Upgrade to Premium
Reply
  #1
Old 12-21-2012, 12:18 AM
SaberKitty's Avatar
SaberKitty SaberKitty is offline
Currently: Waiting for the new 800 engine...
SaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond repute
Default Service Bulletin BS201312 - Slide Rail End Caps 2013 Ms
Thought you guys on the 4-stroke side of the world would like to see this as well....
Service Bulletin
Date: December 19, 2012
Product Line: Snowmobile
Bulletin No: BS201312
Subject: Slide Rail End Caps
Affected Models: 2013 M8, M 1100 Turbo, and M 1100 non-Turbo
NOTE: Refer to Cat Tracker Online to obtain the list of affected VIN’s from your inventory by selecting the “Service” tab, then the “Bulletin Display” tab. Specific criteria is required to be selected. Example: Bulletin Type-All, Product Type-SNOW, Bulletin Number BS201312 and Bulletin Year 2013.
Condition: The slide rail end caps do not meet Arctic Cat standards on the affected models only and should be replaced.
Solution: Install new Slide Rail End Cap Update Kit (p/n 0637-420). Instructions will be included in the kit.
Parts: Order an appropriate number of Slide Rail End Cap Update Kits (p/n 0637-420) through normal parts-ordering channels. Your dealership Parts Account will be billed and then credited upon receipt of a Warranty Claim Request.
Warranty: A labor allowance of 0.2 hr will be paid per affected snowmobile.
 NOTE: It is required to enter the current mileage of each affected model.
! ATTENTION
To ensure that the necessary service work is completed in a timely manner and that this issue can be resolved, Arctic Cat is requesting that all service work be completed prior to December 19, 2013. All warranty claims directly related to this issue will not be honored after December 19, 2013, without prior approval.
__________________
2013 M800 Sno Pro Limited Black 153 w/o ES
2012 M800 Sno Pro 153 Vader makeover
And a retired pair of sequential serial number 2008 M8 Nightfire Sno Pros
Black - It's the new green
Away from internet riding for
Rate this post: Yes | No
  #2
Old 12-21-2012, 03:51 PM
Empire087 Empire087 is offline
Currently: rx-0 SKS 146
Basic Member
Empire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond reputeEmpire087 has a reputation beyond repute
Default
Are they failing?
  #3
Old 12-21-2012, 05:52 PM
SaberKitty's Avatar
Default
With the new 2013 skid mount location, there's a greater risk of the rails stabbing the track.
__________________
  #4
Old 12-23-2012, 02:50 PM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Been installing a lot of anti stab kits on sleds. Had a customer stab a track last year. It's something you never want to have happen, world comes to a violent stop.
__________________
19’ Alpha 800 turbo
18, MC 153 stock
18’ axys 155 stock
18' axis 163 stock
  #5
Old 12-26-2012, 12:09 PM
powerstroke 350,700 powerstroke 350,700 is offline
Currently: Looking to get more HP!
powerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond reputepowerstroke 350,700 has a reputation beyond repute
Default
DO NOT PUT 4 WHEEL ANTI STAB KIT ON A PROCLIMB!!!!!!!!
IT HAS TO BE TWO WHEELED KIT!
I found out the hard way!!!!!!!!
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 01-09-2013, 09:53 AM
fishtrapper fishtrapper is offline
Currently: Not set.
Basic Member
fishtrapper is an unknown quantity at this point
Default RAIL END CAPS
WENT CROSS COUNTRY RIDING LAST WEEKEND AND HAD TO GET SLED PICKED UP WITH TRUCK. LOST BOTH RAIL END CAPS ON 2013 M1100 LTD 162 BLACK RAILS PROCLIMB. WORE OUT BOTH RAIL ENDS AND HYFAX SLIPPED OUT INTO TRACK WINDOW. DID NOT DAMAGE TRACK BUT NEED 2 NEW RAILS, HYFAX, HYFAX BOLTS AND END CAPS. END CAPS AND RAILS NOT AVAILABLE STOCK FROM A/C. ONE WOULD THINK THAT IF THE END CAPS ARE NOT UP TO STANDARD THAT THEY WOULD HAVE REVISED ONES AVAILABLE? RIDING CONDITION WAS RIDING IN ABOUT 2FT OF SNOW IN OPEN FIELD COUNTRY THAT WAS WIND BLOWN DRIFTS. SUSPECT THAT THE IMPACT OF WIND BLOWN DRIFTS HITTING FRONT OF TRACK BROKE OFF END RAIL CAPS.
  #7
Old 01-09-2013, 06:31 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is online now
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Found out that the rail caps are on Backorder.....
S/C
  #8
Old 01-09-2013, 07:23 PM
freddy freddy is offline
Currently: Anticipating
freddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond reputefreddy has a reputation beyond repute
Default
Buy yourself a BDX anti-stab kit - comes with new rail caps - and you'll never have problems again.
__________________
'13 M1100T 162" Ltd.
EVO BRV, Cold air intake, Intercooler fan, turbo and header blankets, 2.5" TD down pipe and can, ballistic battery, ROV, CPC adj. weights. 8" Slydogs.
  #9
Old 01-09-2013, 07:37 PM
mmsports's Avatar
mmsports mmsports is offline
Currently: 208-852-0400
mmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond reputemmsports has a reputation beyond repute
Garage
Default anti stab kits
Yes keep them in stock just for that reason. Just be glad your not buying a new track.
__________________
Hubs Performance Shop
If you're tired of your sled not running 100%
come see me or I can come see you to do a tune clinic in your neck of the woods. I will take the time to get you on the snow.
Check out our Web site for deals on bmp cans
208-852-0400
http://hubsperformance.com/home
  #10
Old 01-09-2013, 07:51 PM
wasatchcomm wasatchcomm is offline
Currently: bye bye snow, its dirt for me
wasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond reputewasatchcomm has a reputation beyond repute
Default
Are the bdx anti stab kit 2 or 4 wheel kits?
the last bd anti stab kit i had was a bdx and it was a 4 wheel kit....
why is a 4 wheel kit bad?
  #11
Old 01-09-2013, 07:57 PM
Click Here to Register
  #12
Old 01-22-2013, 06:58 AM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Service Bulletin BS201312 - Slide Rail End Caps 2013 Ms Thread Starter — SaberKitty Forum — Arctic Cat: Proclimb M Replies — 53 Last Post — 03-22-2013 02:23 PM
Thread — 2013 Polaris Service Bulletin!! Thread Starter — ksmity21 Forum — Polaris: Pro-Ride Replies — 10 Last Post — 11-14-2012 01:17 AM
Thread — service bulletin for torque of the nut??? Thread Starter — samiams2 Forum — Arctic Cat: Proclimb M Replies — 12 Last Post — 02-09-2012 09:13 PM
Thread — Cat Service bulletin Thread Starter — hd4rob Forum — Arctic Cat: Proclimb M Replies — 68 Last Post — 01-01-2012 08:45 PM
Thread — service bulletin Thread Starter — brmk Forum — Polaris Replies — 5 Last Post — 01-26-2009 10:31 PM
no new posts
