Upgrade to Premium
Clutching Discuss all things related to Clutching for your sled.
Closed Thread
  #1
Old 09-27-2010, 06:14 AM
milehighassassin's Avatar
milehighassassin milehighassassin is offline
Currently: Motor is complete!!!
Moderator: Premium Member
milehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond repute
Garage
Default Ski-Doo Clutching Links
This is a growing thread, more Models to come shortly
XP
Big John recommends
Team Secondary on XP
Team Secondary and Primary weight
Another Team Secondary
Better TRA Primary Roller
Primary TRA-7 Blew Apart
Northern Catalyst, tons of info and kits for purchase
Specifics
2011 Clutch specs
Helix Install/secondary removal
Rooster Built v Dynamo Joe
Dynamo Joe setup
Ultimate clutch setup
Rooster Built Review
Clutch Alignment talk
Ski-Doo Memo on alignment
Shockwave adjustable Helix
Floating Secondary (small) talk
Primary clutch wear
Primary disassembly
Belt talk
More belt talk
Clutch out of Balance
Primary Clutch Torque is 90 ft-lbs
Trick Belt Drive for XP
REV
Gearing Calculator:
https://www.ibackshift.com/calculator
https://www.ibackshift.com/builder
__________________
Need to get rid of a STRAIGHT IQ 163" tunnel and tub. Cheap!!
Rate this post: Yes | No
The Following 3 Users Say Thank You to milehighassassin For This Useful Post:
rmk01r1der (04-30-2012), SnowmobileNetwork (11-01-2014), summit800 (03-06-2013)
Closed Thread
Bookmarks
Tags
clutch, clutch alignment, clutches, ski-doo
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Polaris Clutching Info/Links Thread Starter — milehighassassin Forum — Clutching Replies — 0 Last Post — 09-25-2010 11:42 AM
Thread — Ski doo turbo Clutching Thread Starter — Turbo11T Forum — Performance/Modified Replies — 2 Last Post — 12-30-2008 12:14 AM
Thread — Ski doo turbo Clutching Thread Starter — Turbo11T Forum — Ski-Doo Replies — 0 Last Post — 12-29-2008 12:56 PM
Thread — 2007 Ski doo Clutching Thread Starter — richboy202 Forum — Clutching Replies — 5 Last Post — 12-28-2008 09:50 PM
no new posts
