Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 01-01-2013, 06:16 PM
attatoy attatoy is offline
Currently: Not set.
attatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond reputeattatoy has a reputation beyond repute
Garage
Default ski doo Zx Rmk seat mod
I have seen it done on here and on the net so i felt i could tackle it , Got er done this after noon and all i can say is wow. So much better then the stock couch and just makes the sled feel alot more sporty. I got the seat for 120 can of a 2010 assault, and i bought a small sheet of aluminum to make a seat pan for easier mounting. That was 35 and then i just scrounged some old handle bars for the front mount and the rear is stock with a 1/4 piece of cutting board that i shapped to land on the bend in the seat pan. After that i just drilled a bunch of screw holes for the seat to mount to the pan and used marine adhesive(sikiflex) to make sure she holds. I did take a heat gun the pan to shape it to fit tighter against the stock tank and then did some trimming with the grinder as well. turned out much better then i was hoping for and lastly i need to make a filler for the front out of some realy thin light plastic, just gotta find the right material.
Rate this post: Yes | No
The Following User Says Thank You to attatoy For This Useful Post:
Norway (01-08-2013)
  #2
Old 01-08-2013, 11:28 AM
21doo440x 21doo440x is offline
Currently: Not set.
Basic Member
21doo440x is an unknown quantity at this point
Default
pretty cool, seat mods are one of the best things you can do with these older chasis. heres my 02 440.
Click image for larger version
  #3
Old 01-08-2013, 12:38 PM
Currently: Not set.
Garage
Default
I deffinatly agree, I mover my steering post forward an inch too and it is a totaly different beast now, you cut up a stock seat? The hieght was the best part about this seat
  #4
Old 01-08-2013, 01:46 PM
Currently: Not set.
Basic Member
Default
I did the rear end of the seat but had an upholster snip the top section off the old seat cover, add foam and re-sow a new top to the old seat cover. quite an experiment lol. worked out though.
  #5
Old 01-25-2013, 02:36 PM
Twostroke Twostroke is offline
Currently: an iqr junkie
Basic Member
Twostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond reputeTwostroke has a reputation beyond repute
Garage
Default
Quote:
How did you go about moving the post?
  #6
Old 01-25-2013, 08:59 PM
Currently: Not set.
Garage
Default
I stole the idea from a guy on here that did the summit 700 mod sled build on you tube, basically you just add spacers to steering head block to move it forward , I added an inch
  #7
Old 01-28-2013, 04:00 PM
03summit700 03summit700 is offline
Currently: Time to ride!!
03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute03summit700 has a reputation beyond repute
Default
I just used a peice of 1" square tube. Works great.
Name:	2013-01-27 12.20.22.jpg
__________________
03 Summit 800 Himark 151"
4" RSI Riser, Boss Seat, Simmons Skis, Boyesen RAD Valves
03 Summit 700 Himark 151"
4" Oles Riser, Boss Seat, Boyesen RAD Valves, 18/48
  #8
Old 04-05-2017, 12:51 PM
chuckychoadcheese chuckychoadcheese is offline
Currently: Not set.
Basic Member
chuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond reputechuckychoadcheese has a reputation beyond repute
Default
Been modding the wives sled.
*SPG seat
*PowerMadd pivot riser and 6" riser block
*SPG Willard Bend handlebars
*fly racing kill switch
*ODI 8" grips
*skidoo hand warmers and cork insulation
*Mo-Pros tunnel rack and snowboard carry
*vent kit
*straightline ice scratcher
*Removed all factory stickers and have it ready for a Choad Cheese Wrap.
ID:	283557   Click image for larger version
ID:	283558   Click image for larger version
ID:	283560   Click image for larger version
ID:	283561   Click image for larger version
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — BOSS SEAT ZX SKI DOO Thread Starter — jed800 Forum — Seats (Swapmeet) Replies — 2 Last Post — 12-29-2010 02:43 AM
Thread — 01 ZX ski-doo mod roller Thread Starter — tricktech Forum — Chassis/Tunnel (Swapmeet) Replies — 6 Last Post — 02-02-2009 10:15 PM
Thread — Ski-Doo ZX Seat Thread Starter — SpiderHelix Forum — Seats (Swapmeet) Replies — 6 Last Post — 02-22-2008 09:57 PM
Thread — Need To Sell 01 ZX ski-doo mod sled Thread Starter — Mountain Sled Shop Forum — Ski-Doo (Swapmeet) Replies — 3 Last Post — 12-17-2007 09:17 PM
Thread — 02 ski doo zx seat Thread Starter — summit700151 Forum — Seats (Swapmeet) Replies — 2 Last Post — 12-06-2007 09:24 PM
no new posts
