Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 04-23-2013, 08:41 PM
mx100 mx100 is offline
Currently: Loving the XP chassis!!
mx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond reputemx100 has a reputation beyond repute
Default Do these pictures tell you why this motor seized?
I think I was riding my XP on borrowed time. I was ripping up the trail to the Deep snow, and I came to a quick stop. Sled has 3700 hard mountain miles on stock bottom end, and 1300 miles on the dual ring SPI pistons. Lost the PTO piston.
PTO plug, newer than the mag plug.
Click image for larger version
MAG plugClick image for larger version
Head, left is PTOClick image for larger version
This is the top of the cylinders before pulling them off the case.Click image for larger version
Top of piston stuck in the top of the cylinderClick image for larger version
Just pulled the cylinders off the cases, and this is what I found!Click image for larger version
The Pto rod bearing is locked up solid, and also took out the cases. I just did the oil delete, and made it maybe 4 miles. I added enough oil in the fuel tank for 10.6 gals at 32:1, then topped off the tank. I am not sure, but I think it was just time for a rebuild. Did I miss something? If you have a different opinion, please give your 2 cents.
I am looking for cases, (prefer used for the price). I think I will need a new monoblock, the gouges look deep. I am planning on a new, trued crank, and haven't decided what I am doing with the top end yet. I would love to do a big block, but the PURE pressure to do a Turbo is OVERWHELMING!!! Does anybody have any advice on where to get parts? New and Used. Thanks.
Rate this post: Yes | No
  #2
Old 04-23-2013, 09:12 PM
avycital avycital is offline
Currently: Not set.
Basic Member
avycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond reputeavycital has a reputation beyond repute
Default
Call BJ at sled head racing 6127183861
Tell him what you need he has it all
  #3
Old 04-23-2013, 09:23 PM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
Where is the rest of the porcelain from the PTO spark plug? Was that the cause or the effect?
__________________
ALASKA
  #4
Modoutlawkart Modoutlawkart is offline
Currently: Looking to go faster
Basic Member
Modoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond reputeModoutlawkart has a reputation beyond repute
Default
Rings were wore snaged exhaust port bad things happened
  #5
Old 04-23-2013, 09:47 PM
rndy67 rndy67 is offline
Currently: Not set.
rndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond reputerndy67 has a reputation beyond repute
Default
X2 big John will have used cases and all the parts you need. His work and customer service is the best around.
  #6
Old 04-23-2013, 09:55 PM
Default
Quote:
The little piece of porcelain was laying on top of the piston when I took the head off. I am guessing it was the effect.
  #7
Old 04-24-2013, 11:11 AM
tukernater tukernater is offline
Currently: Waiting on more snow
tukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond repute
Default
I beleave Dave has a great deal on trued cranks and cases his price was so close to used cases I would go new.
The Following User Says Thank You to tukernater For This Useful Post:
Mach-ster (04-24-2013)
  #8
Old 04-24-2013, 07:24 PM
frog frog is offline
Currently: Speaking words of true wisdom
frog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond reputefrog has a reputation beyond repute
Default
You added oil to the fuel in the tank but what about the fuel in the fuel lines, fuel pump and carbs?
  #9
Old 04-24-2013, 07:51 PM
Mach-ster Mach-ster is offline
Currently: Premium member
Mach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond reputeMach-ster has a reputation beyond repute
Default
Give Dave a call he's got plenty of new cases and anything else your going to need. As for the oil delete....I'd hook it back up with the new case as lack of oil will make em go real quick!! there is reasoning behind that and Dave can fill you in as to why.
  #10
Old 04-24-2013, 09:15 PM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
  #11
Old 04-24-2013, 09:36 PM
RKT RKT is offline
Currently: The "turd"is now a"Tomato"
RKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond reputeRKT has a reputation beyond repute
Click Here to Register
  #12
Old 04-24-2013, 10:36 PM
joshkoltes's Avatar
joshkoltes joshkoltes is offline
Currently: TOO MANY PROJECTS!
joshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond repute
Garage
  #13
Old 04-24-2013, 10:49 PM
Red-eye Red-eye is offline
Currently: is Ready to RIDE!!!
Red-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond repute
  #14
Old 04-25-2013, 07:35 AM
Danzick Danzick is offline
Currently: Not set.
Basic Member
Danzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond repute
Garage
  #15
Old 04-25-2013, 09:35 AM
  #16
Old 04-25-2013, 06:46 PM
  #17
Old 04-25-2013, 07:11 PM
  #18
Old 04-25-2013, 10:01 PM
  #19
Old 04-25-2013, 10:05 PM
  #20
Old 04-26-2013, 08:51 AM
  #21
Old 04-26-2013, 09:12 AM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #22
Old 04-26-2013, 10:46 AM
  #23
Old 04-26-2013, 11:40 AM
  #24
Old 04-26-2013, 01:14 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
  #25
Old 04-26-2013, 10:38 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Free Ride Down!!! (Seized motor) salute to ski doo Thread Starter — Dock Forum — Ski-Doo: XP Sleds Replies — 27 Last Post — 04-15-2011 07:52 PM
Thread — Need pictures - 08-10 800 motor issues Thread Starter — sled_guy Forum — Polaris: IQ Replies — 9 Last Post — 04-02-2011 08:39 AM
Thread — Seized the motor in my Turbo M8 Thread Starter — DOOMAN Forum — Arctic Cat: TURBO Replies — 14 Last Post — 01-03-2011 06:47 PM
Thread — seized motor question 06 800 Thread Starter — ak ryda Forum — Ski-Doo: REV Sleds Replies — 3 Last Post — 01-11-2010 07:21 AM
Thread — Help,seized? Thread Starter — Kootenay-Stomper Forum — Polaris Replies — 3 Last Post — 05-04-2008 04:26 PM
no new posts
