Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 09-08-2009, 11:07 AM
2strokes_are_awesome's Avatar
2strokes_are_awesome 2strokes_are_awesome is offline
Currently: Not set.
2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute2strokes_are_awesome has a reputation beyond repute
Default Suspension settings for mountain riding
I'm riding a 00' 800 RMK 136"x2" and weigh 155ish with all my gear on.
What rear suspension settings should I be running to get a significant amount of transfer while maintaining a decent attack angle??????
I don't know how much difference the mods I have on it would make but I'll list them.
Escape seat(boss designed, -10lbs)
better boards
2 8" wheel kit
full slp exhaust and intake w/florites
hi-comp head
slp powder pro's
no swaybar
bar risers
Thanks in advance
Rate this post: Yes | No
  #2
Old 09-09-2009, 09:47 AM
augerin augerin is offline
Currently: Not set.
augerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond reputeaugerin has a reputation beyond repute
Default
If I remember right I had the swaybar removed also, fox extended travel shocks with the springs set light up front. In the back I had fox and heavy springs set at medium. I just played with mine constantly for about a year in different conditions until I found what worked for me and by the time I was done it was quite a difference. The sled was plyable and easy to throw around in the powder but could be a little tippy on the trail.
Good luck
The Following 2 Users Say Thank You to augerin For This Useful Post:
  #3
Old 09-09-2009, 09:38 PM
STRETCHITOUT STRETCHITOUT is offline
Currently: stretchitlogging for hire
Basic Member
STRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond reputeSTRETCHITOUT has a reputation beyond repute
Garage
Default
i run my limiter strap all the way down for the deep. mine has stock very wore out suspension i am running med up front and stiff in back i weigh 220... it's time for some new suspention thu
The Following User Says Thank You to STRETCHITOUT For This Useful Post:
  #4
Old 09-14-2009, 01:23 PM
manowar manowar is offline
Currently: I've lost my self so im going to find me if you see me let me konw that im trying to find my self..
Basic Member
manowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond reputemanowar has a reputation beyond repute
Garage
Default
Good work guys keep the info comming if we can get some more detialed info on this i can sticky it for us .
The Following User Says Thank You to manowar For This Useful Post:
2strokes_are_awesome (09-16-2009)
  #5
Old 09-15-2009, 11:22 AM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
You don't need a "significant amount" of weight transfer.
Your shock set up and limiter straps can be adjusted for ideal amount of transfer.
Ideal amount is to just have the skis skegs hovering above the snow on a climb...NOT wheelieing up the mtn. You are losing traction if you are doing that.
SLP does make a bolt on part to remount the top mount of your front rail shock for powder performance. I'd advise getting that.
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
The Following 2 Users Say Thank You to Scott For This Useful Post:
2strokes_are_awesome (09-16-2009), Clarke_67 (12-29-2010)
  #6
Old 09-15-2009, 01:45 PM
xc_rider08's Avatar
xc_rider08 xc_rider08 is offline
Currently: Not set.
xc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond reputexc_rider08 has a reputation beyond repute
Garage
Default
hey scott, how does that help by remounting the front shock???? Not sure if i understand??
thanks
__________________
Nothing better than two stroke smoke
Member of Roughrider Snowmobile Club
2011 Polaris Pro RMK 800 155"
1979 Polaris Gemini
  #7
Old 09-15-2009, 02:13 PM
Scott's Avatar
Garage
Default
The front shock angle is changed...it lays down just a bit more. It changes the skid geometry a little bit.
It supposedly helps get the GenII's up on top the powder better.
__________________
Ambassador for:
  #8
Old 10-03-2009, 11:08 PM
go high fast's Avatar
go high fast go high fast is online now
Currently: enjoying every minute of summer
go high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond reputego high fast has a reputation beyond repute
Default
I like a lot of weight transfer for hillclimbing.
What's worked for me are the stock torsion springs with the adjuster block in the softest position. Dial in some more pre-load on the skids front rear spring. Loosen up the limiter strap and keep it greased.
Even though i also have a gen II I cant remember if the xlite has multiple options on: 1) the stock drop brackets and 2.) where the suspension mounts to the rails..........if I recall sometimes these can also impact weight transfer. I would just stick with the stuff above.
To your list of mods I would a add a tunnel extension and 151 skid and track and you'll have a whole new machine.
__________________
see ya at the top!
The Following User Says Thank You to go high fast For This Useful Post:
Built not bot! (01-14-2012)
  #9
Old 05-09-2010, 10:56 AM
Norway's Avatar
Norway Norway is online now
Currently: gettin ready to ride!
Norway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond repute
Default
Need some more info here...
What I found this year is that there is a balance in the suspension regarding height and handling.
Got suspension mounting tips from Curtis at FTX and "adjusted" these a bit. Put my M-10 lower in the tunnel = higher sled, more clearance I thought.
Also has tall front suspension to match.
What I find is that on steep climbs it is very tippy!! It wants to steer to the sides and send you back down the mountain. The slightest touch of my skis on the snow pushes my front out from the hill, not to good!
I got my height and clearance, but it cost me climbing ability and I think it hurts the sidehilling/laying over in trees etc.
It seems the height coupled with a triple up front makes for a "go/no-go" sidehilling. You either manage to muscle it over, or it dives7tips down again.
My plan for the summer is to look at the bulkhead and see if it is worth re-doing to a lower engine (tubes or something) or just lowering the suspension.
Thoughts/comments?
__________________
«puny god»
http://revver.com/video/310519/a-dozen-more-turns/
  #10
Old 08-31-2010, 02:16 PM
MARV1's Avatar
MARV1 MARV1 is offline
Currently: On top of Moron Mtn. . .
MARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond reputeMARV1 has a reputation beyond repute
  #11
Old 02-21-2011, 01:31 PM
X2Freeride X2Freeride is offline
Currently: Old School
X2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond reputeX2Freeride has a reputation beyond repute
Click Here to Register
The Following 2 Users Say Thank You to X2Freeride For This Useful Post:
Built not bot! (01-14-2012), lescarpentier (05-13-2011)
  #12
Old 09-12-2011, 10:13 PM
cbc24 cbc24 is offline
Currently: IG: crozierc
cbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond reputecbc24 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
