Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-25-2010, 07:45 PM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default BDX oil delete, Caused 09 M1000 crank seize in 950miles running 40:1
To all the post I said I never had a problem, this is a direct result of the bdx oil delete. Just letting you know.
Put it in to there specification, no added oil tube or way get the required amount of lube to center of crank and it dried out center crank bearing and locked them up. Kinda BS. I figured they would know best and would have givin the info needed to do it right but guess not. Even though in the long run its my fault.
Sure liked the way it ran with the oil delete (till Now) But
The other thing that pi$$es me off is the fact I had to put it on because the AC oil injection was sticking and making my sled bog. with it off in my hand I can feel it sticking in the middle and can actually set it in the middle stuck.
BS call to AC on that one.
I ussually ran the sled fat on bottom to make sure it got plenty of oil but recently added a PCIII with the slp programing and it cleaned it up a bunch off bottom and may have caused it but maybe not.
You have been informed, don't be dumb like me. add a way to get oil to the center of crank.
Rate this post: Yes | No
  #2
Old 01-25-2010, 07:54 PM
snowmobiler snowmobiler is offline
Currently: Not set.
snowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond repute
Default
center crank bearings are lubed through the hole?
  #3
Old 01-25-2010, 07:58 PM
M1000Mod162 M1000Mod162 is offline
Currently: Hoping for Deep SNOW!!!!
M1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond reputeM1000Mod162 has a reputation beyond repute
Default
Wow man thats a bummer deal! I had a simmilar deal happen last year only my waterpump/oil pump shaft broke in two and took out the center mag beiring and the copper spline shaft on my crank but i didint thing to blame it on the oil delete! I had about 1200 miles on it with the oil delete when that happened. Now you have me worried
  #4
Old 01-25-2010, 08:03 PM
swashbukler swashbukler is offline
Currently: Not set.
Basic Member
swashbukler is an unknown quantity at this point
Default Oil delete
So whats the right way to do this drill cases or what? I have really been considering doing this but want to know what the right way to go about thanks
  #5
Old 01-25-2010, 08:21 PM
smoothdawg's Avatar
smoothdawg smoothdawg is offline
Currently: '16 AXYS
smoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond reputesmoothdawg has a reputation beyond repute
Default
Same thing happened to us last year Wyoboy. The BDX kit only lasts when you relocate the oil lines on the bottom of the motor like Shain Stanger does. I have rebuilt 2 M1000 motors with good luck. Buy a reman crank from AC, it will be cheaper in the long run. They are around 800.00, maybe less from a sympathetic dealer. Sorry for your trouble. May as well add the extra motormount and torque stop while you are at it. JMO.
__________________
09 M1000 SP 162. Twisted Race Gas kit. Finally happy with a quality kit. Thanks Shain.
The Following 2 Users Say Thank You to smoothdawg For This Useful Post:
Deepsnowisthewaytogo (12-05-2010), WyoBoy1000 (01-26-2010)
  #6
Old 01-25-2010, 09:10 PM
Default
im confused how would drilling the cylinders help the problem
  #7
Old 01-25-2010, 09:50 PM
AaronBND's Avatar
AaronBND AaronBND is online now
Currently: Not set.
AaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond repute
Default
Researching and putting a lot of thought into doing the BDX oil delete kit myself a few weeks ago, I honestly think you had trouble because we need to mix a stronger premix than BDX recommends. Maybe like 32:1 instead of 40:1. Looking at the pictures below of a M1000 case, you will see that the center section where the waterpump shaft is, is completely sealed off by the inner crank bearing seals. In the second picture, I also marked where the oil ports are on the outside of these seals in the case, to lube these inner crank bearings. You can also see in the second picture where these holes literally drop premix right into the bearings. In the second picture you can see where the seals ride in the case telling us that no premix can get in or out of that center section. This is why guys put the grease zerk in to lube the waterpump shaft. Honestly to me, it makes no sense at all drilling the cylinders to run premix down in this waterpump shaft section. How would the fuel part possibly get burnt? Engine heat evaporation? It sucks that it happened, but let it be a lesson to us guys that run it, to mix stronger than recommended.
The Following 5 Users Say Thank You to AaronBND For This Useful Post:
Arctic Thunder (01-26-2010), Deepsnowisthewaytogo (12-05-2010), HCM (02-20-2011), pindallout (02-21-2011), RideGuy (01-31-2010)
  #8
Old 01-26-2010, 09:35 AM
smoothdawg's Avatar
Currently: '16 AXYS
Default
Mix it 20:1 and you will still have a problem. You drill 1 hole in the case not the cylnders. You run a line with the fittings you already have from the hole BDX wants you to plug to a spot in the bottom of the case where the oil pools and hook another fitting that you already have there with a clear piece of line in between. The vaccum will pull from the pooled oil in the bottom of the case to the other side. Don't believe me? Look at the clear line between the 2 holes.
Shain Stanger took the time to go over this with me in great detail at the begginning of the year and explained how this works. Keep in mind this is what they are doing on the Twisted AC kits with no problems at all. Just trying to help.
__________________
  #9
Old 01-26-2010, 09:51 AM
smoothdawg's Avatar
Currently: '16 AXYS
Default
If you pull the crank out you will see the hole BDX wants you to plug with their supplied bolt. That is where the brass gear is oiled from. There is even a line running from your stock oilpump right to it. Make sense now?
Ours stripped all of the teeth off of the brass gear and bent the oilpump\waterpump driveshaft about a half inch.
Ever notice whenever you split the cases on ANY 2 stroke there is always a puddle of oil in the bottom of the cases? That's where you get the small amount of oil for your brass gear when you drill and tap the hole. Hope this helps paint a clearer picture of what I was trying to say.
__________________
  #10
Old 01-26-2010, 10:03 AM
JHG JHG is offline
Currently: Not set.
JHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond repute
The Following 2 Users Say Thank You to JHG For This Useful Post:
  #11
Old 01-26-2010, 10:08 AM
Click Here to Register
The Following User Says Thank You to M1000Mod162 For This Useful Post:
Motive (11-30-2011)
  #12
Old 01-26-2010, 11:04 AM
Vertical-Extreme's Avatar
Vertical-Extreme Vertical-Extreme is offline
Currently: Braaaaap
Vertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond repute
Garage
The Following User Says Thank You to Vertical-Extreme For This Useful Post:
  #13
Old 01-26-2010, 01:25 PM
mountaincat68papa mountaincat68papa is offline
Currently: not set
mountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond reputemountaincat68papa has a reputation beyond repute
The Following User Says Thank You to mountaincat68papa For This Useful Post:
  #14
Old 01-26-2010, 01:28 PM
BigAir's Avatar
BigAir BigAir is offline
Currently: Still missin' the old SnoWest
BigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond repute
The Following User Says Thank You to BigAir For This Useful Post:
  #15
Old 01-26-2010, 02:23 PM
AaronBND's Avatar
Currently: Not set.
  #16
Old 01-26-2010, 03:14 PM
backcountryislife's Avatar
backcountryislife backcountryislife is offline
Currently: almost ready for winter
backcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond repute
The Following User Says Thank You to backcountryislife For This Useful Post:
  #17
Old 01-26-2010, 03:25 PM
WyoBoy1000's Avatar
Currently: Working,
  #18
Old 01-26-2010, 03:42 PM
bgreen776's Avatar
bgreen776 bgreen776 is offline
Currently: gimping around
bgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond repute
The Following 2 Users Say Thank You to bgreen776 For This Useful Post:
catunder (02-25-2011), Deepsnowisthewaytogo (12-05-2010)
  #19
Old 01-26-2010, 05:28 PM
AaronBND's Avatar
Currently: Not set.
  #20
Old 01-26-2010, 06:00 PM
lynxer292b lynxer292b is offline
Currently: Workin on sledssss
lynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond reputelynxer292b has a reputation beyond repute
  #21
Old 01-26-2010, 06:14 PM
bgreen776's Avatar
  #22
Old 01-26-2010, 06:20 PM
bgreen776's Avatar
The Following User Says Thank You to bgreen776 For This Useful Post:
  #23
Old 01-26-2010, 06:35 PM
krom krom is offline
Currently: Gold Catmaster
Basic Member
krom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond reputekrom has a reputation beyond repute
The Following User Says Thank You to krom For This Useful Post:
bgreen776 (01-27-2010)
  #24
Old 01-26-2010, 07:02 PM
bgreen776's Avatar
  #25
Old 01-26-2010, 07:43 PM
AaronBND's Avatar
Currently: Not set.
The Following 2 Users Say Thank You to AaronBND For This Useful Post:
bgreen776 (01-26-2010), Deepsnowisthewaytogo (12-05-2010)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
