Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
View Poll Results: what would be your choice of track
no ports 203 50.75%
mildly ported 150 37.50%
full porting 47 11.75%
Voters: 400. You may not vote on this poll
Reply
  #1
Old 11-03-2009, 10:07 PM
summitdude summitdude is offline
Currently: Not set.
Basic Member
summitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond reputesummitdude has a reputation beyond repute
Default Ported track poll
seems like few people think that Doo went overboard with porting tracks on newer moutain sleds! they dont seem to water skip so well(which dont seem to concern most)...but may possibly lose some floatation on the snow as well...and/or other concerns!
it would be nice if Doo would offer track options again!
***no porting
***mildly porting
***full porting
what would be your choice and why??
Rate this post: Yes | No
  #2
Old 11-04-2009, 07:40 AM
fassteddie fassteddie is offline
Currently: well stated jim. thanks ed
fassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond repute
Default
doo did go off the deep end and so will you if your water skipping.after some real good powder riding to compare, there is a big advantage between ported and non ported side by side. sleds set up vary close and switching riders. farther up the hill and less skid frame build up. i ordered the non ported for the wifes 010 xp 154 track exchange program.i run 2.5 155 2.86 extreme on my 010 xp.worked great on my 09. ski doo should have gone with the 06 size porting. now i have the option to port if i want. the 06 track water skipped across lake callahan with no problems
  #3
Old 11-04-2009, 10:27 PM
Currently: Not set.
Basic Member
Default
did this track exchange cost you anything??
i may look at this before i pickup my sled! if i can change the track for a comparable one without porting i'd probably do it... depending on the cost!
thanks for any info!!
  #4
Old 11-05-2009, 08:05 AM
Default
it's suposed to be $200.some dealers charge and some don't. but with that said it also depends on what you paid for your sled call your dealer see what they will charge if anything.
The Following User Says Thank You to fassteddie For This Useful Post:
summitdude (11-05-2009)
  #5
Old 11-05-2009, 06:14 PM
Dock Dock is offline
Currently: Not set.
Dock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond reputeDock has a reputation beyond repute
Default
I run my stock 09 XP beside my Buddies stock 06 and he goes way further, crazy thing is we both get the same track speed. ported...? never again just put my 2.5 Extreme 146 on
  #6
Old 11-05-2009, 06:20 PM
akpowrider akpowrider is offline
Currently: Not set.
Basic Member
akpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond reputeakpowrider has a reputation beyond repute
Default
My ported xp track gets a ton of "ice dingleberries" due to all of the freying in the ports. If rotary mass is 7 times heavier, it makes it much worse. This only happens in the pow pow.
  #7
Old 11-05-2009, 06:43 PM
BankBuster BankBuster is offline
Currently: Not set.
Basic Member
BankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant futureBankBuster has a brilliant future
Default
Don't know if this is related; but I use a small propane torch (like one you'ld use to solder copper pipes) to burn off any little pieces of rubber or string that is around the holes in the track (or the edges of track). This reduce the amount of ice balls going around with the track and cleans up the track so it looks better even when it's dry/out of the snow,,,
  #8
Old 11-05-2009, 08:23 PM
PJ-Hunter's Avatar
PJ-Hunter PJ-Hunter is offline
Currently: Gotta get a couple more rides in...
Paid Premium Member
PJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond repute
Garage
Default
Full porting. Fraying? That can be solved with a handheld propane torch and 10 minutes.
Buying a 11k sled and worrying about water skipping? Go find a cheap stand up jet ski.
__________________
Colorado Forum Ride.
2009 T-XP 154
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to PJ-Hunter For This Useful Post:
imdoo'n (09-28-2012), skippyh2o (01-07-2014)
  #9
Old 11-05-2009, 09:35 PM
Currently: Not set.
Basic Member
Default
thanks for the info fassteddie!
if a solid track does better then a ported in the deep..then this is something Doo should look into. one of my big concerns is tearing the track catching something under the pow......these tracks are not so cheap to replace!
  #10
Old 11-05-2009, 10:08 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to akpowrider For This Useful Post:
theultrarider (11-05-2009)
  #11
Old 11-05-2009, 10:52 PM
theultrarider theultrarider is offline
Currently: still a rebel way back in the country
theultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond repute
Click Here to Register
  #12
Old 02-13-2011, 07:32 AM
cabinman cabinman is offline
Currently: Not set.
cabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond reputecabinman has a reputation beyond repute
  #13
Old 02-13-2011, 01:55 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
The Following User Says Thank You to fredw For This Useful Post:
  #14
Old 02-13-2011, 02:57 PM
Reeb's Avatar
Reeb Reeb is online now
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
  #15
Old 02-13-2011, 08:34 PM
MURDOCK MURDOCK is offline
Currently: hung over
Basic Member
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
  #16
Old 02-13-2011, 08:47 PM
Basic Member
  #17
Old 02-13-2011, 09:40 PM
9 Iron 9 Iron is offline
Currently: Not set.
Basic Member
9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute9 Iron has a reputation beyond repute
  #18
Old 02-13-2011, 10:10 PM
Basic Member
  #19
Old 02-14-2011, 06:25 PM
xpbadonkadonk xpbadonkadonk is offline
Currently: Not set.
Basic Member
xpbadonkadonk is an unknown quantity at this point
  #20
Old 02-14-2011, 07:54 PM
Yella Belly's Avatar
Yella Belly Yella Belly is offline
Currently: Not set.
Yella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond reputeYella Belly has a reputation beyond repute
  #21
Old 02-15-2011, 06:58 PM
Currently: Not set.
Basic Member
  #22
Old 02-15-2011, 07:48 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
  #23
Old 02-15-2011, 09:39 PM
Basic Member
  #24
Old 02-15-2011, 09:47 PM
Currently: Not set.
Basic Member
  #25
Old 02-15-2011, 11:12 PM
1Mike900 1Mike900 is offline
Currently: Not set.
1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
