W
Just bought a 2013 Assault RMK.
The lever just goes flat to the bars every time you pull. Even if you try to pump it up you can't get it to build any pressure. I dont see any fluid leaking anywhere. Tried cracking the bleeder and bleeding the lines, but since I cant get any pressure pumping the lever, it doesnt allow me to push any fluid to try getting air out if that's the issue.
Do you think its an issue with the master cylinder or the caliper?
Is there rebuild kits available for the master cylinder or the caliper?
Perhaps I am bleeding brakes incorrectly?
I do have a spare master cylinder from an old IQr around somewhere that should be the same as the one on the Pro. But, if its a caliper issue no sense in screwing with that.
