Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 01-01-2012, 09:51 AM
duckslayer duckslayer is offline
Currently: Not set.
duckslayer is an unknown quantity at this point
Default Engine Issue/ Starting
Ok so i figured i might find someone on here who has run across this issue before.
I have an 08 700 CFI Dragon, Oil tank was 2/3 full in the fall, sled has sat except for a couple of start up to load/unload when moving it into garage to work on it. oil tank is now down near empty and if the sled sits for more than a week it takes a lot of pulls to start and then smokes like crazy for a 5-10 minutes after start up.
is there a possibility that check valves on case are stuck open allowing oil to feed into motor?
when i pulled my pipe this fall to do some work i had a decent amount of oil drain out from Y pipe.
Anyone had similar issue or know how to fix/check??
Rate this post: Yes | No
  #2
Old 01-01-2012, 10:09 AM
Kraven's Avatar
Kraven Kraven is online now
Currently: 2013 PRO- R 800 w/3,500 TROUBLE - FREE MILES
Kraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond reputeKraven has a reputation beyond repute
Cool
The "gravity feed" from that oil tank is not going to force the oil past the oil pump into the engine.
Smoke on start-up and oil in the pipe (within reason) is common.
If you're absolutely positively certain, certain, certain, for sure, for sure, you've "lost oil" over time, I'd look into the belly pan, under sled, soaked into trailer plywood, etc.......
Try marking the outside of the oil tank oil level with a magic marker, or fill it to the top.
Regarding the hard starting, pump out all the "old fuel", re-fill with fresh fuel and new spark plugs, and don't touch the throttle on start-up. Should start on the 2nd pull, EVERY time. After that, stator beginning to possibly fail?????????
Hope this helps
__________________
2008 POLARIS PINK DRAGON 120 DELIVERED BY SANTA TO MY 3 1/2 YEAR OLD DAUGHTER ON CHRISTMAS DAY 2007
2007 DRAGON 700 PC-3, V-FORCE 3, AIR HORN + FLO-RITES, PUSH ARM, 4400 MILES+
2002 EDGE-X 800 SNO-CHECKED, 6400+ MILES
1999 XCR 800 SNO-CHECKED
1998 XC 700 SNO-CHECKED
1996 800 STORM SNO-CHECKED 1993 750 STORM
BYRON,IL '84
  #3
Old 01-01-2012, 07:44 PM
Currently: Not set.
Default
There is def no oil leaking from the sled onto floor, bellypan etc. the oil has gone from the tank to somewhere, and i figured its into the engine. last time she sat for a month and it took over 50 pulls and a set of new plugs to get her to finally turn over, and then smoke more than any sled ive seen. ran fine after starting up and burning off excess oil. sat for another month and now i cant get her to turn over at all, ive got 1/4 tank of gas... new gas no so maybe thats an issue
  #4
Old 01-02-2012, 09:40 AM
Currently: Not set.
Default
TTT
  #5
Old 01-03-2012, 07:36 AM
Currently: Not set.
Default
UPDATE>>>>
checked for leaking oil under belly pan and everywhere else...nothing. pulled plugs and they were wet dried them off and smelled inside plug holes and the motor smelled like heavy oil. put plugs back in and she started on third pull. Ran the engine for 15 minutes and after the first ten the amount of smoke decreased and she was considerably more snappy on throttle response. shut her down and noticed that under the exhaust on trailer floor was a heavy amount of burnt oil residue, much more than normal.
talked to the previous owner and he said he had added oil to fuel mixture last fall to fog motor and store....
interested to hear what anyone thinks
  #6
Old 01-05-2012, 10:25 AM
Currently: Not set.
Default
So i go out today, three days after she was started and ran for 20 minutes....and nothing i have zero burp or turnover after 20 pulls!
im at a loss and have run out of ideas....HELP!
  #7
Old 01-05-2012, 04:50 PM
tdorval's Avatar
tdorval tdorval is offline
Currently: Not set.
tdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond reputetdorval has a reputation beyond repute
Default
When you get back lets drain the gas, and put some fresh in and go from there. The oil situation does baffle me as well, we need to see what happens to it from now until you're back. That gas is old stuff though and could be causing the hard starts.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Diagnosing Starting Issue - '07 BD TM8 Thread Starter — DeepInTheTrees Forum — Arctic Cat: TURBO Replies — 24 Last Post — 03-25-2011 12:20 AM
Thread — 2010 renegade etec 600 starting issue Thread Starter — rmk700rules Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 11-29-2010 12:28 PM
Thread — Starting/key assembly issue. Thread Starter — Wheel House Motorsports Forum — Yamaha: 4-Stroke Replies — 3 Last Post — 10-12-2010 07:13 PM
Thread — need help on starting issue, starts and dies out!! Thread Starter — fredw Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 02-04-2010 01:06 AM
Thread — Starting Issue Thread Starter — boondocker97 Forum — Arctic Cat: M Series Replies — 12 Last Post — 01-31-2010 03:46 PM
no new posts
