Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 12-19-2012, 07:49 PM
kyle28 kyle28 is offline
Currently: Braaaaaaaaap!
kyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond reputekyle28 has a reputation beyond repute
Unhappy high idle problem
Im having a high idle problem on my 2004 rev it has rk tek drop ins, computer remap and porting. it stays in the 4k range and will only go down if i flip up the choke. this happens when the sled is cold and hot but mostly when its hot. i have tried ajusting the idle screw, cable, and turning the air/fuel skrew on each carb out half a turn to richen it up with no luck. also there is no air leaks any ideas on how to fix this?
Rate this post: Yes | No
  #2
Old 12-19-2012, 09:51 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
Default
Well if you're sure there are no vacuum leaks, richen up the pilot circuit. What size PJ you running? When did this problem appear? after any mods?
  #3
Old 12-20-2012, 07:52 AM
NEWDUCK NEWDUCK is offline
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default
Ive had this problem on an 07 800. Cleaned the dpm and it went away. Worth a shot if youve done everything else.
  #4
Old 12-20-2012, 08:13 AM
Danzick Danzick is offline
Currently: Not set.
Basic Member
Danzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond repute
Garage
Default
wore out carb slides? my sled has a horrible hanging idle and its because my carb slides are totally shot and i can actually hear them rattling while it idles.
  #5
Old 12-20-2012, 08:14 AM
Default
nope it was like this when i bought it and im not sure what pilot jet im running. how do you find out is there a number on it? should i get the next size up on the pilot or try another half a turn on the air/fuel skrew?
and ill try cleaning the dpm out friday. would that just be cheching the lines and cleaning out the black tube thing?
sorry for all the questions just want to figure this out
  #6
Old 12-20-2012, 08:16 AM
Default
ill check the slides out also.
  #7
Old 12-20-2012, 08:43 AM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default
The stock pilot jet is 17.5 & will be stamped on the side of the pilot jet. I would check with RK tec & see if changing it was required for his modifications. I would also make sure it's not plugged, you should be able to see through it. If you can't see through it, spray some carb cleaner through it until it's clear. Also spray carb cleaner up through the hole where the pilot jet goes & make sure it sprays through the two small holes into the carburator bore.
  #8
Old 12-20-2012, 04:43 PM
Default
ok so still no luck! ive cleaned carbs,jets,dpm,lines, ect, ive checked the carb slides and al is good there. i also turned the air/fuel screws out another half turn with no luck. there is no air leaks anywhere or anything. what else could this be?
  #9
Old 12-20-2012, 05:14 PM
Default
ok just talked to rk-tek and they sayed to put in some 20 pilet jets and that will solve my problem
  #10
Old 12-20-2012, 10:55 PM
gman086 gman086 is offline
Currently: Killing IT!
gman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond repute
  #11
Old 12-21-2012, 09:26 AM
BackCountryBob BackCountryBob is offline
Currently: Hit the HAPPY BUTTON and RIDE
BackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond reputeBackCountryBob has a reputation beyond repute
Click Here to Register
  #12
Old 12-21-2012, 09:59 PM
  #13
Old 12-22-2012, 07:54 PM
Currently: Not set.
Basic Member
Garage
  #14
Old 12-23-2012, 08:57 AM
  #15
Old 12-23-2012, 05:26 PM
Currently: Not set.
Basic Member
Garage
  #16
Old 12-23-2012, 10:46 PM
Sawking Sawking is offline
Currently: Not set.
Sawking is an unknown quantity at this point
  #17
Old 12-24-2012, 09:22 AM
millertime4060 millertime4060 is offline
Currently: Not set.
Basic Member
millertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond reputemillertime4060 has a reputation beyond repute
Garage
  #18
Old 12-24-2012, 01:06 PM
Concrete Mike Concrete Mike is offline
Currently: Waiting for snow,hope the sled don't blow
Concrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant futureConcrete Mike has a brilliant future
  #19
Old 01-02-2013, 06:02 PM
  #20
Old 01-02-2013, 11:24 PM
  #21
Old 01-03-2013, 10:24 AM
BBP BBP is offline
Currently: Not set.
Basic Member
  #22
Old 01-03-2013, 07:38 PM
  #23
Old 01-03-2013, 07:41 PM
Red-eye Red-eye is offline
Currently: is Ready to RIDE!!!
Red-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond reputeRed-eye has a reputation beyond repute
  #24
Old 01-23-2017, 11:47 PM
Jaysummit Jaysummit is offline
Currently: Not set.
Basic Member
Jaysummit is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — High idle Thread Starter — jimjim Forum — Polaris: IQ Replies — 6 Last Post — 11-19-2012 10:23 AM
Thread — High idle then low idle, and no reverse Thread Starter — Whiz-bang Forum — Polaris: Pro-Ride Replies — 11 Last Post — 01-23-2012 10:51 PM
Thread — idle problem Thread Starter — veeder Forum — Polaris: GEN 2 Replies — 4 Last Post — 02-16-2011 08:40 PM
Thread — high idle Thread Starter — reegs Forum — Ski-Doo: XP Sleds Replies — 2 Last Post — 04-12-2010 08:22 PM
Thread — idle problem Thread Starter — veeder Forum — Polaris: EDGE Replies — 8 Last Post — 01-19-2010 01:38 PM
no new posts
