skid or ski shocks? there are rebuilders for your ski shocks or you can find some off a newer model that interchange. skid shocks should still be available. check out schmidt bros for a rebuild.
rollers are available as a unit, you can no longer get just the bushing. keeping that clutch clean seriously reduces the wear its known for.
talk to your dealer, dont believe all you read with the online fisches.
LT- what year is your sled and or clutch? the 97 and prior clutches with the 8mm i.d. rollers are the ones that are becoming increasingly harder to get and bushings no longer available. thats what the original poster stated he had was a 97 sled. the 98 and up styles with the 9mm i.d. are still available as bushings only, or rollers with bushings, your choice.
dont confuse a dealer stock with corporate availability, and be sure your comparing apples to apples as not to cause any confusion.
