Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 09-12-2009, 08:26 PM
FNG FNG is offline
Currently: Not set.
FNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant futureFNG has a brilliant future
Default How to lighten a ZX ?
I can't be the only one on this board who wasn't born into a sleddng family or who doesn't have a long list of sledding buddies right down the road to ask so I'll throw it out here. I am admittedly a recent arrival to sledding and am operating on a budget and I've ended up with a good solid 2001 Summit 700 ZX, 144 x 15 x 2 track as a first sled. Last season was great but this thing isn't a feather to push around that's for sure.
I've seen many posters mention lightning their ZX sleds, how do you go about doing it? My sled already has an aftermarket can (muffler) which is much smaller and lighter than the stock suit case that usully sits in there but what else
Hopefully this will be a usefull (source list) for others with the same questions.
Cheers
Rate this post: Yes | No
  #2
Old 09-12-2009, 08:53 PM
deboer's Avatar
deboer deboer is offline
Currently: counting the minutes tell I can ride my PRO!!!!!!!!!
deboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond reputedeboer has a reputation beyond repute
Default
a couple ways to go about that would be by getting
a boss set= thats a couple pounds
light wieght hood (i think skinns protive gear makes one) = probly about 10lbs there
headlight delete=a couple pounds but then you cant see at night
poweder coat your rails and if you dont like to polish your tunnel you can poweder coat you tunnel too= that will get ride of snow build up in deep poweder
port your track = 1) less rotating mass=less wieght and more HPs 2) snow doesnt build up as much eighter
__________________
Snowest youngest MAX REPPER 42K 2K
Polaris 08 600 RMK 155" white 09 plastic, air frames
  #3
Old 09-12-2009, 09:00 PM
maxwellzx maxwellzx is offline
Currently: Not set.
maxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond reputemaxwellzx has a reputation beyond repute
Default
heres what i did....
lexan hood
deleted all electronics and guages and lights
running a digatron insead
deleted oil injection
deleted all skid wheels except rear 2
boss seat
dynoport can and pipe way lighter
i pretty much have it down to bare bones. going to weigh it soon
  #4
Old 09-12-2009, 09:23 PM
deboer's Avatar
Default
also to eliminate snow build up on your running board you could get a set of betterboard or snoweleminaters
__________________
  #5
Old 09-12-2009, 09:44 PM
Flit8.0 Flit8.0 is offline
Currently: Not set.
Basic Member
Flit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond reputeFlit8.0 has a reputation beyond repute
Default
The one me and my boy built is:
'01 Summit 800
lexan hood
avenger II
boss seat
fabcraft carbon fiber arms
2 inner 8" wheels
simmons skiis
better boards
dynoport pipe and thing can
150x16x2.5 track
fly bars and 8" risers
'bout as light as I can get it.
Would like to get a shorty highrise seat though.
  #6
Old 09-13-2009, 12:00 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
I had a '01 800 with 151. I had Lexan hood, removed oil injection, silencer, no bogie wheels, no sway bar.....with as much gas as I could siphon out it was still 535lbs on certified scale!! They were heavier than advertised, but a very easy chassis to ride, I had a blast on that sled.
  #7
Old 09-14-2009, 02:55 PM
Canuk Canuk is offline
Currently: Not set.
Basic Member
Canuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond reputeCanuk has a reputation beyond repute
Default
the big weight is not cheap to remove but it comes off in piles, relative to a rev or xp.
biggest losers are:
boss seat vs. stock.
Mountain Mod/lexan hood (no lights and gauges) vs. stock.
(i have a fog light bolted to my riser.. works good).
also have done the following.
pipe and can, led tail light, no bogie wheels., powder hound skis.
  #8
Old 09-14-2009, 04:34 PM
Currently: Not set.
Default
does anyone know the savings running no electronics.
my hood with guages and light were rediculously heavy. not sure # tho.
  #9
Old 09-14-2009, 07:12 PM
Motley Doo Motley Doo is offline
Currently: college food stamps for parts anyone?
Basic Member
Motley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond reputeMotley Doo has a reputation beyond repute
Default
Yeah, the hoods are super flexible and hard to really hurt, but HEAVY!
  #10
Old 09-14-2009, 09:39 PM
breakingsomum breakingsomum is offline
Currently: Not set.
Basic Member
breakingsomum is an unknown quantity at this point
  #11
Old 09-14-2009, 09:59 PM
Currently: Not set.
Click Here to Register
  #12
Old 09-14-2009, 10:36 PM
Currently: Not set.
Basic Member
  #13
Old 09-14-2009, 11:25 PM
AKrider AKrider is online now
Currently: Not set.
Basic Member
AKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond reputeAKrider has a reputation beyond repute
  #14
Old 09-15-2009, 09:41 AM
deboer's Avatar
  #15
Old 09-17-2009, 02:11 PM
zeke zeke is offline
Currently: Not set.
zeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond reputezeke has a reputation beyond repute
  #16
Old 09-17-2009, 04:55 PM
Basic Member
  #17
Old 09-17-2009, 07:58 PM
Currently: Not set.
  #18
Old 09-17-2009, 10:11 PM
FNG FNG is offline
Currently: Not set.
  #19
Old 09-17-2009, 10:20 PM
FNG FNG is offline
Currently: Not set.
  #20
Old 09-18-2009, 01:57 PM
deboer's Avatar
  #21
Old 09-18-2009, 11:23 PM
Wade Wade is offline
Currently: Not set.
Basic Member
Wade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond reputeWade has a reputation beyond repute
  #22
Old 09-21-2009, 03:51 PM
LB_ LB_ is offline
Currently: Not set.
Basic Member
LB_ is an unknown quantity at this point
  #23
Old 09-22-2009, 12:19 PM
shankster shankster is offline
Currently: Not set.
Basic Member
shankster is an unknown quantity at this point
The Following User Says Thank You to shankster For This Useful Post:
Motley Doo (09-22-2009)
  #24
Old 09-22-2009, 12:38 PM
Basic Member
The Following User Says Thank You to Motley Doo For This Useful Post:
shankster (10-03-2009)
  #25
Old 09-23-2009, 11:34 AM
deboer's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
