Upgrade to Premium
General Snowmobiling Snowmobile related topics only
Reply
  #1
Old 01-11-2009, 09:47 PM
sledskiing sledskiing is offline
Currently: waiting
Basic Member
sledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond reputesledskiing has a reputation beyond repute
Default Shop Air Compressor?
Any suggestions on an air compressor for my home shop? I'll be using it for: simple griding, changing tires, light cutting. Nothing fancy.
Do I really need a 60 gal or is a 25 enough
Rate this post: Yes | No
  #2
Old 01-11-2009, 09:50 PM
carpainter29 carpainter29 is offline
Currently: ...
Basic Member
carpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond reputecarpainter29 has a reputation beyond repute
Default
You can never have enough air. A small die grinder or angle grinder will drain a 25 gallon in no time. I would go as big as your wiring or budget allows. Just my .02
Aaron
  #3
Old 01-11-2009, 09:52 PM
Blk88GT's Avatar
Blk88GT Blk88GT is online now
Currently: THE CHASE IS ON!!
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
Default
I had a 30gal Craftsman for 5 years, did the job but rattled my brain when it ran (and it ran often) but it did the job. Die grinder would keep it running a lot.
I went to a Husky 60gal 240v job when that one blew up and I'm glad I did. I rebuilt the old one and gave it to my dad so he had something bigger to use.
__________________
2019 Freeride 154x3 w/SHOT
2016 Summit X T3 154
  #4
Old 01-11-2009, 10:08 PM
Snoclo Snoclo is offline
Currently: @ work, thinking about rid'in
Basic Member
Snoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant futureSnoclo has a brilliant future
Garage
Default
As stated before, go with as big as your budget will allow. Any low volume or painting won't require much, but once you start grinding for any length of time or use any type of tool that spins alot of rpm your gonna wish you had more. If you think your ever going to sand blast, better consider a 2 stage with a 60/80 gallon tank. Better to spend a little more up front, then find out you wish you had it to begin with when your in the middle of something.
I've had a Quincy QT5 for 14 years, never regretted it.
  #5
Old 01-11-2009, 10:23 PM
XC700116 XC700116 is offline
Currently: Not set.
XC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond reputeXC700116 has a reputation beyond repute
Garage
Default
I have a little 10 gal for portability and a 60 Gal Husky for the shop. My 60 is still a single stage and if I had it to do over again I would have went to the dual stage. If your going to make the investment for a big one definitely go with the dual stage then you won't be left wishing you had gone bigger after the fact. Die Grinders, Sanders, air nibblers, cut-off wheels, ect all use a pile of air.
  #6
Old 01-11-2009, 11:45 PM
cableguy cableguy is offline
Currently: Not set.
cableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond reputecableguy has a reputation beyond repute
Default
something with 15 cfm min is nice.
  #7
Old 01-12-2009, 01:01 AM
TNTCOPP's Avatar
TNTCOPP TNTCOPP is online now
Currently: Back to selling.....
TNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond repute
Default
I'll chime in and plead ignorance here. What does the dual stage get you? I have not researched enough yet. Was looking at the CH 60 gal from Lowe's against the same only Husky at Home Depot. I use 1/2" impact and die grinder on average say 5 hours per week.
Thanks - sorry to poach.
  #8
Old 01-12-2009, 01:33 AM
theultrarider theultrarider is offline
Currently: still a rebel way back in the country
theultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond reputetheultrarider has a reputation beyond repute
Default
The dual stage gets you air built back up quicker. If you run a da sander alot you will want one for sure. The home depot/lowes 60 gal single stage will do most everything a do it yourselfer needs. Sure, there are times I wish I had more. I had a 30 gal craftsman for 15 years and its still running after all these years. Lots of shop time and even painted a few trucks with it. I now have a 60 gal lowes compressor. The extra volume is sweet and the bigger compressor is quicker and quieter.
  #9
Old 01-12-2009, 08:28 AM
fassteddie fassteddie is online now
Currently: well stated jim. thanks ed
fassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond reputefassteddie has a reputation beyond repute
Default
5 hp 2stg.17.8 scfm @150.p.s.i. should run a large hobby shop. units like this range from $1000. $1600. dont buy the $599 one its not made for cont. duty.
  #10
Old 01-12-2009, 08:30 AM
spring snow hero spring snow hero is offline
Currently: behind rifle sights where you can't see me
Location: spokane, well actually the bustling metropolis of otis orchards
Basic Member
spring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond reputespring snow hero has a reputation beyond repute
  #11
Old 01-12-2009, 09:08 AM
PJ-Hunter's Avatar
PJ-Hunter PJ-Hunter is offline
Currently: Gotta get a couple more rides in...
Paid Premium Member
PJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond reputePJ-Hunter has a reputation beyond repute
Garage
Click Here to Register
  #12
Old 01-12-2009, 04:34 PM
Currently: waiting
Basic Member
  #13
Old 01-12-2009, 08:16 PM
ttyR2 ttyR2 is offline
Currently: strategizing
ttyR2 is an unknown quantity at this point
  #14
Old 01-12-2009, 09:00 PM
Ten-Zing Ten-Zing is offline
Currently: Not set.
Basic Member
Ten-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond reputeTen-Zing has a reputation beyond repute
  #15
Old 01-12-2009, 09:22 PM
hilinerider hilinerider is offline
Currently: Not set.
Basic Member
hilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond reputehilinerider has a reputation beyond repute
  #16
Old 01-13-2009, 12:06 PM
sbojan sbojan is offline
Currently: Not set.
Basic Member
sbojan is on a distinguished roadsbojan is on a distinguished roadsbojan is on a distinguished roadsbojan is on a distinguished roadsbojan is on a distinguished roadsbojan is on a distinguished roadsbojan is on a distinguished road
  #17
Old 01-13-2009, 01:14 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #18
Old 01-13-2009, 01:45 PM
Currently: Not set.
Basic Member
  #19
Old 01-13-2009, 01:52 PM
Scott's Avatar
Garage
  #20
Old 01-13-2009, 02:08 PM
  #21
Old 01-13-2009, 03:10 PM
TNTCOPP's Avatar
  #22
Old 01-13-2009, 10:38 PM
  #23
Old 01-13-2009, 10:56 PM
red99powerstroke's Avatar
red99powerstroke red99powerstroke is offline
Currently: BRAAAAAAAAAAAAP
red99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond reputered99powerstroke has a reputation beyond repute
  #24
Old 01-13-2009, 11:24 PM
snowyo snowyo is offline
Currently: supposed to be working
snowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond reputesnowyo has a reputation beyond repute
  #25
Old 01-13-2009, 11:46 PM
Beels Beels is offline
Currently: There's NOTHING free or basic about me
Basic Member
Beels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond reputeBeels has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
