Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 09-14-2009, 01:17 PM
manowar manowar is offline
Currently: I've lost my self so im going to find me if you see me let me konw that im trying to find my self..
Basic Member
manowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond repute
Garage
Default Genral maintance for GEN 2 sleds.
These sleds are getting older now and keeping them up is most inportant now more then ever . Post up genral prone problems and the fixes you know of . Some of the main things to stay on top of are changing oil in chain case yearly and clutch maint. grease all zerk points and rear skid. watch hifaxes . Carbs clean and working properly . check reeds and carb boots.
Rate this post: Yes | No
The Following User Says Thank You to manowar For This Useful Post:
Scott (10-16-2009)
  #2
Old 09-14-2009, 01:33 PM
cmud cmud is offline
Currently: Not set.
Basic Member
cmud is an unknown quantity at this point
Default
replace the water pump belt, if it goes you are sol
The Following User Says Thank You to cmud For This Useful Post:
Scott (10-16-2009)
  #3
Old 09-14-2009, 10:07 PM
Basic Member
Garage
Default
Perfect keep it going guys . Yes water pump belts are prone to fail on the BB twins after a few years i recomend doing then yearly.
Scott (10-16-2009)
  #4
Old 09-14-2009, 10:24 PM
MORSNO's Avatar
MORSNO MORSNO is offline
Currently: Getting my Wolverine R-Spec ready for summer fun!
MORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond reputeMORSNO has a reputation beyond repute
Garage
Default
Don't forget about replacing your clutch springs and worn jets. These are items that wear but are often forgotten.
__________________
2007 RMK Dragon 700
SLP Pipe/Can Flowrites Vents Airhorn, DTR Tuned PC-V, 19/42 Gears, .375/47 Springs, 5/8" Swing Arm Relocation, Carbide Slidekicks, HD Better Boards, Better Bars, Skinz Bumper, Mountain Addiction TrackRack, Rox FlexTec's, TCP Walker Evans Needles/Dual Rate Springs Front & Rear, AKSNOWRIDER Rear Bumper/Tunnel Support
2012 GMC SLT 2500HD & 16' Aluma Trailer
The Following User Says Thank You to MORSNO For This Useful Post:
Scott (10-16-2009)
  #5
Old 09-15-2009, 10:05 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
This is maintenance for all sleds. Remove the skid frame and check all cross shafts for wear. Replace if needed. When you have them out you can clean out the tubes that they sit in because there is usually some old dried grease in there. Good time to check the wheel bearings for roughness. Check hyfax for wear. They are a lot easier to change with the skid out. Check exhaust springs to see if any are missing. Tighten exhaust manifold bolts for tightness. If oil is leaking from them replace the gaskets.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
Scott (10-16-2009)
  #6
Old 09-15-2009, 11:18 AM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
Make sure you driveshaft and jackshaft bearings are still good...and lubed too.
Replace chain.
Crankshaft runout.
Steering post bent?
Ski skegs?
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #7
Old 09-15-2009, 11:35 AM
Bubbles Bubbles is offline
Currently: Not set.
Basic Member
Bubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond reputeBubbles has a reputation beyond repute
Default
Quote:
wherer do you buy your jtes? Dealer or on line?
The Following User Says Thank You to Bubbles For This Useful Post:
Scott (10-16-2009)
  #8
Old 10-16-2009, 11:32 AM
JustinB JustinB is offline
Currently: #lumberjack
JustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond reputeJustinB has a reputation beyond repute
Garage
Default
Check compression if it blows on the mountain you might have to hike out. Look at your belt surprised no one said this. also look at your track found 3 screws in my paddles this year??? With racing moto check all bolts on the sled had my drive clutch bolt back out and screwed the whole clutch last year.
The Following User Says Thank You to JustinB For This Useful Post:
Scott (10-16-2009)
  #9
Old 10-20-2009, 04:58 PM
ice man ice man is offline
Currently: pro for now
ice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond reputeice man has a reputation beyond repute
Cool gen 2
don"t forget to adjust throttle and oil cable,check carb boots at boost bottle and that weak front motor mount
The Following User Says Thank You to ice man For This Useful Post:
Scott (10-20-2009)
  #10
Old 11-03-2009, 03:05 PM
kinnr3's Avatar
kinnr3 kinnr3 is offline
Currently: Not set.
kinnr3 is an unknown quantity at this point
  #11
Old 11-28-2009, 05:13 PM
polari1man polari1man is offline
Currently: Not set.
Basic Member
polari1man is an unknown quantity at this point
Click Here to Register
  #12
Old 01-13-2010, 09:29 PM
cordoba83 cordoba83 is offline
Currently: Not set.
Basic Member
cordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nicecordoba83 is just really nice
  #13
Old 12-14-2010, 04:11 PM
flying pig flying pig is offline
Currently: pull rope and pound big snow!
flying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond reputeflying pig has a reputation beyond repute
  #14
Old 12-26-2010, 03:01 PM
baddodges baddodges is offline
Currently: Not set.
Basic Member
baddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond reputebaddodges has a reputation beyond repute
  #15
Old 02-21-2011, 12:39 PM
X2Freeride X2Freeride is offline
Currently: Old School
X2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond repute
The Following User Says Thank You to X2Freeride For This Useful Post:
CHIA_PET74 (06-19-2011)
  #16
Old 01-03-2012, 02:20 PM
sniperjms sniperjms is offline
Currently: Not set.
Basic Member
sniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant futuresniperjms has a brilliant future
The Following User Says Thank You to sniperjms For This Useful Post:
indyseriesnick (11-25-2012)
  #17
Old 01-03-2012, 03:15 PM
Scott's Avatar
Garage
  #18
Old 01-18-2012, 06:21 PM
C S Fever C S Fever is offline
Currently: Waitin... turbo... snow...
C S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond reputeC S Fever has a reputation beyond repute
  #19
Old 05-23-2012, 02:44 AM
theultrarider theultrarider is offline
Currently: still a rebel way back in the country
theultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond repute
  #20
Old 05-23-2012, 07:08 AM
judger101 judger101 is offline
Currently: Not set.
judger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond reputejudger101 has a reputation beyond repute
  #21
Old 11-25-2012, 08:48 AM
indyseriesnick's Avatar
indyseriesnick indyseriesnick is offline
Currently: Doing the annual "tearing apart the sled and cleaning"
indyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond reputeindyseriesnick has a reputation beyond repute
Garage
  #22
Old 12-20-2012, 01:30 AM
flyguy_17 flyguy_17 is offline
Currently: Gettin the itch!
Basic Member
flyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond reputeflyguy_17 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
