Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 02-09-2012, 09:42 AM
salmonbum salmonbum is online now
Currently: Trying to find a good duck hunting hole
Basic Member
salmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond reputesalmonbum has a reputation beyond repute
Default New QRS Shim Kit to help with Belt Blowing XP"s
If you are blowing belts on your XP Chassis Snowmobile, there is a good chance your clutches are not aligned, even though they will be in tolerance to BRP's measurements. Most have found by moving out the secondary 1.5 to 3.0mm will solve this problem. Since the QRS clutch is married to the shaft, you need to shim both the clutch side bearing and the gear side of the shaft. My kit comes with two 1.5mm large shims for the bearing hosing (clutch side) and two 1.5mm smaller shims for the gear side of shaft, all precision cut out of 304 stainless steel. This gives you two choices to shim, either 1.5 or 3mm, depending on your situation. I do not recommend going over 3.0mm due to it would be pushing the bearing out of the tower too much. If you need more than 3mm you have a more serious problem and need to look into motor mounts mods or a complete floating secondary, which is expensive.
Installation is simple with the use of basic hand tools.
I have personally did extensive testing since 2009 with many different belts and clutch set-up. I’ve sold many kits and have had only positive feedback that this inexpensive kit save others hundreds on belts.
Below are some pics and instructions to review(small shims for bearing retainer not shown)
If anyone have used my kits, please feel free to post any feedback to let others know how it worked out for you.
See swapmeet link here: http://www.snowestonline.com/forum/s...94#post2979094
Click image for larger version
Name:	Shim in Tower_sm.jpg
ID:	166651   Click image for larger version
Name:	Shim on ShaftSM.jpg
ID:	166652   Click image for larger version
Rate this post: Yes | No
  #2
Old 10-30-2012, 04:12 AM
Basic Member
Default
This is a bump for the 2012-2013 Season
  #3
Old 10-30-2012, 08:23 PM
ShredTheRev ShredTheRev is offline
Currently: ready to ride
Basic Member
ShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond reputeShredTheRev has a reputation beyond repute
Default
are people doing these shim kits as a preventative thing before belts blow, or are they doing it if clutch alignment checks out as terrible??? I just bought an 08 roller and will be putting my motor in soon and who knows if its a good one or bad one for alignment, may be buying your kit, good price!
  #4
Old 10-07-2015, 07:08 AM
Basic Member
Default
These kits will being stock next week for the upcoming season. Since 3mm is the magic number, I know sell them in a solid 3mm shim.
  #5
Old 10-30-2017, 07:29 AM
Basic Member
Default
Just to let all know, I have them in stock and ready to ship!
The Following User Says Thank You to salmonbum For This Useful Post:
WILDBILL01 (11-23-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Salmonbum's XP QRS Shim Kits Thread Starter — salmonbum Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 02-09-2012 09:38 AM
Thread — QRS Shim Kit Thread Starter — jrt574 Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 10-09-2011 08:08 AM
Thread — need a shim kit for my qrs secondary. Thread Starter — redbull660 Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 10-07-2010 08:03 PM
Thread — Qrs Shim Kit Thread Starter — Randog Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 01-06-2010 04:52 PM
Thread — QRS shim kit Thread Starter — blkangus Forum — Ski-Doo: XP Sleds Replies — 4 Last Post — 10-25-2009 09:52 AM
no new posts
