Upgrade to Premium
Clutching Discuss all things related to Clutching for your sled.
Reply
  #1
Old 02-13-2019, 10:41 AM
Bcpappy Bcpappy is offline
Currently: Not set.
Basic Member
Bcpappy is an unknown quantity at this point
Default Elevation and clutching.
So I know carbed sleds are impacted by big elevation changes, so that will effect the power output of the engine causing the need to set up a clutch for the area you ride the most. I don't know alot about clutching, just trying to figure out the possible clutching issues that could happen if I go ride Vancouver island ( 0-4000 feet). Both my sleds (2015 m8000 limited and 2019 alpha one) are fuel injected and set up for 6000-8000 feet. I ride the north Rockies in B.C. the most, I live in the Peace area. Do you guys think there will be a performance change at low elevations?
Rate this post: Yes | No
  #2
Old 02-13-2019, 12:07 PM
MountainCat1 MountainCat1 is offline
Currently: Falling off in the Powder
Basic Member
MountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond repute
Garage
Default
The motor will run fine due to the ECM adjusting fuel/air/timing for the altitude, but it will over-rev out of your power band due to the lighter (high altitude) clutch weights. A N/A motor will make less power at altitude due to the thinner air, thus the need for lighter clutch weights at higher altitudes. If it's only infrequently that you ride at lower altitude, I'd just live with it & ride easy. Your other option is to install adjustable clutch weights & tune them for your intended riding areas. Primary & Secondary spring rates play a role too, but this gets more into more advanced clutching magic that I leave up to the experienced gurus that will tune my sleds for me.
  #3
Old 02-13-2019, 01:37 PM
Currently: Not set.
Basic Member
Default
Just the answer I was hoping for, thank you!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 15'm8000 elevation clutching ? Thread Starter — Wheeeezy9 Forum — Arctic Cat: Proclimb M Replies — 7 Last Post — 06-16-2017 08:25 AM
Thread — Low Elevation Clutching Thread Starter — jstarry31 Forum — Polaris: AXYS Replies — 11 Last Post — 12-15-2016 11:56 AM
Thread — Low elevation clutching help Thread Starter — FitShaced Forum — Arctic Cat: M Series Replies — 18 Last Post — 03-15-2014 09:02 AM
Thread — elevation and clutching? Thread Starter — mkhoskins Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 13 Last Post — 03-14-2014 08:03 AM
Thread — Low Elevation Clutching Thread Starter — eisen097 Forum — Arctic Cat: Proclimb M Replies — 14 Last Post — 10-08-2012 07:51 PM
no new posts
