I have access to the newer hood gauges found on the firecat, crossfire and m-series off of a wrecked sled. Can it be retrofitted to be used on my 1M?
I know the speedo is electronic, which will be one issue. But I would like to know if the rest of the electrics would work, temp light, low oil light, rpms, etc. I believe I can work on the speedo part seperate from the rest.
It looks as if the 03 - 04 speedo sensor should bolt up to where the ZR does and just add power, right.??????
