Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 01-25-2010, 12:15 PM
madmini660 madmini660 is offline
Currently: please snow in montana mountains
madmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond reputemadmini660 has a reputation beyond repute
Garage
Default has anyone pulled a brake off
Having trouble pulling the brake caliber off took my sled to the ski-doo dealer and they said I'd have to pull the chain case apart and push the hole shaft over to get the brake off but I didnt wont to do that if didn't have to
just asking because the ski-doo dealer had never done won before thanks
Rate this post: Yes | No
  #2
Old 01-25-2010, 12:37 PM
Rally2 Rally2 is offline
Currently: Not set.
Rally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond reputeRally2 has a reputation beyond repute
Default
The manual seems to indicate you can remove the brake rotor & caliper without touching the chaincase side.
My concern is that once you get the caliper/bearing housing off the driveshaft has no support on that side and sags down quite a bit until resting on the retainer (still locked in the tunnel with the tabs).
With the shaft hanging down like that I think it would be hard on the seal, bearing, gear, circlip still all attached in the chaincase side.
  #3
Old 01-25-2010, 12:54 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Lay the sled on the side and loosen the track so it's not pulling on the driveshaft. Pull the disc cover and then the brake pad retainer bolt (and that little clip), and then the 4 #40 Torx bolts and the circlip on the disc....then the caliper assy. will come off. Easiest to use the puller from Doo, but will come off with a little heat (not too much, don't cook the caliper), and some gently prying usually gets it.
The Following User Says Thank You to winter brew For This Useful Post:
dingalingman1 (01-12-2018)
  #4
Old 01-10-2018, 09:34 PM
andyhollin andyhollin is offline
Currently: Not set.
Basic Member
andyhollin is an unknown quantity at this point
Default
Obviously this is an old thread but I've run into the same question.
If I *only* need to replace the brake rotor and pads (not changing the track) do I need to get into the chaincase side of things? I will if I have to, just don't want to if it's not needed.
  #5
Old 01-12-2018, 12:46 PM
Currently: Not set.
Default
No, it can all happen from the brake side.
1 out of 1 members found this post helpful. Rate this post: Yes | No
andyhollin (01-12-2018)
  #6
Old 01-12-2018, 01:04 PM
Currently: Not set.
Basic Member
Default
Quote:
Thank you! I'm going to give it a shot later today. I got the C&T tool so I'm hoping it's not a huge pain.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
