Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 12-09-2010, 12:26 PM
AJSskidoo AJSskidoo is offline
Currently: Not set.
Basic Member
AJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant futureAJSskidoo has a brilliant future
Default 03 mxz no electrical please help.
Hoping some one could help me out, Started sled up today to go for a short ride and noticed I have nothing working on the dash. No speedo,tach,warning lights, no headlight, tail light and no warmers. Tether key is on all the way runs fine, took it down the trail for 5 mins or so runs wide open fine what else could it be? both fuses I know of (on right side behind choke lever) are good. everything worked a week ago when I ran it around home and got it ready for season. Thanks for any input. Adam.
Rate this post: Yes | No
  #2
Old 12-09-2010, 12:32 PM
Snow Duck's Avatar
Snow Duck Snow Duck is offline
Currently: Trees are not for me!!or my son..
The Great and Mighty SnowDuck
Snow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond reputeSnow Duck has a reputation beyond repute
Garage
Default
Check all harness plugs to see if tight and pushed all the way in...then second...pull loom off wiring and make sure no rubbed spots evident...from hood connector to engine..
__________________
  #3
Old 12-09-2010, 12:34 PM
Currently: Not set.
Basic Member
Default
I will check it thanks again. where would the most common spot be if its rubbed? hood hinge area I would guess?
  #4
Old 12-09-2010, 12:54 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
It's the relay...small black relay zip-tied above/behind the secondary clutch. NAPA # AR201 is a cheap replacement. Common, carry a spare.
The Following 3 Users Say Thank You to winter brew For This Useful Post:
AJSskidoo (12-09-2010), RottenRobbie (10-24-2012), summ8rmk (03-29-2016)
  #5
Old 12-09-2010, 12:57 PM
Snow Duck's Avatar
Garage
Default
Quote:
yes i forgot about those...mine are by the regulator in the right side of the bulkhead in front of the engine
__________________
The Following User Says Thank You to Snow Duck For This Useful Post:
  #6
Old 12-09-2010, 01:11 PM
Currently: Not set.
Basic Member
Default
thanks guys I will look in both spots I also have a black circut breaker next to the fuses on right side wondering what that is or if that is what you guys are tlking about. In any case I will check both spots thanks again. Iguess they're bound to go out some time. they are only 7 YEARS OLD!
  #7
Old 12-09-2010, 01:45 PM
Currently: Not set.
Basic Member
Default
LET THERE BE LIGHT!!! thanks a million guys. My relay was located behind right side panel next to fuses napa #AR201 is the one! #AR143 relay comes with the mounting tab to screw it back to original spot. Thanks again. I bought 3.
The Following 2 Users Say Thank You to AJSskidoo For This Useful Post:
ape (01-07-2012), summ8rmk (03-29-2016)
  #8
Old 12-09-2010, 05:29 PM
skidoorevetec skidoorevetec is offline
Currently: Not set.
Basic Member
skidoorevetec is an unknown quantity at this point
Default 03 eltrical problem
its a relay under the hood right above the air box.. its like 35 bucks or you can get one at the auto parts for cheaper... but yea goodluck..
  #9
Old 12-10-2010, 06:54 PM
keneb keneb is offline
Currently: Won't be long now!
keneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond reputekeneb has a reputation beyond repute
Default
Funny, I just had the same problem. I found a nice firm "WHACK" with a screwdriver handle on the relay workes wonders! Though I did promptly get a few new ones when we got back home.
  #10
Old 01-07-2012, 05:44 PM
ape ape is offline
Currently: Not set.
Basic Member
ape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud ofape has much to be proud of
  #11
Old 03-28-2016, 06:29 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 01 MXZ 700 to 03 MXZ 800 Renegade Thread Starter — IL Renegade Forum — Ski-Doo: ZX Sleds Replies — 2 Last Post — 11-28-2010 10:37 PM
Thread — 03 800 skidoo electrical problems Thread Starter — roos800 Forum — Ski-Doo Replies — 3 Last Post — 02-24-2009 10:03 AM
Thread — 03 summit x 800 electrical problem Thread Starter — GRAVITYXXX Forum — Ski-Doo Replies — 3 Last Post — 01-03-2009 10:45 AM
Thread — '03 summit electrical issues Thread Starter — skidoochick564 Forum — Ski-Doo Replies — 6 Last Post — 11-10-2008 10:04 PM
no new posts
