Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 12-24-2009, 05:06 PM
NEWDUCK NEWDUCK is online now
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default 96 580 powder special problems
This sled used to rip for what it was. Would smoke my 700 mtn cat in a powder climb. It was my buddies who has passed away and I ended up with it. The sled is carbed and is running psi pipes. On the flats down in the valley it hits 7500 max rpms. Where do these motors want to run at? this seems low I was thinking 8200ish. Now when I go up in the foothills the sled runs horrible. Pulls a hill around 6000grand. Before my buddy died this sled ran amazing. I have changed nothing since I got it. I had the sled in higher elevations in a meadow and when I would give it gas it would let the clutches engage then just die. As I started to ride lower in elevation it ran better. Allt comp gone bad? Any idea where to start with this B? Would really like to get it going for a second sled for people to ride.
Rate this post: Yes | No
  #2
Old 12-24-2009, 05:21 PM
rdr99 rdr99 is offline
Currently: Not set.
Basic Member
rdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond repute
Default
Start with the basics. Clean clutches, check for broken springs, clean carbs, make sure a mouse wasn't living in the pipes.
  #3
Old 12-24-2009, 05:28 PM
Basic Member
Default
Cleaned carbs. Primary has all brand new parts. Pipes seem clear dont sound plugged up. I was thinking its either electrical or the altitude comp is messed up.
  #4
Old 12-25-2009, 04:05 PM
sdsnocop sdsnocop is offline
Currently: Not set.
sdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond reputesdsnocop has a reputation beyond repute
Default
Sled should run at 8000-8200 with a stock pipe (I do not know if different with performance pipe). With altitude compensator my 97 PS runs a 380 main. The compensator is designed to fail at a rich setting so check the plug color. A black oily color indicates a rich condition. I am not sure the jetting required for that sled with the compensator disconected but if it was my sled I would start with 250-260 mains at 5000-6000 feet and check plug color. If youir plug color is good (light to medium brown) I would concentrate on clutch problems.
  #5
Old 01-03-2010, 05:48 PM
Basic Member
Default
Think that running without the carb boots would cause the compensator to freak out? Right now it has none and I just noticed it today. Think I might order a set
  #6
Old 01-03-2010, 05:55 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default
your not kidding those sleds ripped...!!!!...black magic and psi got them sleds wicked performance...and climb with the plastic paddles in those days...man alive your post brought back memories...!!!!
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
  #7
Old 01-13-2010, 03:55 PM
Basic Member
Default
Running 410 mains. In the valley its at 4600 ft and I ride up to 10000. Think I should just can the altitude compensator and start at 250? Or keep it and still jet down and see what happens
  #8
Old 02-16-2010, 11:06 PM
Rixster's Avatar
Rixster Rixster is offline
Currently: I love you El Nino
Rixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond repute
Garage
Default
Can it and start jetting. Did it on many a 580 back in the day.
__________________
Custom built sled decks contact me for details
A.K.A."Seth"
06 M7 CPC Dragoncat 1000 162
F350 crewcab
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and Screaming "WOO" What a ride!
KCCO
  #9
Old 01-19-2015, 10:00 AM
Basic Member
Default
Sled has sat for 5 years..wow. anyways my nephew wants to ride it so we started jetting it. So far wide open it rips with 270 mains. The bottom end is a dog. Its at a 75 pilot and wants more. I think something is wrong with these carbs or a possible boot leak. Anyone have an idea?
  #10
Old 01-29-2015, 02:08 PM
All_talk All_talk is offline
Currently: Not set.
Basic Member
All_talk is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
