Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 07-29-2009, 02:57 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Exclamation USEFULL 900/755 RMK/Switchback/Fusion LINKS
Check this Thread FIRST... CAREFULLY... before posting up any questions on your 900 or 2006 755 (2006 700 which is differnet from the 2007 and up CFI's)
Hopefully this post will keep people from asking the same questions, keep the posts from getting deleted and get YOU answers more quickly!!
This is a SIMPLE post that lists links relevant to the 2005/06 900 RMK/Switchback/Fusion and the 2006 700 (755cc) RMK/Switchback/Fusion .
This is to be a NO COMMENTS short cut to other posts with what you feel is valuable information related to maintenance, operation and aftermarket parts available for these sleds.
Please do not post up ANY comments on this thread.
Also, please occasionally "TTT" the threads that are linked to if you access them so that they do not get deleted by the system after a certain time.
If you find an interesting 900/755 thread on another forum or website... please feel free to post up a link on this thread.
This will keep the search process to a minimum and not require people to ask questions that have already been answered.
The format that I want to use is simple....
1) 1 line description of the thread
2) Link to the thread
Please DO NOT cut/paste contents of the other posts on this thread
__________________
Signature:
Rate this post: Yes | No
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
Bbender4 (09-02-2010), MacDawg productions (01-28-2010)
  #2
Old 07-29-2009, 02:58 PM
Default
I'll start with some of my posts....
2005 900 AND 2006 900/700.... Read Before you Buy http://www.snowestonline.com/forum/s...d.php?t=112723
900/755 RMK: Recoil housing removal Warning http://www.snowestonline.com/forum/s...d.php?t=117423
POLZINHUNTER's Rider Select Delete for the 2005 RMK Kicks Azz http://www.snowestonline.com/forum/s...d.php?t=152846
Skinz Protective Gear (SPG) Handlebars http://www.snowestonline.com/forum/s...ad.php?t=73628
Cleaning exhaust valves, how to http://www.snowestonline.com/forum/s...d.php?t=112042
Pre Season Check... Primary Clutch bolt http://www.snowestonline.com/forum/s...ad.php?t=80011
HOW TO PRIME THE FUEL PUMP ON POLARIS CFi http://www.snowestonline.com/forum/s...ad.php?t=73263
900 Iq Primary Install And Torque Procedures http://www.snowestonline.com/forum/s...ad.php?t=43530
Adding A Battery To The Rmk's For Gps Etc http://www.snowestonline.com/forum/s...ad.php?t=73256
INFO on CFI sleds Chassis Power Connectors, Relays and Grounds http://www.snowestonline.com/forum/s...ad.php?t=73220
Help For The Plastic Chaincase Covers http://www.snowestonline.com/forum/s...ad.php?t=74068
Some Mtn. Track Weights including the Polairs, Camo Ext, and AC Power Claw http://www.snowestonline.com/forum/s...d.php?t=150622
COMPFUSION's IMPROVED MOTOR MOUNTS FOR THE 900 IQ's - 2005 AND 2006 MODELS http://www.snowestonline.com/forum/s...ad.php?t=46232
Video For Tps Setting For Cfi Sleds http://www.snowestonline.com/forum/s...ad.php?t=72725
Better Kill switches, NOS switches http://www.snowestonline.com/forum/s...d.php?t=125131
__________________
Signature:
Last edited by 94fordguy; 02-06-2012 at 07:32 PM. Reason: Updated all Domain Names
The Following 5 Users Say Thank You to mountainhorse For This Useful Post:
94fordguy (02-07-2011), ColoradoMtnman (12-01-2017), happyhour (12-08-2009), LUBA (01-04-2010), sw (01-01-2010)
  #3
Default
From Super Dave3
2005 rmk 900 turbo http://www.snowestonline.com/forum/s...d.php?t=119472
From Ron
Polaris P85 Drive Clutch http://www.snowestonline.com/forum/s...ad.php?t=87640
Engine Break-In http://www.snowestonline.com/forum/s...d.php?t=103341
From IndyDan
Drive clutch balancing differances http://www.snowestonline.com/forum/s...ad.php?t=96366
NEW!!!! Polaris 900 Torque Master 1 http://www.snowestonline.com/forum/s...d.php?t=105378
** new ** torque master iii 800 bottom-end http://www.snowestonline.com/forum/s...d.php?t=126769
900 Polaris Crankshaft info http://www.snowestonline.com/forum/s...ad.php?t=89103
R U having problems getting your 900 clutch off?? http://www.snowestonline.com/forum/s...ad.php?t=61419
Polaris 900 PTO ENDS AND CRANKSHAFTS http://www.snowestonline.com/forum/s...ad.php?t=87985
Oil Confusion, simplified...... I hope. http://www.snowestonline.com/forum/s...ad.php?t=92802
Some others
Weight/ Helix/ Gear setup http://www.snowestonline.com/forum/s...d.php?t=115861
05/06 900 IQ Oil Pump cable solution http://www.snowestonline.com/forum/s...d.php?t=102337
http://www.snowestonline.com/forum/s...ad.php?t=46926
CRANK'N my 06 900 http://www.snowestonline.com/forum/s...ad.php?t=52811
2005 RMK 900 Piston's http://www.snowestonline.com/forum/s...ad.php?t=69339
05 900 RMK -- Pistons http://www.snowestonline.com/forum/s...ad.php?t=73572
Track clearance and track upgrades http://www.snowestonline.com/forum/s...d.php?t=123561
Check Engine Light (CEL) blink codes http://www.snowestonline.com/forum/s....php?p=1640974
http://www.snowestonline.com/forum/s...ad.php?t=92771
Another 08 and Earlier Front Bumper Option Coming Soon! http://www.snowestonline.com/forum/s...ad.php?t=93115
Skinz Protective Gear (SPG) products for the RMK http://www.snowestonline.com/forum/s...ad.php?t=97551
Treedog front bumper 05/06 900 http://www.snowestonline.com/forum/s...d.php?t=124654
05 900 clutching..CANT DECIDE..INPUTS PLEASE!! http://www.snowestonline.com/forum/s...d.php?t=122258
New front Plastic for 900 RMK http://www.snowestonline.com/forum/s...d.php?t=150365
Powering up the multi function display http://www.snowestonline.com/forum/s...d.php?t=147956
Ready to burn my 05 900 fusion http://www.snowestonline.com/forum/s...d.php?t=136442
torque measure on Poo900 front motormounts http://www.snowestonline.com/forum/s...ad.php?t=54926
900 RMK Electrical Prob http://www.snowestonline.com/forum/s...ad.php?t=47871
06 900 RMK Exhaust sensor issue http://www.snowestonline.com/forum/s...d.php?t=141808
2005 900rmk wiring? http://www.snowestonline.com/forum/s...d.php?t=116764
Reverse!!!! Binds clutch real bad?? http://www.snowestonline.com/forum/s...d.php?t=116847
Polaris 975 electrical issue http://www.snowestonline.com/forum/s...d.php?t=113278
Help with 2006 900 rmk http://www.snowestonline.com/forum/s...d.php?t=111160
How do you get the throttle body assembly off a 900 rmk? http://www.snowestonline.com/forum/s...d.php?t=104191
Cutting out majorly at anything other than WOT .. http://www.snowestonline.com/forum/s...ad.php?t=72066
Question(s) for the guys with 900 Turbos http://www.snowestonline.com/forum/s...d.php?t=149638
Pics of modified 900's lets see them! http://www.snowestonline.com/forum/s...ad.php?t=54300
05 900 top end questions and torque specs http://www.snowestonline.com/forum/s...d.php?t=104942
Do you have to pull the motor to get the jugs off a 900? http://www.snowestonline.com/forum/s...ad.php?t=74414
anyone having coil problems? 05 900 http://www.snowestonline.com/forum/s...d.php?t=139775
New 900 crankshaft assembly? http://www.snowestonline.com/forum/s...d.php?t=135146
900 piston arrow http://www.snowestonline.com/forum/s...d.php?t=131285
Hard Starting 900 http://www.snowestonline.com/forum/s...d.php?t=127864
2006 rmk Speedo sensor replacement http://www.snowestonline.com/forum/s...d.php?t=126588
New crank and clutch combo pack from Polaris for 700/900? http://www.snowestonline.com/forum/s...d.php?t=121811
High idle and intermidant PERC http://www.snowestonline.com/forum/s...d.php?t=125566
900 Low Voltage Problem http://www.snowestonline.com/forum/s...d.php?t=124054
900 with 05 & 06 piston http://www.snowestonline.com/forum/s...d.php?t=123115
RMK 900 questions http://www.snowestonline.com/forum/s...d.php?t=119449
KILLING PLUGS!! Help!!! http://www.snowestonline.com/forum/s...d.php?t=119645
06 900 MFD Cutting out? http://www.snowestonline.com/forum/s...d.php?t=117323
05 900 rmk runnning like crap after you hit some powder. http://www.snowestonline.com/forum/s...d.php?t=119262
Clutch Theory for Dummies http://www.snowestonline.com/forum/s...d.php?t=121944
2006 switchback primary clutch sticking http://www.snowestonline.com/forum/s...d.php?t=116308
crankcase sealer http://www.snowestonline.com/forum/s...d.php?t=117658
How do you clear a BLINK CODE? http://www.snowestonline.com/forum/s...d.php?t=112785
Where to find 225 Lb spring? (front-track spring) http://www.snowestonline.com/forum/s...d.php?t=112168
05 900 alititude issues...still http://www.snowestonline.com/forum/s...d.php?t=110994
Crank Bearing Questions http://www.snowestonline.com/forum/s...d.php?t=105431
Stock boost box for 700/900 RMK ... $143? http://www.snowestonline.com/forum/s...d.php?t=109452
How much oil to fill o6 RMK chaincase? http://www.snowestonline.com/forum/s...d.php?t=106314
06 700 to 900 http://www.snowestonline.com/forum/s...ad.php?t=99831
Does anyone have the instructions for adjusting the camber http://www.snowestonline.com/forum/s...d.php?t=101325
Problems 06 900 Rebuild http://www.snowestonline.com/forum/s...ad.php?t=89264
06 900 Injection Oil Leak?? http://www.snowestonline.com/forum/s...ad.php?t=96092
Anyone put anti ratchets on a new IQ without a set back? http://www.snowestonline.com/forum/s...ad.php?t=87668
__________________
Signature:
The Following 3 Users Say Thank You to mountainhorse For This Useful Post:
06 RMK 900 (09-12-2009), 94fordguy (09-30-2009), LUBA (01-04-2010)
  #4
Old 07-29-2009, 02:59 PM
Default
Fire N Ice airbox or SLP http://www.snowestonline.com/forum/s...ad.php?t=95214
Timbersled Clean Air Intake kit on my 2006 RMK 700? http://www.snowestonline.com/forum/s...d.php?t=156099
help on fire n ice intake kit for 900 rmk http://www.snowestonline.com/forum/s...ad.php?t=91025
FYI... New Fire N Ice headlight intake kit, turbo intake and other stuff. http://www.snowestonline.com/forum/s...ad.php?t=93581
Best Intake for 05 RMK 900????? http://www.snowestonline.com/forum/s...ad.php?t=71072
__________________
Signature:
The Following User Says Thank You to mountainhorse For This Useful Post:
LUBA (01-04-2010)
  #5
Old 07-29-2009, 03:00 PM
Default
Open
__________________
Signature:
  #6
Default
Also, If you open a thread...please put a "ttt" as a quick reply, or more information you may feel needs to be added to the post if it hasn't been refreshed in the last 6 months to keep the system from automatically deleting these usefull threads... many have been lost already because the system automatically deletes older threads with no action on them.
Please Do Not put a ttt on the thread every 3 weeks to keep them uncluttered.
PLEASE keep adding links you feel are relevant to 900/755's to this list
If you have posted up a question or have a tip...and got some help or answers to it....please post up a link!
__________________
Signature:
  #7
Old 07-29-2009, 07:07 PM
94fordguy's Avatar
94fordguy 94fordguy is offline
Currently: Enjoying the snow!
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
Default
Front Radiator removal for 900 RMK
//www.snowest.com/forum/showthread.php?t=44150&highlight=radiator+removal
__________________
ARRA MEMBER - Americans for Responsible Recreational Access
WSSA MEMBER - Washington State Snowmobile Association
Yakima Ski Benders MEMBER - Washington's first snowmobile club
Support Public Access to Public Land
13 PRO RMK 800 162 VEI Custom
12 Ford F-350 Lariat C/C S/B 4x4 6.7L Powerstroke...133K
08 Polaris Scrambler 500 4x4
06 Kawasaki ZZR 600
05 RMK 900 166 Anniversary Edition #850 6,782 Miles
02 Interstate 19' Enclosed
  #8
Old 08-07-2009, 02:26 PM
jafraune jafraune is offline
Currently: chillin'
jafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond reputejafraune has a reputation beyond repute
Default
Good RMK 900 Gearing Thread http://www.snowestonline.com/forum/s...d.php?t=130792
  #9
Old 10-23-2009, 08:32 PM
94fordguy's Avatar
Default
Another good gear and chain thread with part numbers.....
http://www.snowestonline.com/forum/s...d.php?t=173641
http://www.snowestonline.com/forum/s...hlight=gearing
__________________
06 Kawasaki ZZR 600
  #10
Old 01-20-2010, 09:12 PM
Danbot Danbot is online now
Currently: bustin' pow
Danbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond reputeDanbot has a reputation beyond repute
Garage
  #11
Old 01-31-2010, 08:38 PM
94fordguy's Avatar
Click Here to Register
  #12
Old 08-12-2010, 06:28 PM
94fordguy's Avatar
The Following User Says Thank You to 94fordguy For This Useful Post:
guidoxpress (08-15-2010)
  #13
Old 10-23-2010, 09:45 AM
94fordguy (10-23-2010), rmk2112 (10-23-2010), tahoermk (10-23-2010)
  #14
Old 10-24-2011, 09:27 PM
Garage
The Following 2 Users Say Thank You to Danbot For This Useful Post:
AJmhgMatthews (04-13-2016), uSoTiNy (02-28-2017)
  #15
Old 08-30-2013, 09:21 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
  #16
Old 12-27-2013, 05:36 PM
MNSledShed MNSledShed is offline
Currently: READY FOR SNOW!
MNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond reputeMNSledShed has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
