Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 07-12-2010, 06:20 PM
summit ate summit ate is offline
Currently: BEST DEAL IS NOW!!!
Basic Member
summit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant futuresummit ate has a brilliant future
Default ultimate clutch set up
for 9-12500' elev. 09 stock 800 154
who has the best aftermarket set up
how does the setup from" winterbrew" compare?
Rate this post: Yes | No
  #2
Old 07-12-2010, 07:38 PM
byeatts byeatts is offline
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
Default
I run Toms heavy arms .433s 160/320 and Team Tied 66/60 and its spot on at 7 to 11,ooo.In fact this does not ever require any clicker change from #3
  #3
Old 07-12-2010, 08:28 PM
pauly-doo pauly-doo is offline
Currently: UTYEU
pauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond reputepauly-doo has a reputation beyond repute
Default XP CLUTCH SET UP.
I WENT WITH ONE FROM ROOSTER BUILT/WINTER BREW.GREAT CUSTOMER SERVICE,SET UP WORKS GOOD.GEARED DOWN ONE TOOTH.KEEP CLICKERS ON 3 ALL SEASON..BELTS LASTED ABOUT 900 MILES..I WAS PLEASED..
  #4
Old 07-12-2010, 09:39 PM
2Thetopp's Avatar
2Thetopp 2Thetopp is offline
Currently: on Snowest
Location: Everett WA. 4 minutes from work,one hour from the mountains
2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute2Thetopp has a reputation beyond repute
Default ultimate clutch set up Reply to Thread
Roosterbuilt/Winterbrew = God, I mean "Good" (typo) or was it?
  #5
Old 07-13-2010, 02:07 PM
yamahaboy701's Avatar
yamahaboy701 yamahaboy701 is offline
Currently: Modding the eight50
yamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond reputeyamahaboy701 has a reputation beyond repute
Default
I was shopping around for clutch kits early this summer for my 154 and talked to a few companies and people and I am going with Winter Brew / Roosterbuilt. He just said this is what you need and why and how much it will cost, all the other 10+ places were like "I think I got something that will work".
0 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 07-13-2010, 04:59 PM
turboal turboal is offline
Currently: Not set.
Basic Member
turboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond reputeturboal has a reputation beyond repute
Default
we found that the stock set up with the primary spring changed to 160/350 worked very well , makeing sure that the motor was in align and stayed there was extremely important . no other change needed.
  #7
Old 07-13-2010, 05:24 PM
clutch man clutch man is offline
Currently: dex add up now location La pine or.
clutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond reputeclutch man has a reputation beyond repute
Default
Quote:
how much wieght are you running in your arms?
  #8
Old 07-14-2010, 05:42 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Well, OK....since it's July and not many guys on here.....a blast from the past thread.
http://www.snowestonline.com/forum/s...hlight=rooster
  #9
Old 07-15-2010, 07:48 AM
gus bohne gus bohne is offline
Currently: Not set.
Basic Member
gus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond repute
Talking
Brews rep stand s for itself,
long belt life, someone to answer the phone and rave reviews from all who use them ( of course he learned it all from OT..! )LMAO !!!
Though I am a strong believer in using variable center of mass levers in the tra ..
Wouldn't it be cool to have a lever with internal mass that shifts to the tip as the lever swung out ???,, then under spring force pushed back to pivot when rpms drop..
We COULD make them,, BUT WINGNUT RANDY has a patent to block it..He won't make them and won't relinquish the patent.
Gus
  #10
Old 07-15-2010, 08:11 AM
Currently: Not set.
  #11
tukernater tukernater is offline
Currently: Waiting on more snow
tukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond reputetukernater has a reputation beyond repute
Click Here to Register
  #12
Old 07-18-2010, 11:09 PM
2009skidoo800rxp 2009skidoo800rxp is offline
Currently: Not set.
Basic Member
2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future2009skidoo800rxp has a brilliant future
  #13
Old 08-12-2010, 10:58 PM
Maximum1 Maximum1 is offline
Currently: Not set.
Maximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to beholdMaximum1 is a splendid one to behold
  #14
Old 08-13-2010, 12:29 PM
Currently: Not set.
  #15
Old 08-16-2010, 10:36 AM
Dynamo^Joe's Avatar
Dynamo^Joe Dynamo^Joe is offline
Currently: talking about clutching
Dynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond repute
  #16
Old 08-17-2010, 07:20 AM
BIG JOHN's Avatar
BIG JOHN BIG JOHN is offline
Currently: making Summits bettersince 1997
BIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond reputeBIG JOHN has a reputation beyond repute
  #17
Old 11-27-2017, 07:17 PM
trappersnapper trappersnapper is offline
Currently: Not set.
Basic Member
trappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond reputetrappersnapper has a reputation beyond repute
  #18
Old 11-27-2017, 11:02 PM
duncan76 duncan76 is offline
Currently: Not set.
duncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond reputeduncan76 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
