03 RMk wont hold RPM
J
JohnnyH
116
SL,UT
Looking for ideas on why my 03 RMK 800 will hit 8000 RPM at WOT on the trail and then slowly drop RPM till I let off the throttle.
If the Deep fluffy powder it will only pull 7200-7400 RPM.
Ideas???
Ride 7-10k
Crankshop twins
UBR head
159 polaris track
19-41 gears
390 mains(too rich, will try 380 later this week)
10-58 weights, 140-330 spring (Team Green )
TSS-04. 58-38 with red/pink (140-260 ) with 3 delrins
Yellow exhaust springs
I weigh about 260 with gear.
Thanks for your ideas
M
Sep 4, 2007
568
317
Minnesota
It's shifting too fast and dragging your RPM's down.
Could run 10-56 weights and try it. If your engagement is right though you could try a heavier secondary spring instead. I'm not a clutching pro. Just some thoughts.
J
JohnnyH
116
SL,UT
Yea the 10-56's crossed my mind but that just does not seem right for a 800 with twins:confused:
Higher start or finish for the Spring?
M
Sep 4, 2007
568
317
Minnesota
Couldn't tell ya for sure.
I would think you'd be close on clutching to new 700's
10-58's with a 140/330 spring in the primary.
56/42/36 helix with a Black Team spring 155/222 (I think) in the secondary.
omernikski
651
78
Minocqua, WI/ Foxboro, WI
I have the identical sled setup for the same alt. running CPI Twins with twin stingers. I will let you know tomorrow what I'm running for a setup, I'm not sure at this time because I bought the sled this way. It about pulls my arms off and engages at 3500 rpm and tachs out at 8800 give or take a couple hundred rpms. the sled did come to me with 390 mains, and a speedwerx high alt. domes running 50/50 race gas
T
theultrarider
891
Soldotna Alaska
I'm running an 03 159 with slp race twins and also weigh about 260. Last week I finally dropped to 19/43 gears and that made a big difference on just what you are describing. I also went to a 160-240 secondary spring, black/purple. That worked better than the 140/260 also. Good luck, Please let us know what you figure out.
Tim
indydan
1,245
3,301
Custer, South Dakota
www.indyspecialty.com
Air Box & vents
Ideas???
Ride 7-10k
Crankshop twins
UBR head
159 polaris track
19-41 gears
Jonny, Tell me about your air box and carbs vents.........
Are they completely stock or have they been altered ???
1 thing - Your Helix is to flat, I would go right to a 64/42 .46 and gear it down.
A
810
Elko, NV.
I'm not following Indy's clutching advice. How is a steeper helix going to help this sled gain RPM's. Gearing down is generally good for another loss in RPM's without going lighter in the primary. Hmmm!
T
theultrarider
891
Soldotna Alaska
I'd like to hear Dan's explanation as well. A steeper helix will usually drop r's and slow down backshift, so if it isn't backshifting now, how will a steeper helix help?
J
JohnnyH
116
SL,UT
The air box is gutted with a SLP air horn kit, carb vents are just the stock ones that go to the front of the air box.
I also have plenty of Flow-Rites.
What kind of gear down, Like 19-43 or lower?
M
Sep 4, 2007
568
317
Minnesota
I would say your gears are fine. Try a heavier starting secondary spring. That will slow the shifting (keeping your RPM's up) and improve the backshifting. There only like $20. That would be the cheapest place to start. I don't agree with a steeper helix in the elevation your in. Would also like to know how that would help.
J
JohnnyH
116
SL,UT
I have a Black/Red (155-222) kicking around, What would the lower finish do different than the Red/Pink (140-260) ???
Or would I be better off trying a Black/ Purple (160-240) ?
R
Aug 30, 2008
1,438
151
Rocky Mountians
Had a similar thing happen when I first rode my sled (04 800). Turns out I was running the ignition switch in the secondary position not the premium. It was cutting down the timing.
Just a thought, I know there are other circumstances
J
JohnnyH
116
SL,UT
So what will I notice if I have either too high of a start or finish with a secondary spring?
40
2
8
If it was me I'd spend a little more time and get the jetting set spot on. I ended up dropping my jetting down 5 jet sizes last year to get the perfect color on my plugs. And it changed the RPM's big time and then I dial in the last couple R's with the weights dropping to a 10-56 and may go lower yet.
Get some good info on plugs there's more to it than just looking for Brown on the plug. It took me some time but I have it perfect now.
J
JohnnyH
116
SL,UT
What is your elevation, sled and setup?
40
2
8
I run at 9000-11500.
My sleds 02 700 Ported and piped, Wiseco pistons
Primary stock Black/green 120-340 10-56's
Secondary SLP yellow/purple (don't remember rate)
SLP mountain helix 44-46/34 1 shim #3 hole
I have a friend that use to work for Xtreme and compared these specs to there kits and it's real close, except they run a 10-57.5 weight. (they grind their weights) I was having the same problem when I talked to him and he told me to dial in my jetting so I did and it helped. I dropped to a 290 from a 330 and could probably go down one more size if I pushed it. I'm pulling 8200 RPM's but I'm still a little under full shift out. I know the motor will pull more R's. My big thing now is I think I need to just clean up my clutches real good and see.
Plus I did find that my throttle cable was starting to frey so I wasn't getting WOT alot of the time when I was tuning last year, so that problems fixed now I just need to get out at check it out.
