Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
View Poll Results: Does Your D8 lean to the left
yes 52 50.00%
no 51 49.04%
08 21 20.19%
09 31 29.81%
Multiple Choice Poll. Voters: 104. You may not vote on this poll
Reply
  #1
Old 02-08-2010, 02:08 PM
stage1 stage1 is offline
Currently: gonig to cat!!
Basic Member
stage1 is an unknown quantity at this point
Default 08 D8 leans to left all the time!!
Any one have a fix for the 08 D8 slumping left side front suspension ?? never crashed,dealor and factory looked at it and said not shure. shock rebuild no help!! Buddy has same thing on his. will not go to rhe right in powder and dives or rolls in slow right turns (Rolls to Left) and turns left tike a normal sled. remove sway bar?? then what?? sat level at dealor wile the had motor out to replace the ****ty factory crank (813 Miles).
Rate this post: Yes | No
  #2
Old 02-08-2010, 02:50 PM
Jeff95 Jeff95 is offline
Currently: Not set.
Jeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond reputeJeff95 has a reputation beyond repute
Default
My is the same!
I put 235lb's in left and 210lbs in right to help.
If you push down in the middle in front and release the left sags by about 1/2".
I gave up on tring to get level.
Jeff
  #3
Old 02-08-2010, 02:54 PM
pokey76 pokey76 is offline
Currently: MOUNTAIN MANIA
pokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond reputepokey76 has a reputation beyond repute
Default 09 800 Dragon
Did you ever find a fix for the left diving? My 09 does the same. Had it to dealer, shock rebuilt ect. Still does it.Still can't figure it out.
  #4
Old 02-08-2010, 03:34 PM
joe julkowski joe julkowski is offline
Currently: Not set.
joe julkowski is an unknown quantity at this point
Default
I no longer own the sled but mine had me going crazzy. What I found by pulling the primary clutch off the two aluminim parts that should have been tight it seemed to be opening up. Dont know the cause but was the only thing that was not right that I could find. just my two cents
  #5
Old 02-08-2010, 03:36 PM
RamrodAK1 RamrodAK1 is offline
Currently: Need more Avgas!
RamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond reputeRamrodAK1 has a reputation beyond repute
Default
Mine does the same thing. I can't figure out why. Theres gotta be a flaw somewhere. I have looked over the whole thing?
  #6
Old 02-08-2010, 03:49 PM
wolf wolf is offline
Currently: Not set.
Basic Member
wolf is an unknown quantity at this point
Default
is your rear suspension in square and level to your chassis. is your chassis twisted measure it on level surface.
  #7
Old 02-08-2010, 03:58 PM
JDen JDen is offline
Currently: Not set.
JDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond reputeJDen has a reputation beyond repute
Default
My 08 D8 does the same thing, pretty much since new, don't understand, rebuilt and still no difference.
  #8
Old 02-08-2010, 04:03 PM
xltdale xltdale is offline
Currently: Not set.
xltdale is an unknown quantity at this point
Default 09 d8
Mine is doing the exact same thing. walker evan shocks and battery on left part of the problem?
  #9
Old 02-08-2010, 04:30 PM
IdahoPowderHound IdahoPowderHound is offline
Currently: NXT LVL Clinics start in one month!
IdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond reputeIdahoPowderHound has a reputation beyond repute
Default
I have seen this on almost every sled ive owned in the past. Set your sled on a solid surface and lift the front off the ground. Set it back slowly as if your tring to get the most clearance for the front. Grab the bumper from the front with both hands and lift the suspension up and down just a couple inches. you will be able to tell you have a weak shock by one side shrugging more then the other. this will cause the front to dive and poor handling. If you are having problems with this on just the Walker Evans floats i say trash them and get some Ride FX shocks or upgrade to the coilover WE. Everyone that i know that has a dragon has problems with there WE's shocks. I have had Fox Floats on my iqr and have this problem when air leaks out of the chambers but its an easy fix with there air pump tool.
  #10
Old 02-08-2010, 08:47 PM
Basic Member
  #11
Old 02-08-2010, 09:44 PM
IDAHO HOT SHOT IDAHO HOT SHOT is offline
Currently: Theres snow in them thar hills!!
IDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond reputeIDAHO HOT SHOT has a reputation beyond repute
Click Here to Register
  #12
Old 02-08-2010, 09:46 PM
RMKen RMKen is offline
Currently: Not set.
Basic Member
RMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond reputeRMKen has a reputation beyond repute
  #13
Old 02-08-2010, 09:55 PM
Ex-Flit's Avatar
Ex-Flit Ex-Flit is offline
Currently: Not set.
Ex-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond reputeEx-Flit has a reputation beyond repute
  #14
Old 02-08-2010, 09:57 PM
Basic Member
  #15
Old 02-08-2010, 10:21 PM
HighLineHooker HighLineHooker is offline
Currently: Not set.
Basic Member
HighLineHooker is an unknown quantity at this point
  #16
Old 02-08-2010, 10:29 PM
Basic Member
  #17
Old 02-08-2010, 10:31 PM
Basic Member
  #18
Old 02-08-2010, 10:39 PM
akassault akassault is offline
Currently: Not set.
Basic Member
akassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond reputeakassault has a reputation beyond repute
  #19
Old 02-08-2010, 10:50 PM
Basic Member
  #20
Old 02-08-2010, 11:14 PM
Currently: Not set.
Basic Member
  #21
Old 02-08-2010, 11:21 PM
Basic Member
  #22
Old 02-09-2010, 02:12 AM
Wayniac Wayniac is offline
Currently: Gettin' stuck
Wayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant futureWayniac has a brilliant future
  #23
Old 02-09-2010, 07:46 AM
crf118r's Avatar
crf118r crf118r is offline
Currently: It's finally here!!
crf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond reputecrf118r has a reputation beyond repute
  #24
Old 02-09-2010, 08:22 AM
Basic Member
  #25
Old 02-09-2010, 11:26 AM
towngrunt towngrunt is offline
Currently: Not set.
towngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond reputetowngrunt has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
