Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 02-17-2013, 05:12 PM
fasta76's Avatar
fasta76 fasta76 is offline
Currently: No Drugs, No Bottle, Just Balls And Throttle!!!
fasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond reputefasta76 has a reputation beyond repute
Default Set Screw issues
For what ever reason i cannot get my set screws in my MTX weights to hold? They keep backing out. I have even tried red lock-tight? I have tried new ones three time and even tried new pins with no luck! Any ideas?
Rate this post: Yes | No
  #2
Old 02-17-2013, 05:30 PM
Frostbite's Avatar
Frostbite Frostbite is online now
Currently: Dreaming of riding in deep, deep powder!
Frostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond reputeFrostbite has a reputation beyond repute
Default
I drilled the holes in the bolts that hold the weights just a hair deeper. It worked for quite a while until one of the bolts snapped right at the hole at about 6,000 RPM. I have replaced all the bolts and set screws. I didn't look to see if the setscrews held after my last ride. I sure hope so.
__________________
The Original Frostbite
The Following User Says Thank You to Frostbite For This Useful Post:
fasta76 (02-17-2013)
  #3
Old 02-17-2013, 06:10 PM
fasta76's Avatar
Default
I've also been doing that with the last two sets of pins. But they still wont hold! And i've seen them hold but start to cut the pin like you had happen.
  #4
Old 02-17-2013, 06:17 PM
markd7 markd7 is offline
Currently: premium Member
Basic Member
markd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond reputemarkd7 has a reputation beyond repute
Default
Try and clean the hole out real good and screw. Then spray some either on both and blow dry with air. Might have to heat them the next time to get them out. Either really cleans it good. Use it all the time on the farm. Mark
The Following User Says Thank You to markd7 For This Useful Post:
  #5
Old 02-17-2013, 06:32 PM
fasta76's Avatar
Default
Ive done that also! I dont know what the hell is wrong with them! I have to heat them to remove them and re-set them! But the wiggle loose when i ride!
  #6
Old 02-17-2013, 08:17 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
hmmm...ether has a top end lubricant...i would use brake clean or acetone for cleaning..
but if locktite is failing ya why not try a silcone coating on the threads and/ or drag the threads with a hard steel to roll the threads over abit...
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
The Following User Says Thank You to m8magicandmystery For This Useful Post:
  #7
Old 02-17-2013, 08:27 PM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
Your weights must be shot then ,evidently the threads are completely shot. If your cleaning the threads and using red lock tite and its just coming loose they have to be shot or your clutch is getting so hot the weights are heating up and releasing the locktite. Just get different weight problem solved.
__________________
M 1000 modded but no turbo no way Uh well maybe
The Following User Says Thank You to Hardass For This Useful Post:
fasta76 (02-18-2013)
  #8
Old 02-17-2013, 09:04 PM
Stack's Avatar
Stack Stack is online now
Currently: Ready for the Snow!
Stack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond reputeStack has a reputation beyond repute
Default
You can try the set screws with the knurled cup that grips a little better along with possibly using the green loctite, 620 I believe. It is very important to burn off or clean off all the old loctite and residue before assembling. Also important to properly cure the loctite, I believe minimum 3 hrs at 60 degrees, but that's for red. Check the TDS to be sure
Stack
The Following User Says Thank You to Stack For This Useful Post:
  #9
Old 02-18-2013, 12:27 AM
Frostbite's Avatar
Default
Interesting topic. I will have to take a look at mine tomorrow.
__________________
  #10
Old 02-18-2013, 12:34 AM
sunbather1969 sunbather1969 is offline
Currently: patiently waiting
Basic Member
sunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond reputesunbather1969 has a reputation beyond repute
Garage
  #11
Old 02-18-2013, 08:22 AM
Arctic Thunder Arctic Thunder is offline
Currently: Not set.
Arctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond repute
Click Here to Register
The Following 2 Users Say Thank You to Arctic Thunder For This Useful Post:
fasta76 (02-18-2013), madsledder (02-27-2013)
  #12
Old 02-18-2013, 10:15 AM
Frostbite's Avatar
  #13
Old 02-18-2013, 06:32 PM
BigAir's Avatar
BigAir BigAir is offline
Currently: Still missin' the old SnoWest
BigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond repute
The Following User Says Thank You to BigAir For This Useful Post:
  #14
Old 02-18-2013, 06:52 PM
fasta76's Avatar
  #15
Old 02-19-2013, 02:32 PM
05M7 05M7 is offline
Currently: Not set.
05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute
Garage
  #16
Old 02-19-2013, 02:38 PM
TheBreeze's Avatar
TheBreeze TheBreeze is online now
Currently: 850 down!
TheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond repute
The Following User Says Thank You to TheBreeze For This Useful Post:
fasta76 (02-19-2013)
  #17
Old 02-19-2013, 07:47 PM
Frostbite's Avatar
  #18
Old 02-20-2013, 12:59 AM
Basic Member
Garage
  #19
Old 02-20-2013, 09:30 PM
Polarisrocks's Avatar
Polarisrocks Polarisrocks is offline
Currently: Enjoying the cool summer
Polarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond reputePolarisrocks has a reputation beyond repute
The Following User Says Thank You to Polarisrocks For This Useful Post:
fasta76 (02-20-2013)
  #20
Old 02-22-2013, 10:49 PM
XxXModRods XxXModRods is offline
Currently: Not set.
XxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond reputeXxXModRods has a reputation beyond repute
  #21
Old 02-24-2013, 07:25 PM
Frostbite's Avatar
  #22
Old 02-24-2013, 09:09 PM
  #23
Old 02-25-2013, 07:34 PM
Tonysnoo's Avatar
Tonysnoo Tonysnoo is offline
Currently: Not set.
Tonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond repute
  #24
Old 02-25-2013, 08:22 PM
Frostbite's Avatar
  #25
Old 02-27-2013, 06:14 PM
Flatcat12's Avatar
Flatcat12 Flatcat12 is offline
Currently: Not set.
Flatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond reputeFlatcat12 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — stripped out set screw Thread Starter — WFOWA Forum — Arctic Cat: M Series Replies — 13 Last Post — 12-14-2012 11:43 AM
Thread — Set screw in fixed weights?? Thread Starter — Hardass Forum — Arctic Cat: M Series Replies — 7 Last Post — 03-30-2012 05:06 PM
Thread — AC 70# light tip set screw have a set of 4 Thread Starter — dmkhnr Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 12-04-2009 11:32 AM
Thread — secondary set screw M7 Thread Starter — dgreet77 Forum — Arctic Cat: M Series Replies — 5 Last Post — 10-05-2009 06:02 PM
Thread — Tuning set screw clutch vs. non set screw Thread Starter — kidrman Forum — Arctic Cat Replies — 0 Last Post — 10-31-2008 08:02 AM
no new posts
