broken ski rubber
hanson summit
134
26
Farm in SD
Ski doo rev ski rubbers are your best bet! They last alot longer. I love the grippers but they dont last too well for me. Plastic gets slopped out so the mounting bushings can move up and down. At this point no ski rubber will stay in. Going to slp powder pros now!
tuneman
1,167
1,205
Minnesota
www.everettsports.net
Even the Doo snubbers eventually tear and fail, but they work really well.
I've found that the Doo snubbers work best, part #505071779, followed closely by adding a 1/16" shim under the stock snubbers (aluminum or uhmw). Lubing the snubbers with silicone will make them last longer too.
Sheetmetalfab
7,905
6,649
I got some urethane ski bumpers from sweden.
Pm “gulfi” on snowest.
Worked sweet last year.
If using doo rubbers 3 sheetrock screws into the front and back of each rubber will keep them in place. (Drill through the plastic)
Grease the top of the rubber.
Sheetmetalfab
7,905
6,649
They work sweet.
Sheetmetalfab
7,905
6,649
a430195da984f04b3db4c6b309709081.heic
Cut one to fit the Timbersled ski.
Should be a good replacement for the rock hard loose stock one.
Sheetmetalfab
7,905
6,649
8db7f6544e8cb1b7f042d62d13d8c396.heic
ee0cab1ae390bfcaf17b480c8b2f769e.heic
Adding bracing to my spindles.
Re Powdercoat, new bushings and I’ll be ready for another season.
Keep in mind these are hand made in small batches.
Nearly prototype pieces.
Hence the small voids.
