Upgrade to Premium
SnoWest Announcements This forum is for announcements from your web administrators to all members of the SnoWest Forums.
Reply
  #1
Old 09-10-2009, 10:00 AM
christopher's Avatar
christopher christopher is online now
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default SNOWEST FORUMS: Why did my POST COUNT drop ??????
Last night we ran all of the VBulliten Maintenance modules in an attempt to get all of the databases cleaned and optimized as much as possible to get a handle on the constant unending "DATABASE ERROR" reports.
Part of this standard maintenance run is to have all of the "Counters" on the forums Re-Count.
This means that VBulliten goes through every single post, and re-counts all attributes of it, and then rebuilds the master counters lists.
While I have done this many many many times in the past, I have NEVER seen people's post counts DROP like this.
Many people are reporting MASSIVE drops in post count!
Please understand that not one single person on SnoWest had their post counts lowered on purpose. This was a fully automated process that is built into the forums and designed to be run on a regular basis.
The only thing that MIGHT explain this, is if those post counts that you had yesterday were NOT from "THIS" forum. If those counts were carried forward from some previous forum where all of the historical posts were not fully/properly imported into the VBulliten system, then the new post counts would be 100% accurate for all the posts you have made since "THIS" forum was launched a couple years back.
I will get looking into this today to try and see whats going on.
__________________
Rate this post: Yes | No
The Following 5 Users Say Thank You to christopher For This Useful Post:
Arctic Thunder (09-10-2009), BigJake (09-10-2009), Scott (09-10-2009), smokindave (09-18-2009)
  #2
Old 09-10-2009, 10:04 AM
Super B Super B is offline
Currently: 2012 Pro
Super B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond reputeSuper B has a reputation beyond repute
Garage
Default
From what I gather, back in Nov. of '07, SW went to a new format. During that change, our join date and post counts were reset. Alan (the old Mod AC) manually changed our join dates and post counts as requested by the member. Christopher did a maintenance feature that removed what AC manually entered a few years ago.
The Following User Says Thank You to Super B For This Useful Post:
  #3
Old 09-10-2009, 10:13 AM
speeddemon speeddemon is offline
Currently: It is good It is great bend over ill give u 8"
speeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond reputespeeddemon has a reputation beyond repute
Default
glad to see ur looking into it ! i know alot of people will be upset on here because of this ! thanks for trying to fix it !!!
mike
  #4
Old 09-10-2009, 10:24 AM
BIGGDAWG BIGGDAWG is offline
Currently: Not set.
BIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond reputeBIGGDAWG has a reputation beyond repute
Garage
Default
i was just going to ask this same question. went from 1300 to 600 oh well just the way it is. i ain't no post whore anyhow
The Following User Says Thank You to BIGGDAWG For This Useful Post:
silvertip (09-25-2009)
  #5
Old 09-10-2009, 11:46 AM
Garage
Default
Its almost certainly a case of HAND SET POST COUNT values that were brought into the new forum.
Those values represented your HISTORICAL POSTS and not the posts that actually appear on this forum.
__________________
  #6
Old 09-10-2009, 01:01 PM
Ex-Member Ex-Member is offline
Currently: MULE
Ex-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond reputeEx-Member has a reputation beyond repute
Default
Copypasta from ....
Quote:
Quote:
Originally Posted by christopher View Post
I think you are EXACTLY CORRECT.
While I do NOT yet know this for certain.
It "APPEARS" that when the old database was imported from the previous forums, not all the posts came over, but your post count did.
So when the counters went through the current database they didn't find all of the old posts from the previous forums, and your post counts were adjusted to reflect ONLY what is available on this forum.
Old forums were totally dropped. Those that requested their numbers (Join date and post count) be transferred had them overwritten by admin/bigd. Post/join was an offset value from what VBulletin saw.
I just re-ran the counter by hand.
DID ANYONE'S POST COUNT JUST JUMP UP?
Uhm, yeah... by ... a lot... lol
if it recounted -everything-, even posts from deleted threads, I could see my post count being 30k+... but 40k sounds pretty high.
  #7
Old 09-10-2009, 03:02 PM
Garage
Default
The post count numbers are stable and TRUE now.
They are the actual posts that can be found on this forum right now.
__________________
  #8
Old 09-10-2009, 03:10 PM
Currently: MULE
Default
holy crap.... i am a post whore
  #9
Old 09-10-2009, 05:00 PM
RMKRIDER RMKRIDER is offline
Currently: I'm the orginal RMKRIDER!
Basic Member
RMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond reputeRMKRIDER has a reputation beyond repute
Default
I went from 4000 to 400?
  #10
Old 09-10-2009, 05:07 PM
Garage
Default
The Information Technology department at Harris Publishing is TRYING to locate one of the old archived copies of the previous forum.
But so far NO LUCK.
May take a couple days to find it as it was NOT where they thought it had been stored.
If we find it, I THINK I will be able to recover a great deal of your post counts AS WELL AS your actual posts!
If not, then we are stuck with what we now have.
__________________
  #11
Old 09-10-2009, 05:15 PM
Currently: MULE
Click Here to Register
  #12
Old 09-10-2009, 06:04 PM
Nubulin Nubulin is offline
Currently: Not set.
Nubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond reputeNubulin has a reputation beyond repute
  #13
Old 09-10-2009, 06:21 PM
Mountain Doo Mountain Doo is offline
Currently: Walking on Snow
Basic Member
Mountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant futureMountain Doo has a brilliant future
The Following User Says Thank You to Mountain Doo For This Useful Post:
MOONMAN (09-10-2009)
  #14
Old 09-10-2009, 07:00 PM
happylilcuss happylilcuss is offline
Currently: Not set.
Basic Member
happylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond reputehappylilcuss has a reputation beyond repute
  #15
Old 09-10-2009, 07:07 PM
Garage
  #16
Old 09-10-2009, 07:54 PM
BigJake BigJake is offline
Currently: Not set.
BigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond reputeBigJake has a reputation beyond repute
The Following User Says Thank You to BigJake For This Useful Post:
ski-doober (09-10-2009)
  #17
Old 09-10-2009, 09:04 PM
Nikolai Nikolai is offline
Currently: Not set.
Nikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond reputeNikolai has a reputation beyond repute
  #18
Old 09-10-2009, 09:18 PM
Garage
  #19
Old 09-10-2009, 09:19 PM
Garage
  #20
Old 09-10-2009, 09:35 PM
Currently: Not set.
  #21
Old 09-10-2009, 09:38 PM
Garage
The Following User Says Thank You to christopher For This Useful Post:
let it snow (09-11-2009)
  #22
Old 09-10-2009, 09:44 PM
Currently: Not set.
  #23
Old 09-10-2009, 11:01 PM
akmc800 akmc800 is offline
Currently: Not set.
Basic Member
akmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond reputeakmc800 has a reputation beyond repute
Garage
  #24
Old 09-11-2009, 07:13 AM
let it snow let it snow is offline
Currently: In search of monster bulls..
Basic Member
let it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond reputelet it snow has a reputation beyond repute
  #25
Old 09-11-2009, 07:59 AM
Garage
Reply
Bookmarks
Tags
birds cooking pasta, lame
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
