Upgrade to Premium
Reply
  #1
Old 06-05-2011, 05:26 PM
48janke 48janke is offline
Currently: Not set.
Basic Member
48janke is an unknown quantity at this point
Default IQR 800 conversion questions
Hey I am new to this mod sled world and I currently bought an 05 polaris IQR 440. I installed a 144'' easy ride skid with a 2.5''x 144'' track and a VE tunnel, I now have a 05 800 switchback sled to steal a motor out of. what are some good tips for this motor swap, I have done allot of reaserch and would just like to hear from some guys that have already done this mod. I have brads motor plate on order. What should i be looking for for a center to center on the clutches? what are guys using for oil tanks to retain the oil injection? what are guys using for belts,pipes,carb boots, airbox, etc. any feedback would help thx
Rate this post: Yes | No
  #2
Old 06-05-2011, 05:55 PM
Currently: Not set.
Basic Member
Default
Pictures would be VERY helpful too!!!!
  #3
Old 06-06-2011, 11:44 PM
shoobear shoobear is offline
Currently: blah blah blah
Basic Member
shoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond reputeshoobear has a reputation beyond repute
Default
you can use a oil res tank from a 600rr.
I used one a quad.
Have a look on HCS for a more 800 install info.......
The Following User Says Thank You to shoobear For This Useful Post:
48janke (07-12-2011)
  #4
Old 06-24-2011, 07:14 PM
Gmiller's Avatar
Gmiller Gmiller is offline
Currently: Time to TRIPLE!!
Gmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond reputeGmiller has a reputation beyond repute
Default
I used the Factory 800 Race Straps instead of Brads plate so its a little different but still pretty similar. I still had to make room for the oiler on the mag side, shock tower brace. I used a $15 1997 Polaris XLT oil tank from an XCR INDY. Since i used the Twin pipes i had NO room on that side of the engine for an oil bottle so i mounted it above the clutches on a custom mount i made. My engine has ves and was mounted so high the bent steering post i bought didn't clear the VES and was useless. I took the stock straight steering post and without bending it dented the area where it came in contact with the VES. That worked awesome, I made a custom bent upper support for above the clutch side spark plug and VES so i can still get at them. Other than that, USE HCS 440/800 thread, Tons of build-up info using Brads plate. If you need close up pictures of anything i did, Let me know.
Grant
__________________
2005 Polaris IQR, 146 track, 800 ves, twin slp's.
2009 Polaris IQR, shorty 600 hi comp, twin slp's
2013 Polaris IQR build with 1200 triple, 155. in process.
2007 Dodge Ram 2500 6spd, 5.9 Cummins, To many extras.... 700hp and big tires....
The Following 2 Users Say Thank You to Gmiller For This Useful Post:
48janke (07-03-2011), epiphanot (08-11-2016)
  #5
Old 06-24-2011, 07:20 PM
Gmiller's Avatar
Default
Oh and use Brads carb adapters with air pods, They clear the Jackshaft and are awesome, that way no airbox. Twins are expensive but worth it IMO.
__________________
The Following User Says Thank You to Gmiller For This Useful Post:
  #6
Old 04-12-2016, 03:52 PM
SnoDmon's Avatar
SnoDmon SnoDmon is offline
Currently: Avoid Power Addiction(PAR) like the plague!
SnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond reputeSnoDmon has a reputation beyond repute
Default
gmiller - do you have the Part number for the factory 440 to 800BB engine mounting straps? My IQr is an '09 600 and I'm going to a 1085 PSI based off of the 800 BB. Thanx
__________________
>~*SnoDmon*~<
When in Doubt, Throttle it out!!!
'09 Polaris IQr 153"
'05 Polaris 900 RMK 174" - rollin' on 10"s
'96 Polaris Indy Ultra RMK - draggin asphalt!
  #7
Old 08-03-2016, 12:56 PM
MrIQR MrIQR is offline
Currently: Too many sleds, not enough time
Basic Member
MrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond repute
Default
Quote:
Call Brad at the Polaris Race Department.. 715-355-3008
Youll need the spacer/shim also unless you've notched the front of your bulk head to clear the waterpump..
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 800 CFI Conversion Into IQR Need Help!! Thread Starter — colbyj Forum — Polaris: IQR Replies — 1 Last Post — 10-22-2010 05:07 PM
Thread — IQR with 800 monoblock conversion F/S Thread Starter — PR Performance Forum — IQR Parts Replies — 1 Last Post — 05-25-2010 09:30 PM
Thread — 800 conversion for IQR Thread Starter — Clarke_67 Forum — Racing Replies — 8 Last Post — 01-12-2010 10:31 AM
Thread — Where can i get a motor Plater for a IQR 800 BB conversion Thread Starter — rab Forum — Polaris Replies — 4 Last Post — 04-09-2009 08:03 AM
Thread — 2008 IQR 800 for sale - monoblock conversion Thread Starter — voodoo Forum — Racing Replies — 0 Last Post — 03-13-2009 11:16 AM
