeskidoo2012 has a reputation beyond repute
Garage
Default
spend the extra money and get the compressor so you don't have to tote a compressor and its nice to be able to change the amount of PSI right from the cab. Just my .02.
  #9
Old 11-22-2013, 09:50 AM
RCR3 RCR3 is offline
Currently: I AM RASMUSSEN STYLE
RCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond reputeRCR3 has a reputation beyond repute
Default
The old school method is fine just keep an air check with you and adjust and fill as needed at the gas station or where ever you can get air. But compressor mounted is easier! Or try a portable compressor that you clip to your battery!
  #10
Old 11-24-2013, 07:04 PM
Mitch P.'s Avatar
Mitch P. Mitch P. is offline
Currently: Not set.
Mitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond reputeMitch P. has a reputation beyond repute
  #11
Old 11-27-2013, 09:39 AM
Blk88GT's Avatar
Blk88GT Blk88GT is offline
Currently: Patiently waiting for my '19
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
Click Here to Register
  #12
Old 12-08-2013, 09:01 PM
Bocephus Bocephus is offline
Currently: Rye whisky Rye whisky Rye whisky I cry
Bocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond reputeBocephus has a reputation beyond repute
  #13
Old 12-08-2013, 11:45 PM
summ8rmk's Avatar
Bocephus (12-09-2013)
  #14
Old 12-08-2013, 11:54 PM
  #15
Old 12-09-2013, 12:10 AM
summ8rmk's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Air bags Thread Starter — Powderboy Forum — Trucks and Trailers Replies — 25 Last Post — 11-13-2012 11:19 AM
Thread — Firestone wireless air command for air bags - installed and love it Thread Starter — Bocephus Forum — Trucks and Trailers Replies — 8 Last Post — 12-31-2011 01:09 PM
Thread — air bags for a truck Thread Starter — catman 1200 Forum — Trucks and Trailers Replies — 13 Last Post — 12-09-2010 10:13 AM
Thread — F/S Industrial Air Compressor with Dry Air Purge - Boise Thread Starter — idpwdagrl Forum — Tools/Shop Items (Swapmeet) Replies — 3 Last Post — 04-15-2009 05:04 PM
Thread — GMC Cold air intake and Air ride Bags Thread Starter — Firecatab Forum — Truck/Truck Accessories (Swapmeet) Replies — 0 Last Post — 10-21-2008 11:02 AM
no new posts
