#1
I've got a buddy who just bought a 05 mxz renegade 600 with only 300 miles on it and completely stock. He's trying to make it into a better powder machine without spending a whole bunch of money. Any suggestions? It seems like the first place to start would be to cut out the sway bar, loosen the limiter strap, and tighten the front track shock, but i don't know much about revs, so i really don't know.
#2
Hello, Loose the swaybar, set skis to inside position, Maybe taller Bar risers, Longer taller lug track more floatation less getting stuck go more places. for a deeper snow sled or powder sled Snow Eliminators is a must on a moutain machine, less snow on the boards more free movement of your feet rather than shovin the snow around.
Could be many other mods but these will be most noticed from the start. Good Luck, Wildcard
__________________
Polaris Pro RMK 2014 800 163x2.5 Tether Zbros 36in Frontend Walker Evans Revalved Dual Rate Front Springs Super Q Can Koso dual window EGT Guage Lifter Fly Next Level Handlebars Skinz Next Level Windshield bag Skinz Headlight Delete Muffpot Underhood Goggle/ Glove bag 2 Cool footwell Vents Burandt Running Boards VEI Rear Tunnel Brace Burandt Handlebars Burandt Tunnel Bag W/ Axys Twist Lock tie downs Arctix Fx wrapped tunnel Aluminum Rear Bumper Powder Jack on Tunnel |
#3
Thanks for the tips, he's got the bigger track already so the big ones done so to speak. It seems like he's got to much ski pressure but I know that messing with the track suspension can make it into a real bad trencher as well. I suppose trial and error will be the way of the day but if anyones got some tips on that we'd appreciate it.
#4
Economical clutch improvements
Removing the black 160/300 secondary spring and installing a purple 225/300 secondary spring (414978300) from a rev 800 summit or XP 231/300 secondary spring (417127062) would be a great calibration change to contribute to better clutching for the newly applied track.
__________________
Really good G4-850 and XM summit clutch kits 850 G4 Summit clutch kit index Online Gear Calculator @ iBackshift Last edited by Dynamo^Joe; 12-31-2012 at 09:30 AM. |
#5
![]() Quote:
x2, clutchin can be huge improvement in any sled and this guy Knows how to put down the power. gotta be the best performace change that can be done. Wildcard
__________________
#6
Feels like it is clutched fine, so I guess now I'm looking for suspension setup info. Anybody?
#7
Does the front arm on the rear skid have a twist know to adjust the front limiter strap or is it the type you have to change move the bolt from hole to hole?
Having the knob is the easiest way to adjust while out riding, with the sled setting on a flat surface feel the slack on the limiter strap if its tight loosed the knob till it has some slack in it and try that. If its tight now don`t go really sloppy loose you want to make some minor adjustment at first to much and suspension won`t like it. This will allow the front end to come up more on the throttle and make it get up on the snow easier and handle better in deeper snow. Try this on the rear skid first if it makin the back of the sled squat to much on the throttle and not trying to lift the front end up or out of the snow then move the rear of skid spring adjustment up a notch. Loosening the limiter strap will take away the front ski pressure and will sometimes depending on snow conditions make the front try to push thru the corners when on the throttle but sometimes you have to give up trail manners to get more moutain sled characteristics. You have to play with it a little at a time and tune it to your liking and not to many big changes. What size track has the sled gone too? is it a longer skid change along with track or have rail extensions from what I would imagine the 121 MXZ skid? What skis does the sled have? Good Luck, Wildcard
__________________
#8
stock 136'' skid with a 2'' challenger. I think because it's a renegade it had the 136'' skid from stock setup. It has the stock trail skis. Apart from its complete lack of flickability it seems to get round ok, but it would be nice to get it lay over easier.
#9
Find someone parting out a summit and buy the front end if its like mine it has a 46" front end way to much ski pressure I put on summit a arms and shocks off an XP better boards and can move the steering post forward with a 440 race seat its a fun sled now needs a longer track but its on a budget
#11
![]() Click Here to Register |
#12
#13
The Following User Says Thank You to LRD For This Useful Post: | ||
Mainaa (03-02-2018) |
#14
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — 2008 Ski Doo 800R Rev XP MXZ/Renagade 137" NICE | Thread Starter — tskgyfz450 | Forum — Ski-Doo (Swapmeet) | Replies — 7 | Last Post — 12-18-2012 09:48 AM |
Thread — 06 mxz renagade | Thread Starter — redrazor | Forum — Ski-Doo: REV Sleds | Replies — 2 | Last Post — 12-12-2012 12:21 PM |
Thread — FOR SALE **2004 MXZ Renagade 600 HO sdi** | Thread Starter — SNOW 365 | Forum — Ski-Doo (Swapmeet) | Replies — 0 | Last Post — 02-15-2012 12:14 PM |
Thread — Long tracking a 2007 mxz renagade 800 | Thread Starter — bud_1080 | Forum — Ski-Doo: REV Sleds | Replies — 2 | Last Post — 12-13-2009 04:39 AM |
Thread — Need renagade mountain setup 8-10 ft. | Thread Starter — TABLEROCK | Forum — Ski-Doo | Replies — 6 | Last Post — 01-10-2009 07:52 AM |
