Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 04-02-2012, 06:49 PM
glaciermonkey glaciermonkey is offline
Currently: Not set.
glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey glaciermonkey
Default 09 m8 reverse grind noise, dd inspection question
hi,
on my last ride in heavy wet powder my diamond drive or something from the lower left side made a crunchy grinding noise in reverse so i got the sled on flat hard pack area and tested reverse again to see if the noise was still there. it happened again so i road back to the truck, gently, and had no problems.
now i have the dd apart but i'm not sure if i'm seeing anything to worry about. no metal, i drained the oil(valvoline synthetic gear oil 75/90) through a clean rag and i don't see any metal. the oil was dirty but not bad looking. 1000 miles on sled, separated and cleaned dd at 550 miles, 6203 looks good but i have the 5203 to go in this time
here is my questions and i have some pics to help
*are the marks on the brass shims of the planetary very bad? they all look and feel in good shape other than the stains or burns on the right side of the pic, no wear marks.
*how do i inspect the movement of the planetary gears? i assume some is normal, up down, diagonal, but not side to side?
*for the second pic, the gear on the left of the cover, not the one the clutch mounts too, i can tip that gear side to side a bit, if i press on it i can see it getting closer to the cover kind of movement. bad or normal?
thanks for reading all this and any good info
Click image for larger version
ID:	173204   Click image for larger version
Rate this post: Yes | No
  #2
Old 04-02-2012, 07:01 PM
Woody67's Avatar
Woody67 Woody67 is offline
Currently: Digging the Alpha One
Woody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond repute
Garage
Default
dd looks good...other than the transfer gear bearing they don't go bad very often on stock sleds. If you have too much belt deflection your noises could be coming from your clutches. It will be more prone to slip in reverse. May not be it but something to check.
__________________
Woody
Store:360-676-4096
Cell: 360-255-3381
stevewoodward@mtbakermoto.com
www.mtbakermoto.com
  #3
Old 04-02-2012, 09:41 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
R u running a stock helix or do u have a torsional setup?
  #4
Old 04-02-2012, 09:48 PM
Currently: Not set.
Default
Quote:
it's the stock 44/40. why?
  #5
Old 04-02-2012, 10:26 PM
summ8rmk's Avatar
Default
The torsional setup grinds real bad if the dogs don't catch the groove and spread the sheaves open letting the belt slip and no reverse.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to summ8rmk For This Useful Post:
Wrenchmaster (03-12-2018), summ8rmk (03-12-2018)
  #6
Old 03-12-2018, 09:30 AM
Wrenchmaster's Avatar
Wrenchmaster Wrenchmaster is offline
Currently: working when I should be riding
Wrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond repute
Default
I know this us a super old thread, I have this problem with my '09 M8T CPC stage II kit and Dalton secondary setup, grinds and bogs in reverse, makes a horrible noise, I know it's not my DD because I put a BDX high torque setup in it and lightweight axl, it measured up good for clearances too. Has anyone found a fix for this probelm? mine will reverse but makes a ton of noise, then will bog out and stop moving, very annoying
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — '10 M8 reverse grinding noise? Thread Starter — AkHockey10 Forum — Arctic Cat: M Series Replies — 16 Last Post — 04-01-2018 11:35 PM
Thread — amount and kind of dd oil for 2008 m8 w/reverse Thread Starter — amberm8 Forum — Arctic Cat: M Series Replies — 1 Last Post — 10-28-2010 08:35 PM
Thread — 08 M8 reverse noise/grind? Thread Starter — M8 Megatron Forum — Arctic Cat: M Series Replies — 8 Last Post — 02-23-2010 07:40 PM
Thread — 07 m8 dd stuck in reverse Thread Starter — snobyrd Forum — Arctic Cat: M Series Replies — 2 Last Post — 12-20-2009 05:11 PM
Thread — 08 M8&M1000 DD with shaft,drivers and reverse actuator Thread Starter — 1100Cat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 3 Last Post — 03-29-2009 11:09 PM
no new posts
