Upgrade to Premium
Fouled Plug Stuff not directly related to snowmobiles. ATVs, trucks, hunting, sports, boating etc. Please keep it clean.
Reply
  #1
Old 04-20-2009, 03:06 PM
NDflatlander NDflatlander is offline
Currently: PRO BRO
NDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond reputeNDflatlander has a reputation beyond repute
Default Maintenance intervals with synthetic oil
I've been running syntethic oil in my vehicles for a couple years, but haven't changed the maintenance intervals at all. I still have been changing my oil anywhere from 2500-3000 miles. What do you guys do? Does anyone run the synthetic oil longer and if you do how long? This stuff is getting expensive and it seems that we're always doing a $50 oil change on something around the farm.
Rate this post: Yes | No
  #2
Old 04-20-2009, 03:15 PM
Rubberdown! Rubberdown! is offline
Currently: Not set.
Basic Member
Rubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond reputeRubberdown! has a reputation beyond repute
Default
5000 miles
  #3
Old 04-20-2009, 03:33 PM
Himark's Avatar
Himark Himark is offline
Currently: Retired
Himark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond reputeHimark has a reputation beyond repute
Garage
Default
Change your oil 3 times your factory reccomended change intervals. If you are not using the synthetic oil for extended changes you are not getting the best benefit. I change my oil once a year on my vehicles or 20k miles. For the most part the year is up first. I do change filter at 6 months. You have to use a high effeciancy filter to do this. I have been doing this now for years. Currently I have a beetle tdi that has 197000 miles on it and it has only had the annual change. I also run WVO in it so was a bit concerned about that one. I have several truckers running there rigs to 50k miles and pulling samples at that time. Sample results..."good for continued use" With the correct filtering you can run 100k miles! BTW these are ALL Amsoil examples.
__________________
Forum#2009 Member Team summer sucks, Canadian Coalition,
"I am good at telling people where to go! (directionally speaking)" -Himark
timlind_2000@yahoo.com
For your Amsoil needs PM me!
  #4
Old 04-20-2009, 03:37 PM
Himark's Avatar
Currently: Retired
Garage
Default
BTW, a study done in last few months shows a potential increase of 3% fuel effeciancy using synthetic oils over std. petroleum. This combined with added protection and extended drain intervals makes it a no brainer. Actual results found in a recent fleet study yielded a 1.2% increase in economy and this was done outside the govt. studies results. Granted this means very little to us but think about the benefit to larger fleets!!!
**If you want to buy the oils at my cost I would be glad to set you up as a preferred Amsoil customer. Just PM me.
__________________
  #5
Old 04-20-2009, 03:59 PM
John John is offline
Currently: Not set.
John has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond reputeJohn has a reputation beyond repute
Default Synthetic is the only way to go...
Once a year here too, I run Mobile 1 and usually do 8000+ a year. '96 Suburban, 5.7, 12-17 MPG depending on trailer I'm pulling and wind, the 17 was between Yakima, Wa and Boise with my two place and a Dragon. I did get passed by a tumbleweed while doing 55 before I hit I84. 215000 miles now, hoping for another 100000. If the transmission holds up I'm sure the motor will still be going strong.
  #6
Old 04-20-2009, 06:43 PM
Greg B. Greg B. is offline
Currently: Not set.
Basic Member
Greg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond reputeGreg B. has a reputation beyond repute
Default
Quote:
Should be able too. I got 275,000 on my 03 HD and it has the orignal tranny. Fluid changes are key to tranny life. I should have 300,000 by the end of June
  #7
Old 04-20-2009, 07:57 PM
sledhead03 sledhead03 is offline
Currently: Not set.
sledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant futuresledhead03 has a brilliant future
Default
I go 5k miles on my mustang with full synthetic, and in my sebring I go about 8k. Depends on what kind of driving you do with the car, but 5k minimum.
  #8
Old 04-20-2009, 08:34 PM
Blu Du's Avatar
Blu Du Blu Du is online now
Currently: scott is gutless
Blu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond reputeBlu Du has a reputation beyond repute
Default
a buddy has a friend who is a amsoil rep with 250k plus with out oil change on a d max. he has an auxilary oil filter that does the trick
  #9
Old 04-20-2009, 09:04 PM
sledboy82's Avatar
sledboy82 sledboy82 is online now
Currently: i wish i lived out west
sledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond reputesledboy82 has a reputation beyond repute
Garage
Default
i change oil every 25,000 miles and change filter every 2,000 or 3,000
__________________
11 Polaris Assault 800
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
