What are your setups on 2016 M8000 Ltd?
K
Dec 12, 2010
99
32
18
38
Just received my 2016 M8000 LTd 162, and will be starting to tune it for the season. All I need is baseline setup, so for those of you who got to ride them last year what did you guys (Wyoboy) do for a setup?
Suspension setup, what rear skid position? What PSI in the Fox shocks front and back?
Clutching, I'm looking into MDS weights in the future, or what are you guys using for Primary weights/spring? How about the secondary? I had a Dalton Aqua Blue Primary spring installed in my 2013 M800 and loved it, seems the 2016 primary is set up to engage at similar rpm as stock 2013.
Gearing, what you guys running for gearing? Stock 19/50? Is it true that Cat is using an Aluminum gear? What options for upgrade?
Have a TSS can on installed for now
