Upgrade to Premium
Electronics Beacons, GPS, communication systems, etc.....
Reply
  #1
Old 12-20-2013, 03:37 PM
RX-1 Liter RX-1 Liter is offline
Currently: Not set.
RX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant futureRX-1 Liter has a brilliant future
Default GoPro Mounts
I just picked a GoPro 3 Black. What mounts should I look into? I was considering the Chest and the handlebar. Any advice?
Rate this post: Yes | No
  #2
Old 12-20-2013, 07:23 PM
OEUnlimited's Avatar
OEUnlimited OEUnlimited is offline
Currently: Not set.
OEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond reputeOEUnlimited has a reputation beyond repute
Default
Quote:
Comes with the sticky mounts for your helmet as well. Those with the chest and handlebar - which can also be attached to a ski pole, shove shaft, etc. are the most popular.
For long days in the cold, a good investment may also be extra batteries and/or a battery bacpac (snap on extended battery).
__________________
Avalanche Airbags, Beacons, Shovels, Probes, BC LINK, GoPro, PLBs, Delorme InReach, and more.
Rent for dollars per day!
Off-rental sale: Deals on Tracker 3, Airbags, and more
www.oerentals.com - 201-477-0217
  #3
Old 12-23-2013, 08:10 AM
DieselTwitch DieselTwitch is offline
Currently: Trying to get lost
DieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond reputeDieselTwitch has a reputation beyond repute
Default
Lots of extra batteries and replace every hour. Also 1080p-30FPS is the least power consuming setting you can use.
I run a chest mount along with a telescoping pole in my back pack.
  #4
Old 01-04-2014, 09:00 PM
dubbs dubbs is offline
Currently: Selling the turbo kit time for a new avatar
dubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond repute
Default
I like the chest, helmet, and hood facing back quite a bit..
Also these batteries and charger from ebay are a great deal and work really good..
http://www.ebay.com/itm/Wasabi-Power...item27d9b5da0d
  #5
Old 01-05-2014, 03:00 AM
907SledShredder 907SledShredder is offline
Currently: Status Quo
Basic Member
907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute907SledShredder has a reputation beyond repute
Default
Bumper mount makes cool shots.
Click image for larger version
  #6
Old 01-05-2014, 03:04 AM
Basic Member
Default Since I can't seem to get both pics loaded at once.
From front bumper.
  #7
Old 01-05-2014, 08:49 PM
Dbaker Dbaker is offline
Currently: 30 rounds of rock and roll...
Basic Member
Dbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond reputeDbaker has a reputation beyond repute
Default
like the front bumper view does anyone have a forward facing
front bumper mount?
  #8
Old 01-06-2014, 10:46 AM
dstrbdxpak dstrbdxpak is offline
Currently: Not set.
Basic Member
dstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond reputedstrbdxpak has a reputation beyond repute
Default
Ive been using a rear facing front bumper mount w/ extension pole from Rodger @ http://www.vuvantage.com
Youtube clips
Some tips....
Dual U-bolt mount is good
Use the HD Metal lever lock clamp at at the bumper side
Composite at the camera side.
Farther out you try to lean it, the easier it will tip down, works best in pow, not so much on hard pack.
You'll have to test out vibration dampening in anything other than pow, Im gonna try wrapping my front bumper with a roll of grip tape.
Also looking at doing a support arm of sorts.
  #9
Old 01-06-2014, 02:56 PM
Basic Member
Default 360 degrees
Quote:
front bumper mount?
Front bumper is same as rear and has 360 degrees of rotation. I wrap rubber stretch tape around bumper then use 2 hose clamps on one strand of heavy electric wire, then bend straight up. You can tilt forward for entire sled shot or toward you for rider close up or rotate camera for filming in front of sled. Cost about 5 bucks for 3 mounts.
  #10
Old 01-06-2014, 06:35 PM
milehighassassin's Avatar
milehighassassin milehighassassin is online now
Currently: Motor is complete!!!
Moderator: Premium Member
milehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond repute
Garage
Default
Anyone using a teather of some sort on the camera?
The Following User Says Thank You to milehighassassin For This Useful Post:
907SledShredder (01-11-2014)
  #11
Old 01-06-2014, 11:56 PM
Basic Member
Click Here to Register
  #12
Old 01-07-2014, 12:13 AM
Garage
  #13
Old 01-07-2014, 06:12 PM
Currently: Not set.
Basic Member
  #14
Old 01-07-2014, 08:14 PM
byeatts byeatts is offline
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
  #15
Old 03-05-2014, 11:38 AM
2Huskies's Avatar
2Huskies 2Huskies is offline
Currently: not being CBP any longer
2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute2Huskies has a reputation beyond repute
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Billet GoPro mounts Thread Starter — FatDogX Forum — Misc. Sled Parts Replies — 7 Last Post — 11-30-2013 01:46 PM
Thread — GoPro mounts Thread Starter — kipperdavis Forum — Mountain/Deep Powder Replies — 7 Last Post — 11-14-2013 12:52 PM
Thread — gopro mounts for a 509 helmet Thread Starter — Goin For Snow Forum — Mountain/Deep Powder Replies — 24 Last Post — 02-24-2013 05:46 PM
Thread — Couple GoPro mounts w/pics Thread Starter — snopro176 Forum — Electronics Replies — 4 Last Post — 01-29-2012 04:22 AM
Thread — GoPro 1080p HD Helmet Hero $129.99 GoPro 1080 for $135 shipped....good deal? Thread Starter — Mafesto Forum — General Snowmobiling Replies — 7 Last Post — 12-21-2011 02:32 PM
no new posts
