Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 06-13-2011, 09:28 PM
ftodd39 ftodd39 is offline
Currently: Not set.
Basic Member
ftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond reputeftodd39 has a reputation beyond repute
Default Xp Seat on a ZX Chassis
Well I bought a used xp seat, gas tank, trim on top of tank,trim over side brackets, side brackets from tunnel, and the back steering post braces. I cut the tank to fit and removed material so as to allow access for using original seat back bolts that were relocated to attach the rear of the gas tank that was cut to fit around the original tank. You need the xp tank because it is the mounting surface/bracket for the seat. The original seat weighed 14.2lbs and the new seat/tank mount combo weighed 12lbs
Click image for larger version
Name:	xp seat zx 01.jpg
ID:	143325   Click image for larger version
Name:	xp seat zx 02.jpg
ID:	143326   Click image for larger version
Name:	xp seat zx 03.jpg
Name:	xp seat zx 04.jpg
ID:	143328   Click image for larger version
Name:	xp seat zx 05.jpg
ID:	143329   Click image for larger version
Name:	xp seat zx 06.jpg
Rate this post: Yes | No
The Following 4 Users Say Thank You to ftodd39 For This Useful Post:
dleishman (08-15-2013), JustinB (06-26-2011), Snow Duck (01-19-2012), summit403 (11-07-2013)
  #2
Old 06-14-2011, 07:36 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
Very interesting the way you did that. But how much did you pay for all that you had to buy?
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 06-14-2011, 12:05 PM
Currently: Not set.
Basic Member
Default
I paid $125 for all the pieces
  #4
Old 06-15-2011, 11:02 AM
cubby's Avatar
Default
Used parts I assume. Nice job, looks pretty cool
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #5
Old 06-15-2011, 01:48 PM
jake432 jake432 is offline
Currently: Need snowwwww
jake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond reputejake432 has a reputation beyond repute
Default
that is the best looking zx summit i have ever seen! nice job!
  #6
Old 06-21-2011, 02:22 PM
cwrolson cwrolson is offline
Currently: Diggin Dinasaur Juice
cwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond reputecwrolson has a reputation beyond repute
Default
How much taller is the XP configuration than the stock zx seat? Are the steering post braces under all the trim pieces?
  #7
Old 09-20-2011, 05:55 PM
shawn2820 shawn2820 is offline
Currently: Not set.
shawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond reputeshawn2820 has a reputation beyond repute
Default
did you have to remove the rails and all to get to everything? I suppose it would be easier if you did. Probably the way i should do it too if im going to be putting a different track on anyway.
  #8
Old 10-16-2011, 10:16 PM
Danzick Danzick is offline
Currently: Not set.
Basic Member
Danzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond reputeDanzick has a reputation beyond repute
Garage
Default
very clean job. good work. i have yet to see a zx with an xp seat. there probably has been others but this is the first one ive seen. very nice.
  #9
Old 10-16-2011, 10:23 PM
i'llDooit i'llDooit is online now
Currently: summer sucks
i'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond repute
Default
nicely done. saw someone do a xp seat on a rev and it looked like garbage. you did it right. cheers
  #10
Old 10-17-2011, 04:45 PM
wordawg wordawg is offline
Currently: Not set.
Basic Member
wordawg is an unknown quantity at this point
  #11
Old 11-23-2011, 08:32 PM
poo poo is offline
Currently: Not set.
Basic Member
poo is an unknown quantity at this point
Click Here to Register
  #12
Old 01-02-2012, 10:20 PM
PTE800 PTE800 is offline
Currently: Not set.
PTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond reputePTE800 has a reputation beyond repute
  #13
Old 01-11-2012, 08:07 PM
MK4TDI MK4TDI is online now
Currently: TMR 840
Basic Member
MK4TDI is an unknown quantity at this point
  #14
Old 01-11-2012, 09:35 PM
Currently: Not set.
  #15
Old 01-12-2012, 02:19 PM
LRD LRD is offline
Currently: Not set.
LRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond reputeLRD has a reputation beyond repute
  #16
Old 01-19-2012, 12:05 PM
northshoremb northshoremb is offline
Currently: Not set.
Basic Member
northshoremb is an unknown quantity at this point
  #17
Old 01-19-2012, 12:36 PM
Snow Duck's Avatar
Snow Duck Snow Duck is offline
Currently: Trees are not for me!!or my son..
The Great and Mighty SnowDuck
Snow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond repute
Garage
  #18
Old 01-19-2012, 09:37 PM
Currently: Not set.
  #19
Old 01-20-2012, 04:47 PM
Currently: Not set.
Basic Member
The Following 2 Users Say Thank You to northshoremb For This Useful Post:
Nels_15 (11-21-2014), PTE800 (01-20-2012)
  #20
Old 01-20-2012, 05:16 PM
Currently: Not set.
Basic Member
  #21
Old 10-24-2012, 07:27 PM
awsome al awsome al is offline
Currently: Not set.
Basic Member
awsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant futureawsome al has a brilliant future
  #22
Old 10-24-2012, 08:41 PM
Currently: Not set.
  #23
Old 10-25-2012, 06:23 AM
Currently: Not set.
Basic Member
  #24
Old 10-29-2012, 03:25 PM
Rev.440x Rev.440x is offline
Currently: Not set.
Basic Member
Rev.440x is an unknown quantity at this point
  #25
Old 08-15-2013, 04:31 PM
dleishman dleishman is offline
Currently: Not set.
Basic Member
dleishman is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Zx Chassis Seat Thread Starter — kevinhoglund Forum — Seats (Swapmeet) Replies — 5 Last Post — 01-15-2011 05:22 PM
Thread — zx chassis seat f/s Thread Starter — addikted Forum — Seats (Swapmeet) Replies — 1 Last Post — 12-10-2009 05:03 PM
Thread — Boss Seat for a ZX chassis Thread Starter — Dummy Forum — Seats (Swapmeet) Replies — 14 Last Post — 02-17-2008 12:19 PM
Thread — looking for boss seat for zx chassis Thread Starter — skidoo mod 700 Forum — Seats (Swapmeet) Replies — 1 Last Post — 01-05-2008 07:57 PM
Thread — REV seat on ZX chassis Thread Starter — texasranger556 Forum — Ski-Doo Replies — 5 Last Post — 11-26-2007 08:49 PM
no new posts
