Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 09-04-2011, 06:46 PM
AkHockey10 AkHockey10 is offline
Currently: Healing up...
AkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond reputeAkHockey10 has a reputation beyond repute
Garage
Default '10 M8 reverse grinding noise?
Whoa....haven't been on here in a while! Anyway...
Have a grinding noise only in reverse when getting on throttle. Took DD a part and that's not it. Next thought would be something wrong with primary? Secondary had been checked out back in Feb but may as well look at it also. Anyone have an idea??
Also, sled also slams HARD into gear going forward and in reverse. Sitting at idle I slowly give it throttle and it revs up and nothing happens then bam it goes into gear. It will jolt forward and backward and will throw you off the sled if not read for it. Crazy!
Rate this post: Yes | No
  #2
Old 09-04-2011, 07:04 PM
ACMtnCat ACMtnCat is offline
Currently: Hold'n on to Black Metal!
ACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond reputeACMtnCat has a reputation beyond repute
Default
your grinding noise is likely the drive shaft bearing it the brake caliper. Take the caliper off, youll have to get both bearings out to check them. The inside one is held in by a C clip. Tap the first one out then youll see the C clip that needs to be removed.
The harsh engagement is likely two things. The belt to sheave gap is one. The other is a combination of weights being too tight and not swinging free enough and the spindle bushings hanging up or worn out. A good primary clutch cleaning and making sure the weights are just right and swing easy will help a lot! But you may need to adjust belt to sheave gap to cure the slam your feeling.
  #3
Old 09-04-2011, 08:10 PM
diggerdown diggerdown is offline
Currently: Not set.
diggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond reputediggerdown has a reputation beyond repute
Default
Primary could be the cause of both problems. Depends on what you consider a grinding noise. You can also get vibes in reverse from the end of the hyfax.
  #4
Old 09-04-2011, 09:53 PM
bushy's Avatar
bushy bushy is offline
Currently: livin the dream
bushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond reputebushy has a reputation beyond repute
Default
Was told the secondary converted back to torsion spring setups can cause a grinding like noise/feel in reverse. Causes the belt to slip and hop in reverse?? My sheaves are full of belt marks. The 09 M8 I just bought is doing it. Really has a hard time getting moving in reverse. Anybody confirm or refute this? Mine is the OVS secondary kit.
__________________
  #5
Old 09-04-2011, 09:59 PM
Default
Quote:
Just open your hood and watch what the belt does when you're in reverse and start to move. Whats happening?
  #6
Old 09-04-2011, 10:25 PM
bushy's Avatar
Default
That would be too easy..I'm more of a "pull the crank out and have it straightened only to find it was a loose helix all along" kind of mechanic. lol I actually did that last year...
First sled with reverse and I'm guessing it will work better reversing on snow, but the trailer has plastic ski guides so it should have that much trouble backing out? I'll let you know what I find out next time I pull it out of the trailer.
__________________
  #7
Old 09-05-2011, 08:39 AM
kidrman kidrman is offline
Currently: Not set.
kidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond repute
Default
Seems like tons of threads on here about torsional kits not working well with reverse. Do you have a bud you could swap secondarys with that is still running compression setup?
  #8
Old 09-05-2011, 09:18 AM
RickM's Avatar
RickM RickM is offline
Currently: Not set.
RickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond reputeRickM has a reputation beyond repute
Default AkHockey10
After reading your post, it sounds like you may have the torsional conversion spring setup in the driven clutch. As mentioned above, a lot of people including my self had issues with them working in reverse properly. If belt deflection is off then the helix can grind and sheaves open up and that caused the sudden jerk or grab when the belt slams in taking up the slack in the belt.
Once the sheaves are open then when you try and engage the clutch forward you have the lurch forward again. Look at your helix where the rollers ride on it in the reverse side area of roller contact. I bet you see the problem.
Hope this may help you out.RickM
  #9
Old 09-12-2011, 09:23 PM
Garage
Default
Nice. Thanks guys!!
I FINALLY had the chance to look into the sled. Diamond drive is in healthy condition. Took off the primary and didn't see anything out of the ordinary Its gotta be something! Giving it a good wash down (same with DD) and putting it back on. My next thing is maybe I should change my spring... It will help with the rough engagement making it smooth...in theory. Will look into the other possibilities.
  #10
Old 09-12-2011, 10:27 PM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
  #11
Old 09-13-2011, 01:13 AM
Garage
Click Here to Register
  #12
Old 09-13-2011, 01:17 AM
Garage
  #13
Old 09-13-2011, 07:49 AM
mr p-j mr p-j is offline
Currently: Not set.
mr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond reputemr p-j has a reputation beyond repute
The Following User Says Thank You to mr p-j For This Useful Post:
Wrenchmaster (03-12-2018)
  #14
Old 03-12-2018, 09:35 AM
Wrenchmaster's Avatar
Wrenchmaster Wrenchmaster is offline
Currently: working when I should be riding
Wrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond repute
  #15
Old 03-16-2018, 07:09 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
The Following User Says Thank You to summ8rmk For This Useful Post:
Wrenchmaster (03-16-2018)
  #16
Old 03-16-2018, 07:39 AM
  #17
Old 04-01-2018, 11:35 PM
Tmann Tmann is offline
Currently: Previously known as "Deadsled1"
Basic Member
Tmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Grinding in reverse Thread Starter — pinko Forum — Arctic Cat: M Series Replies — 12 Last Post — 01-20-2011 03:12 PM
Thread — 2009 HCR grinding noise? Thread Starter — corydoneen Forum — Arctic Cat: M Series Replies — 11 Last Post — 01-07-2011 05:34 PM
Thread — Help-2011 m8 grinding noise Thread Starter — togwoteerider Forum — Arctic Cat: M Series Replies — 12 Last Post — 12-29-2010 02:17 PM
Thread — 08 M8 reverse noise/grind? Thread Starter — M8 Megatron Forum — Arctic Cat: M Series Replies — 8 Last Post — 02-23-2010 07:40 PM
Thread — 06 900 RMK, grinding noise in reverse, no power Thread Starter — Clarke_67 Forum — Polaris Replies — 11 Last Post — 01-15-2008 06:20 AM
no new posts
