There should be a few mountain cats out there. What is everyone running for air and clicker setings.
most cat guys do ride with higher pressures, but most of them do the hill climb thing where you need a stiffer psi.Thanks Guys
Cat recommends way higher pressures than that. I have not tried it yet but other riders said rear was stiff, I think 180lb was in manual
After few sleds with Float shocks, i have few tips. Always take off weight on suspension. You need to put a bit more pressure because when you will unscrew the air pump, a bit pressure will get out. I always does a double check to have a right pressure and take the pressure OUTSIDE, in your riding temperature.
After this lesson, I'm 180lbs geared up with my backpack and i have a 18' MC 153''. I run at softest mode (1) on snow, and depending of trail i turn up the QS3 clickers
On flat trail, FSS 2, FTS and RTS 1 (less sway on front end)
On small bumpy trail : FSS = 2, FTS =2, RTS = 1
On bumpy trail : FSS and FTS = 3, RTS = 2
FSS : 65psi
FTS : 55psi
RTS : 125psi
I had a 16' LTD 162 3'' before this and i don't have any regret, I only notice that a 153 is more sensitive to lower pressure on RTS.
Thanks Guys
