Upgrade to Premium
Reply
  #1
Old 11-04-2013, 11:52 PM
tpollon2 tpollon2 is offline
Currently: Recovering from shoulder surgery
tpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond reputetpollon2 has a reputation beyond repute
Default Buy earthX Batteries
Superclamp is selling earthX sled batteries.
405 CC
3.5 lbs
$349.95
2 warranty
https://www.superclamp-orders.net/su...country=canada
Click image for larger version
Rate this post: Yes | No
  #2
Old 03-13-2014, 08:55 AM
chicago chicago is offline
Currently: Not set.
Basic Member
chicago is an unknown quantity at this point
Default EarthX
I put one in my 2012 PRO800, started having engine cut out,after 250 miles pulled a code 651 indicating injector issue. I put the OEM battery back in after 60 miles no issues. I think this battery goes into discharge and reduces voltage, I'm going to try the EarthX again to see if issue returns.
The Following User Says Thank You to chicago For This Useful Post:
freeflorider (03-17-2014)
  #3
Old 03-17-2014, 11:54 AM
freeflorider freeflorider is offline
Currently: Thinking summer has ended
freeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond reputefreeflorider has a reputation beyond repute
Default Power issues
Quote:
Good post, like to know if your right. Cuts down on weight but if it cycles into a low charge that kills your ride then it a bad thing.
  #4
Old 09-10-2014, 07:31 PM
TJ427 TJ427 is offline
Currently: Not set.
TJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond repute
Default
Resurrecting thread... Would be interested in responses also.
  #5
Old 09-10-2014, 07:50 PM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default
Here is a good general review of Lithium batteries.
I plan on installing another one in my new Viper this fall.
//www.snowest.com/forum/showthread.php?t=284250
__________________
  #6
Old 09-10-2014, 07:51 PM
Garage
Default
Quote:
http://www.superclamp.net/site/earthx.asp
Donít buy or sell a lithium battery without a BMS (Battery Management System)! EarthX has patent pending technology that makes it the most advanced lithium battery; the highest cranking amp cells (405 CCA (Cold Cranking Amps)); and the only one with a built-in BMS (Battery Management System) for performance, safety and longevity! This is not an upgrade or optional feature but a REQUIREMENT for a lithium battery to operate correctly! Donít be fooled if someone says if you have quality cells you donít need a BMS, that is absolutely not true!
Switch from a
LEAD ACID BATTERY
...to an
Lithium
Weight: 15 lbs Weight 3.5 lbs
Power: CCA: 310 AH: 20 Power: CCA: 405 AH: 36
Freezes Will Not Freeze
Long Charging Time Fast Charge (Less than 2 hrs.)
Special Mounting Required Mount Any Direction
Life Span: 3 yrs Life Span 8 Years
Warranty: 6 months Warranty 2 Years
Hazardous Waste Environmentally Friendly
__________________
  #7
Old 09-10-2014, 07:52 PM
Garage
Default
__________________
  #8
Old 09-13-2014, 12:37 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Battery management is HUGE for any Li battery to last.
The "kiss of death" for any Lithium tech. battery is if you exceed more than 50% discharge on the battery... the LVCO (low voltage cut off) feature will save the battery.
I'm game for the little "baby" EXT6A battery ($129.00) for a project I'm working on... Just ordered it!
I've been holding off on buying a Li battery till I saw the BMS on the EarthX.
http://earthxmotorsports.com/shop/etx6a/
__________________
Signature:
  #9
Old 10-21-2014, 08:53 AM
Norona Norona is offline
Currently: Not set.
Norona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond reputeNorona has a reputation beyond repute
Default
These earths batteries work period. I have been using them for 2 years in all my sleds, 2 will go into my T3's this year and I have one in a Beta 250RR a KTM 200 and a KTM 300 and a snow bike, zero issues , and they all have sat through a season and work perfectly without charging them up... great company as well!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — earthX batteries Thread Starter — tpollon2 Forum — General Snowmobiling Replies — 0 Last Post — 11-04-2013 11:43 PM
Thread — Dead batteries Thread Starter — mud99 Forum — Polaris: Pro-Ride Replies — 5 Last Post — 10-14-2013 10:42 PM
Thread — Antigravity Batteries Thread Starter — SnoConeKing Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 01-06-2013 02:54 AM
Thread — Batteries Thread Starter — bendelow Forum — GPS enabled devices Replies — 13 Last Post — 12-14-2010 12:54 PM
Thread — Optima Batteries Thread Starter — Anti-Hero Forum — Fouled Plug Replies — 11 Last Post — 11-01-2009 06:58 PM
no new posts
