Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-10-2012, 05:24 PM
stevepolaris stevepolaris is offline
Currently: Not set.
stevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond reputestevepolaris has a reputation beyond repute
Default Free or Cheap Mods
thought id bring this over here was on dootalk.. This will be for Free/ cheap Mods only, let's keep it under $50 Let's try to have pic's with them also. Maybe add the benefit of the mod also
here are some already
Pull out all the foam when it gets wet and freezes it gets heavy
by:rocks rev
post forward, pretty well known mod, supposedly helps carve and sidehill easier (I haven't ridden it this way yet).
The picture shows the holes in the back, where the rear mounts of the post used to go. Simply take the bolts out push the post forward, put one of the bolts back in, drill out the front hole, second bolt in and you're good to go.
Total cost-$0
Go to 1st pic
(since I have giant feet) is to cut the panels open for more foot room, it doesn't move you more forward, but it certainly helps get your feet in/out/etc. After being "hooked in" the stirrup and getting my foot broke on my first REV, this seems to help a lot.
See 2-3
Printing some graph paper online and carefully laying it out on your panels and drilling a 5/64" grid pattern is good for some cheap/easy/free venting too.
See 4-5
i took a piece of masking tape and masked from the snow flap mount to the drop bracket and trimmed my tunnel to have a nice even rise instead of the weird stock style, and i cut my running boards and raised them up.
see 6-7
the switch relocate. i used a buzzer button from ace for the reverse and toggle switches for the hand warmers and lights
see 8
go to home depot and ask for some "pet screen". i did a headlight delete and use a small fog light from oriely's, and replaced the stock metal screens with the pet screen. i used hot glue and its pretty strong actually.
see 9-10
next is the 2 wheel kit! free if you have a tap set. these are not my instructions, i found them off of another site
cut the axle to 8 7/8"
cut the spacer to 4 1/4"
tap the axle with the correct metric threads, or use a 3/8 course SAE it works ok.
Take the plastic piece off the clutch cover, trim the tabs off, and put some holes in it.... Let that thing stay cool....
see 11
Click image for larger version
ID:	182616   Click image for larger version
ID:	182617   Click image for larger version
ID:	182619   Click image for larger version
ID:	182620   Click image for larger version
ID:	182622   Click image for larger version
ID:	182623   Click image for larger version
ID:	182625   Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 8 Users Say Thank You to stevepolaris For This Useful Post:
Aalexander (11-05-2016), BIG JOHN (05-18-2017), dsdyreng (10-30-2013), powderman800 (10-10-2012), rocks rev (10-10-2012), sledguy71 (04-14-2013), sledsrock (10-12-2012), wildcard28 (11-17-2012)
  #2
Old 10-10-2012, 05:25 PM
Currently: Not set.
Default
Sway bar removal & stiffen up front springs (if it fits your riding style), removal of track clips (clipped every other/every third) small ports in ctr of track (1") clips & porting usually good for 3.5-4lbs on a 151 track. Spending some time to set-up clutching & suspension for YOUR riding style/ weight
The Following User Says Thank You to stevepolaris For This Useful Post:
  #3
Old 10-10-2012, 05:27 PM
Currently: Not set.
Default
ski brake... just get a old belt and cut it
  #4
Old 10-10-2012, 10:06 PM
wildcard28's Avatar
wildcard28 wildcard28 is offline
Currently: Thinkin Snow! Bought APro Rmk Love this Sled
wildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond reputewildcard28 has a reputation beyond repute
Garage
Default
Did the same thing, I seen my buddy climb a nasty steep hillside last year in crusty spring snow and he actually was more nervous having to come down it rather than up and brakes did not work so he twisted the extra belt up and looped it over the skis and I was amazed on how he creeped back down litteraly had to stay on the throttle a bit to come all the way down, he usually carried one of these under the hood but just before this ride that day he took it out,
anyway the next week I went home found an old belt clip and an old belt and made this and mounted it to the tunnel
Real cool mod and works great.
this litteraly only took about 15minutes including mounting the clip to the tunnel.
Wildcard
__________________
Polaris Pro RMK
2014 800
163x2.5
Tether
Zbros 36in Frontend
Walker Evans Revalved
Dual Rate Front Springs
Super Q Can
Koso dual window EGT
Guage Lifter
Fly Next Level Handlebars
Skinz Next Level Windshield bag
Skinz Headlight Delete
Muffpot
Underhood Goggle/ Glove bag
2 Cool footwell Vents
Burandt Running Boards
VEI Rear Tunnel Brace
Burandt Handlebars
Burandt Tunnel Bag W/
Axys Twist Lock tie downs
Arctix Fx wrapped tunnel
Aluminum Rear Bumper
Powder Jack on Tunnel
  #5
Old 10-10-2012, 10:42 PM
powderman800 powderman800 is offline
Currently: wishing it would snow.
powderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond reputepowderman800 has a reputation beyond repute
Default Air Box Delete
Mod: The two piece REV air box is giant. Delete it; two pre-filters on the carbs works fine.
Benefit: Air flow improved & weight loss & lots more under hood space.
Price: approx. $50 (for 2 filters)
Alternative: I like the Timbersled intake. Its about $250. Great product IMO.
Mod: REV gauge clusters have a gauge blank. SLP makes a Flo-Rite for it.
Benefit: More airflow
Price: $36 from SLP
Alternative: BRTech makes a sweet hood pod with headlight delete & intake. Spendy.
Mod: Windshield removal. I F^CKING HATE WINDSHIELDS!!!!!!!!!!!
Benefit: Don't look like a tool & don't bust $80 pieces of plastic on the first twig that touchs it!
Price: FREE
Alternative: Some windshields are okay, but if you keep your stocker you look like a tool or an old dude.
  #6
Old 10-10-2012, 11:29 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
Wildcard
a loop of winch cable on each ski..(1/4 inch 10 in diameter) works really well and can be rolled up
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
  #7
Old 10-11-2012, 06:09 AM
bwylde bwylde is offline
Currently: Not set.
bwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond reputebwylde has a reputation beyond repute
Garage
Default
a couple of leather dog collars work pretty well too, and you can stash them just about anywhere.
  #8
Old 10-11-2012, 02:59 PM
gman086 gman086 is offline
Currently: Killing IT!
gman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond repute
Default
I've done more mods than most (as those that know me on Dootalk can attest) and the one that is BY FAR the best free/low cost mod you can do on a Doo is my track cut:
http://www.snowestonline.com/forum/s...98#post2732998
Will transform your sled into a more agile beast yet still retain deep snow floatation!
Have FUN!
G MAN
The Following User Says Thank You to gman086 For This Useful Post:
rocks rev (10-11-2012)
  #9
Old 10-11-2012, 08:43 PM
wildcard28's Avatar
Garage
Default
Have FUN!
G MAN
Hello G Man, How many sleds have you done this too and noticed the difference from before and after you modded the track?
I`m not doubting you in any way I have done alot of mods I have seen you do and suggest to others and happy with everyone, I am going to put a 163x16x2.5 XP track or one like it on my Rev which is getting a chassis swap that has a VE Drop and Roll and a few other mods to it so I can go bigger lug..
I am going to do you mod to that track. just curious to you answer to my question.
Also for the XP tracks out there, which one do you recommend is the better one or year to have? thats not the overported one.
Thanks, Wildcard
__________________
Polaris Pro RMK
2014 800
163x2.5
Tether
Zbros 36in Frontend
Super Q Can
Guage Lifter
Muffpot
Burandt Handlebars
  #10
Old 10-11-2012, 09:29 PM
snowboatboy snowboatboy is offline
Currently: IT'S SNOWING
snowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond reputesnowboatboy has a reputation beyond repute
  #11
Old 10-11-2012, 11:22 PM
wildcard28's Avatar
Garage
Click Here to Register
  #12
Old 10-11-2012, 11:24 PM
The Following User Says Thank You to m8magicandmystery For This Useful Post:
stevepolaris (10-15-2012)
  #13
Old 10-12-2012, 08:24 PM
  #14
Old 10-13-2012, 12:33 AM
wildcard28's Avatar
Garage
  #15
Old 10-13-2012, 12:08 PM
Currently: Not set.
  #16
Old 10-15-2012, 06:39 AM
skidoo_guy skidoo_guy is offline
Currently: That's what you get!
skidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond reputeskidoo_guy has a reputation beyond repute
Garage
  #17
Old 10-16-2012, 01:39 PM
wildcard28's Avatar
Garage
  #18
Old 10-26-2012, 06:44 PM
rocks rev's Avatar
rocks rev rocks rev is offline
Currently: Need Snow!!!!!!
rocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond reputerocks rev has a reputation beyond repute
The Following User Says Thank You to rocks rev For This Useful Post:
  #19
Old 10-26-2012, 09:01 PM
wildcard28's Avatar
Garage
  #20
Old 11-11-2012, 06:26 PM
kevinm7's Avatar
kevinm7 kevinm7 is offline
Currently: is tired of the heat already!!
kevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond reputekevinm7 has a reputation beyond repute
  #21
Old 11-12-2012, 07:20 PM
Wyorever's Avatar
Wyorever Wyorever is offline
Currently: Come on winter!!!
Wyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond reputeWyorever has a reputation beyond repute
  #22
Old 11-12-2012, 09:16 PM
kevinm7's Avatar
  #23
Old 11-16-2012, 07:12 PM
kevinm7's Avatar
  #24
Old 12-17-2012, 09:08 PM
monster967 monster967 is offline
Currently: Not set.
monster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond reputemonster967 has a reputation beyond repute
  #25
Old 12-18-2012, 12:26 AM
rocks rev's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Cheap/free mods for the m series sleds Thread Starter — Empire087 Forum — Arctic Cat: M Series Replies — 38 Last Post — 12-05-2012 02:41 PM
Thread — cheap/free mods Thread Starter — RMK4life Forum — Polaris: GEN 2 Replies — 13 Last Post — 11-10-2009 10:49 PM
Thread — Cheap mods.. Thread Starter — sledordie Forum — Ski-Doo: XP Sleds Replies — 20 Last Post — 11-07-2009 11:07 PM
Thread — Free DIY Mods Thread Starter — ScubaSteveSK Forum — General Snowmobiling Replies — 23 Last Post — 10-06-2008 11:38 PM
Thread — Cheap mods 4 apex. Thread Starter — pgsledder Forum — Yamaha Replies — 1 Last Post — 01-18-2008 12:48 AM
