B
Brp is updating our summit 850 154 gearing it says new gear ratio but does it come with a new chain or they using the same size chain
Big John even with the belt issues on the 154 2.5 go up a tooth,what's your input on brp wanting to run 21/53
it was poor clutching, wrong belt deflection video, no venting, poor PDI by dealer, owner running sled at wrong rpm for MOST issues...
gearing is way down the list-BJ...
What should proper belt deflection set at?
SHR recomendations...
154/3" hi elevation only- new gear ratio (21/51) is OK
154/3" low/mid ele the stock gearing (19/45) is OK
154/2.5 hi elevation only, stock gear (19/45) is OK
154/2.5 hi/lo ele gear up (20/45) recomended
154/2.5 lo only gear up 2 (21/45) recomended
165/3" hi ele only update gear (21/53) is OK
165/3" low/mid ele stock gear (21/51) is OK
165/2.5 hi ele only stock gear (21/51) is OK
165/2.5 lo/mid gear up (22/51) recomended
clutching, venting, motor mt shims, belt deflection are way more important-BJ
