Upgrade to Premium
Reply
  #1
Old 05-09-2019, 08:36 AM
G-Force's Avatar
G-Force G-Force is online now
Currently: Parking the pro and polishing the CVO..
G-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond repute
Default How important is re-mapping?
Looking at building my first snow bike. Have the kit on order, snow checked a Riot LE
Now for the bike.. It will only be a play bike, I have a sled for the deep/mountain days. I just want something playful I can bomb along beside the trails as the wife learns to ride a sled.
Have it narrowed down to an '18 KTM 450 SX, or an '18 YZ 450F. Riding be -10*C to +10*C, and between 2,000 - 4,500' elevation. Just wondering how critical re-,sapping the bike will be, if at all? Have read where some guys are having issues over-feeling and getting fuel into the engine oil? Would re-mappping things help? Or am I way overthinking things. Just want to make the best choice possible, the first time.
Thanks in advance!
__________________
2018 F-350 6.7 Platinum
2019 Axys RMK 850 155"
2016 Axys RMK 155"
2013 CVO Road Glide
2011 AMG C63 Sedan Sold
"Haywood, who's a convicted felon in the offseason.."
Rate this post: Yes | No
  #2
Old 05-09-2019, 09:05 AM
barkbuster barkbuster is offline
Currently: Not set.
barkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant futurebarkbuster has a brilliant future
Default
Fuel re mapping is more to correct for opening up the air box, and exhaust. The efi system will compensate for altitude and temp. on its own. The over fuelling issue is due to the engine temp being too low, and the efi system staying in warm up mode and adding more fuel. This issue is addressed by managing engine temp with hotter thermostat, shunting radiators, blocking airflow to radiators, engine blankets, ect. The goal is to maintain an engine temp of at least 180 deg f.
The Following User Says Thank You to barkbuster For This Useful Post:
G-Force (05-09-2019)
  #3
Old 05-09-2019, 10:50 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
What he said.
I will concede there are small improvements available in the way the fuel can be delivered and when it is delivered but by in large the manufactures are not leaving a ton extra of performance on the table these days. Claims of 8hp yada yada through a remap I call BS. You can get improvements via fine tuning the fuel and timing which will help in setting up a better running bike. A bone stock bike is going to run pretty friggin well out of the box these days if you maintain your temps as stated. So is a remap necessary, no, is it something to consider, maybe down the road once you run out of things to spend money on. You really cant get a bunch more HP without making physical changes to the motor ie. cams and porting and high comp pistons, race fuel yada yada. More air, more fuel equals more power.
Buy a bike, get a Tstat, shrouds, engine blanket and my bet is all you will do is add gas and do oil changes.
M5
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to M5- For This Useful Post:
  #4
Old 05-09-2019, 01:09 PM
Excalibur's Avatar
Excalibur Excalibur is offline
Currently: Need snow!!!!
Excalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond repute
Default
Agreed with everything said in the prior responses. A problem associated with the warm up/over fueling of the stock ECU is you will end up diluting the oil with fuel. The challenge is keeping engine temps consistently above 160F at which point the warm up over fueling stops. You will also have days of trying to get it cooled down. These bikes can be managed by a Tstat, engine blankets, blocking and unblocking the rads. You will find quite a variance of conditions that affect engine temps even with the right gear. Having a snow specific tune that drops that warm up temp/over fueling is also one way to keep excess fuel out of the crankcase. PR2 has a good premapped ECU. I have it currently on three bikes. I did not purchase it for the possible performance gains, just keeping these money pits alive as long as possible!
Link to some PR2 info https://www.snowest.com/forum/showth...&highlight=PR2
The Following User Says Thank You to Excalibur For This Useful Post:
  #5
Old 05-09-2019, 01:15 PM
G-Force's Avatar
Default
Thanks guys ! Yes, I wasn't looking for more performance, just to correct the over-fuelling issue. Seems that's more an operating temp deal than tune, so that eliminates a variable when it comes to deciding which bike!
With that sorted, which would be the more reliable? I know Yamaha are sturdy as heck, but I'm thinking the better clutch and trans on the KTM MIGHT make it more suitable to a snow bike application?
__________________
2016 Axys RMK 155"
2013 CVO Road Glide
  #6
Old 05-09-2019, 01:30 PM
Basic Member
Default
Forgot to mention, make sure you install a temperature gauge so you can see where you are at.
M5
  #7
Old 05-09-2019, 01:47 PM
teal_210 teal_210 is online now
Currently: Not set.
teal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond reputeteal_210 has a reputation beyond repute
Default
I have a lot of time comparing a 2018 ktm 450sxf to a 2018 yz450f with ARO 120LE kits. The KTM wins hands down, it's not even close. I sold my yzf for a ktm 450.
No reliability issues with either bike.
The Following User Says Thank You to teal_210 For This Useful Post:
  #8
Old 05-09-2019, 03:41 PM
Jaynelson Jaynelson is offline
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
Haven't seen over-fueling issues on KTM's for the most part, I wouldn't bother with a re-map on an SX or XC.
EXC's usually like a re-map if you ditch the smog equipment/change exhaust.
  #9
Ktm300 Ktm300 is online now
Currently: Not set.
Ktm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant futureKtm300 has a brilliant future
Default
Just curious what the KTM did so much better then the YZ ? Iím currently running an 18 YZ as a snowbike and it runs really strong and has been bulletproof, but Iím always looking for an improvement if there is one when Iím eventually going to get a new bike.
  #10
Old 05-09-2019, 08:32 PM
Currently: Not set.
  #11
Old 05-09-2019, 09:54 PM
G-Force's Avatar
Click Here to Register
  #12
Old 05-10-2019, 08:17 AM
Basic Member
  #13
Old 05-13-2019, 08:13 AM
Currently: Not set.
Ktm300 (05-14-2019)
  #14
Old 05-13-2019, 10:37 AM
byeatts byeatts is online now
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
The Following User Says Thank You to byeatts For This Useful Post:
dooman92 (05-13-2019)
  #15
Old 05-14-2019, 07:51 AM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
  #16
Old 05-17-2019, 05:44 PM
G-Force's Avatar
  #17
Old 07-08-2019, 03:47 PM
G-Force's Avatar
  #18
Old 07-09-2019, 07:38 AM
GKR's Avatar
GKR GKR is offline
Currently: Its ON !!!!!!!!!!!!!
GKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond reputeGKR has a reputation beyond repute
  #19
Old 07-10-2019, 10:27 PM
G-Force's Avatar
  #20
Old 07-11-2019, 07:28 AM
Basic Member
  #21
Old 07-11-2019, 02:03 PM
POLZIN's Avatar
POLZIN POLZIN is online now
Currently: Back from riding the wilderness
POLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond reputePOLZIN has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Looking for mapping Thread Starter — mickyd32 Forum — Polaris: Pro-Ride Replies — 4 Last Post — 01-06-2013 01:02 PM
Thread — mapping ? Thread Starter — huetty1 Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 06-23-2012 11:42 PM
Thread — Mapping Thread Starter — cgsled Forum — Polaris: IQ Replies — 4 Last Post — 12-07-2010 01:05 AM
Thread — 07 mapping on a rt Thread Starter — rather be ridn Forum — Ski-Doo: REV Sleds Replies — 7 Last Post — 01-19-2010 09:37 PM
no new posts
