Upgrade to Premium
User Product Reviews Honest product reviews by sledders for sledders.
Reply
  #1
Old 10-19-2013, 01:40 AM
RoffRider RoffRider is offline
Currently: Not set.
Basic Member
RoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond reputeRoffRider has a reputation beyond repute
Default My Experience With JB Weld High Heat
on my 4 wheeler there are 2 cracks on the header pipe, one on the top, and one on the bottom, both are about 7 inches long and are about 1 mm thick
so i decided to get some jb weld highheat
the first time i used it...i did a crap job, no cleaning, no sand paper, and dry hands(makes for miserable mixing and applying), and i didnt let it cure for long, maybe 2 hours, and the bottom half fell off with in 1 mile, the top half(much much more jb weld was used) turned black and baked
the 2nd time however, i cleaned the pipe good, filed it, and heated it up with a lighter, used wet hands(otherwise it will only stick to your fingers), pressed it hard onto the pipe, did a great job putting it on, let it cure for 1 day...and tried it out, it lasted much much longer, didnt turn black, but it still ended up cracking and half of it falling off on the bottom, and on the top all of it fell off
to be fair these only cost like 8 bucks, my idle jet was far too lean to get good egt's, the crack is only about 4 inches from the exhaust flange so its roasting hot, is exposed to lots of rattling and vibrations, and goes through rapid tempature changes from driving through water
would i recomend it? yes, it is worth a shot
info on it here JB Weld High Heat
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — JB Weld on Bulk Head?? Yay or Nay Thread Starter — 987 Forum — Arctic Cat: M Series Replies — 16 Last Post — 02-06-2013 10:34 PM
Thread — Will PC stick to JB Weld Thread Starter — Nikolai Forum — General Snowmobiling Replies — 3 Last Post — 05-25-2009 07:59 PM
Thread — JB Weld a crankcase? Thread Starter — 95RXL Forum — General Snowmobiling Replies — 18 Last Post — 03-04-2009 09:04 AM
Thread — JB Weld on Aluminum ? Thread Starter — RideGuy Forum — Fouled Plug Replies — 4 Last Post — 02-17-2009 07:28 PM
Thread — 08 XP Crankshaft, Will JB weld work Thread Starter — Ramjet15x Forum — Mountain/Deep Powder Replies — 34 Last Post — 03-18-2008 07:44 AM
no new posts
