Upgrade to Premium
Electronics Beacons, GPS, communication systems, etc.....
Reply
  #1
Old 12-17-2010, 11:03 AM
Brian's Avatar
Brian Brian is offline
Currently: Trying to make it go faster.
Brian has disabled reputation
Garage
Default In-Helmet radios with Midland / Rino / others.
So I am the first to fully admit that I'm new to sleds... My background is on ATVs, but several things I do there seem to translate well to the sled world.
In the ATV world, we've been using Midland GTX1000VP4 FRS / GMRS radios. They are a full 5-watts on GMRS, they are completely waterproof, and most importantly, you can pull out the rechargeable battery and swap it with AA batteries on the fly. Link to the Midland radios is here. I can tell you with 100% certainty these are the best basic FRS/GMRS radios on the market, hands down.
Attached to the Midland radios, I use a kit that installs right inside the helmets (earphones and microphone are embedded right inside). Out of the helmet a cable runs and connects to a "push to talk" button that's mounted right on the handlebars, and then connected to the radio. The point is that riders can talk to each other and hear each other from right inside their helmet... And the transmit-button can be pushed without taking their hands off the machine. Link to the helmet-kit I use is here.
The radios are easily attached to the handlebars with zip-ties. I find they hold better than any of the mounts I've attempted.
In other words... For around $120, you can get two radios and two helmet kits and two riders can talk easily to one another.
NOW... I'm looking at replacing my entire setup with the Rino 530hcx radios for the SOLE reason that I want the ability to see where the other riders are in the group at any given time. However, I've been hesitant to do so because I have such a significant investment in my helmet-radio kits (8 helmets across 6 different machines, which obviously comes with a pile of radios too).
I just learned, however, that the speaker / mic pinout on the Rino is -IDENTICAL- to the speaker/mic pinout on the Midland radios that I use... Which is good for several reasons...
1) For guests, I can continue to use my Midland radios and don't need to ask everyone in the group to buy a Rino.
2) All of my existing helmet kits are compatible with BOTH radios (in other words, someone can sit down on a machine, and regardless of whether it's my new Rino or the Midland radio, their helmet can plug right in).
3) The helmet kid for the Midland is significantly cheaper ($30) than the helmet kit designed for the Rino ($50).
THE POINT IS SIMPLE: You can safely and CHEAPLY use a combination of the Rino and the Midland radios I've mentioned above, since the helmet-kits are completely interchangeable, and both radios are very capable, high-power, and durable.
The only remaining question is how well the quick-disconnect works if you become dismounted from your sled. The quick-connect literally "pulls apart". The question is, will it safely separate, or will it damage the wire as it pulls apart?
I'm going to test the heck out of it this weekend. I will return and report.
Rate this post: Yes | No
  #2
Old 12-18-2010, 06:58 AM
firecatguy firecatguy is offline
Currently: I have madpow disease
firecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond reputefirecatguy has a reputation beyond repute
Default
that is alot of work there....what I use is a mic\speaker with the radio in my pack I can hear as i ride and also talk as i ride....this set up works!!!!!
The Following User Says Thank You to firecatguy For This Useful Post:
christopher (12-24-2010)
  #3
Old 12-18-2010, 06:59 AM
Default
we have a guy who uses his rino 2way and it works just fine with our radios
  #4
Old 12-18-2010, 09:37 AM
tmk50's Avatar
tmk50 tmk50 is offline
Currently: Not set.
tmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond reputetmk50 has a reputation beyond repute
Default
We just use the simple earbuds and stick the radios in our jackets. The only time we use the radios is when we are stopped and figure out that someone is stuck/separated so those work for us.
I like firecatguy's set up better - I don't want any wires attached from me to the sled. I'd break those within a half day ride, but I'm sure that setup would work for a lot of other riders.
  #5
Old 12-18-2010, 10:04 AM
flyboy103 flyboy103 is offline
Currently: Not set.
flyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond reputeflyboy103 has a reputation beyond repute
Default
Has anyone tried the throat mic setup that motorola makes? Been planning to try these for a couple years but havent gotten around to it yet.
  #6
Old 12-18-2010, 08:09 PM
Tonysnoo's Avatar
Tonysnoo Tonysnoo is offline
Currently: Not set.
Tonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond reputeTonysnoo has a reputation beyond repute
Default
I sure like my chatterbox radios. We talk a long way with other radios or rhinos, and don't have any cords hanging around anywhere because, it clips to the side of my helmet, easy to use controls, mics and ear speakers available for many helmet configs. They even have blue tooth now so the phone or ?? can be listened to while riding.
Priceless when sweeping a high steep rocky slope and coming down through a mine field. The guys down below can alert you of dangerous conditions with out your hands leaving the bars.
cons:
spendy, separate gps, some difference in channel numbering.
__________________
If ya ain't gonna Cowboy up..... get yer dainty be-hind back in the truck!
  #7
Old 12-19-2010, 01:44 PM
Engine Pro 5x's Avatar
Engine Pro 5x Engine Pro 5x is offline
Currently: Building Race Engines
Engine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond reputeEngine Pro 5x has a reputation beyond repute
Garage
Default
X2 for the Chatterbox. We use these and they have never let us down. Clear reception and easy to use. They have a voice activation or a push to talk button. I like the ptt button just to make the mic engagement easier >>>>.
__________________
Nitro is spelled with an I !!!
  #8
Old 12-24-2010, 12:52 AM
toesmack's Avatar
toesmack toesmack is offline
Currently: Finally! SNOW!!
toesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond reputetoesmack has a reputation beyond repute
Default ChatterBox GMRS X1
As to the Garmin or Collett, both require extra wires and the Collett even has an external battery pack to deal with. As Tony has said, the ChatterBox is totally contained on the helmet. 9 ounces incl the battery. Collett battery pack alone weighs like 14 ounces, nearly a pound!
ChatterBox GMRS X1 claims up to 5 mile range. That won't happen. They are good out to about a mile or a little better in the right conditions. VOX or Push to Talk, water resistant and very rugged. I have had the same unit for 6 years. As to bulky, you won't feel it on the helmet. The 2 nine year old girls that we sometimes ride with don't notice them.
Also, Collett has a very short range in offroad applications. You can expect about 300 yards, and they won't talk with other handheld brands. ChatterBox will.
Talk and recieve on the fly, battery good for about 14 hours. 15 channels and TONS of side channels. Simple.
Yep, I sell ChatterBox. X1 now only $170
ED
775-230-6032
  #9
Old 12-24-2010, 09:09 AM
Garage
Default
This the model I prefer !!! >>>>.
__________________
  #10
Old 12-24-2010, 10:54 AM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default
Quote:
You can REALLY HEAR THIS when your in motion????
__________________
  #11
Old 12-24-2010, 10:53 PM
heavy_haul's Avatar
heavy_haul heavy_haul is offline
Currently: " "
heavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond reputeheavy_haul has a reputation beyond repute
Garage
Click Here to Register
  #12
Old 12-25-2010, 12:32 AM
toesmack's Avatar
  #13
Old 12-28-2010, 06:21 AM
  #14
Old 01-02-2011, 11:52 AM
Flattracker Flattracker is offline
Currently: Not set.
Flattracker is an unknown quantity at this point
  #15
Old 01-02-2011, 06:16 PM
  #16
Old 02-01-2011, 06:24 PM
danduvall danduvall is offline
Currently: team long track
danduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond reputedanduvall has a reputation beyond repute
  #17
Old 06-03-2011, 10:04 AM
Skidor Skidor is offline
Currently: Ayuh
Basic Member
Skidor is an unknown quantity at this point
  #18
Old 06-19-2011, 10:58 AM
1MEX 1MEX is offline
Currently: needing a new sled
1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute1MEX has a reputation beyond repute
Garage
  #19
Old 07-22-2011, 10:54 AM
Jeff C's Avatar
Jeff C Jeff C is offline
Currently: Snowest elder statesman
Jeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond reputeJeff C has a reputation beyond repute
  #20
Old 07-22-2011, 10:10 PM
Tonysnoo's Avatar
Currently: Not set.
  #21
Old 08-22-2011, 09:26 AM
Jeff C's Avatar
  #22
Old 08-26-2018, 11:44 PM
lucyjohn987 lucyjohn987 is offline
Currently: Not set.
Basic Member
lucyjohn987 is an unknown quantity at this point
  #23
Old 08-27-2018, 07:04 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
  #24
Old 09-20-2018, 03:04 PM
HenryTheHammer HenryTheHammer is offline
Currently: Not set.
HenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant futureHenryTheHammer has a brilliant future
  #25
Old 12-11-2018, 07:51 PM
Golanda Golanda is offline
Currently: Not set.
Golanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond reputeGolanda has a reputation beyond repute
The Following User Says Thank You to Golanda For This Useful Post:
christopher (12-11-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Two Way radios ? Thread Starter — Rprecision Forum — Communications Replies — 6 Last Post — 09-02-2009 08:00 PM
Thread — Rino 530HCx: In Helmet Communications Thread Starter — christopher Forum — Communications Replies — 0 Last Post — 08-29-2009 12:20 PM
Thread — F/S Rino 110 & 120 GPS Radios Thread Starter — Sled169 Forum — Communications Replies — 1 Last Post — 12-07-2007 10:49 AM
Thread — 2 way radios Thread Starter — Insaneboltrounder/sjohns Forum — General Snowmobiling Replies — 2 Last Post — 11-29-2007 01:18 AM
no new posts
