Upgrade to Premium
Reply
  #1
Old 02-04-2013, 10:51 PM
65pony123 65pony123 is offline
Currently: 2012 polaris assault, pro suspensin
65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute65pony123 has a reputation beyond repute
Garage
Default tracker 2 light on when turned off?
when i turn it off the indicator light on the side still flashes red same as it does when it is on? why?
Rate this post: Yes | No
  #2
Old 02-05-2013, 08:11 AM
SnowBigDeal's Avatar
SnowBigDeal SnowBigDeal is offline
Currently: Deploying Avalanche Airbags!
SnoWest Paid Sponsor
SnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond reputeSnowBigDeal has a reputation beyond repute
Garage
Default
I can't say I've seen this in particular. But I have seen some of the T2's drain their battery when they are turned off.
Do you know if your battery is getting drained? If so, BCA will warranty the beacon. If you need help, feel free to give us a call 1-877-766-9244
__________________
THE AVALANCHE AIRBAG EXPERTS
Avalanche Airbags
Avalanche Beacons
509 Helmets & Goggles
Snowmobile Clothing
1-877-SNOW-BIG (1-877-766-9244)
  #3
Old 02-05-2013, 11:10 AM
cateye5312 cateye5312 is offline
Currently: Not set.
Basic Member
cateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond reputecateye5312 has a reputation beyond repute
Default Try this first
Take the batteries out and then re-install them. Mine was doing that when I put the batteries in the first time. After thinking about it for a bit, I tried taking the batteries out and putting them back in, kinda like I've had to do to my cell phone to get it unscrambled once in awhile. It worked fine after that. Then I took it outside and tested it to make sure it was functioning properly. I found my wife's beacon no problem.
Also, after shutting it off, turn it back on, write down the percent of battery remaining, shut it back off, wait a day, turn it back on and see if the percentage changed. Then you will know the problem has been resolved.
  #4
Old 02-05-2013, 03:02 PM
Garage
Default did
took the batteris out and put them back in still doing it and also yes it is using the battery. was 86 yesterday now its 80 today
  #5
Old 02-05-2013, 05:26 PM
Chris6060's Avatar
Chris6060 Chris6060 is offline
Currently: Wishing my femur would heal.
Chris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond reputeChris6060 has a reputation beyond repute
Garage
Default
I'd call BCA if I were you. See what they say.
How do you check the battery percentages on these things?
__________________
2012 Arctic Cat M800 Retro w/ All the decals removed
SLP Can, 156" x 2.5" Challenger Extreme, 2013 Skid Drop, BDX Anti-Stab, SLP Powder Pros, 19/50 gearing, 2014 Secondary & 2014 updates, Elka Stage 5 front shocks
  #6
Old 04-20-2013, 12:11 AM
800tech 800tech is offline
Currently: hello there!
Basic Member
800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute800tech has a reputation beyond repute
Default
When you turn it on IMMEDIATELY look at the window for it to flash the battery % number. It only flashes it for less than 2 seconds. So I usually am looking at the window when I turn it on. Ya gotta be quick!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ORIGINAL BCA tracker vs tracker 2? Thread Starter — rhalloran Forum — Avalanche Beacons Replies — 1 Last Post — 08-06-2012 09:09 AM
Thread — Anyone turned their rails up? Thread Starter — Teth-Air Forum — Ski-Doo Replies — 6 Last Post — 08-05-2008 08:17 AM
Thread — Just turned over 4000KM Thread Starter — RGM Forum — Ski-Doo Replies — 2 Last Post — 03-09-2008 10:08 PM
no new posts
